acivoJ Napisano Februar 13, 2015 Share #1475 Napisano Februar 13, 2015 Da, razmišljao sam u tom smeru. Treba Epson, a treba i odgovarajuće mastilo. Čini mi se da su tada pljuckavci štampali na posebne "printable" CD medije. Neko reče ovo mastilo: http://www.inksupply.com/product-details.cfm?pn=MISPRO-4-Y Link to comment Podeli na ovim sajtovima More sharing options...
acivoJ Napisano Februar 13, 2015 Share #1476 Napisano Februar 13, 2015 Javija se Šime! Neću dalje ovde pisati dok ne budem imao šta. Yes, I know that the HPs will print like that - I spent a lot of time experimenting with an HP1100. There is a "workaround" that might work for you.Before printing take some pigment inkjet ink - I used Mispro Yellow since I had it - and smear it on the copper using a paper towel. Allow it to dry, then print. You can also dilute the ink by 1:10 and try that. Other inks from a crafts shop may work as well. A heatgun (on low) or hair dryer helps it dry faster.I never followed up on the HP because I wanted a process that let you just print and etch.I have some other thoughts on correcting the problem. If you'd like to discuss them, contact me directly at *******@************ Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Februar 13, 2015 Share #1477 Napisano Februar 13, 2015 http://techref.massmind.org/images/pcb/etch/directinkjetresist/pcb_volkan_before_etch.jpg volkan sahin pretraži po netu. zanimljivo šta sve čova uradio i ako se oduzme potreba da bude pošto-poto tvoj uradak i ako se predpostavi da nisi na kraj sveta, apsolutno ništa ne opravdava izradu grafičkog filma ko predloška Link to comment Podeli na ovim sajtovima More sharing options...
silentbob Napisano Februar 13, 2015 Share #1478 Napisano Februar 13, 2015 Ako nije 'rapavo neće ni da se štampa. Čime da tretiram pločicu ako ne šmirglom? Šta misliš da provučeš bakar kroz kiselinu za ecovanje na kratko pre štampe. Drugo što mi pada na pamet je neko ovlaš peskiranje. Link to comment Podeli na ovim sajtovima More sharing options...
Leonardo Napisano Februar 13, 2015 Share #1479 Napisano Februar 13, 2015 Bob je u pravu za peskiranje, tačnije rečeno za SODIRANJE jer se radi soda bikarbonom. Efekat je odličan, abrazija minimalna, površina dobija fini mat satenski finiš. Evo i linka za DIY skalameriju koja je krajnje jednostavna, a ceo postupak je apsolutno "for dummies". Link to comment Podeli na ovim sajtovima More sharing options...
Aleks Napisano Februar 21, 2015 Share #1480 Napisano Februar 21, 2015 Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Februar 24, 2015 Share #1481 Napisano Februar 24, 2015 i dalje oko ispravljača tasovac, fazan, plastifikacija Fukushima je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
John Coltrane Napisano Februar 25, 2015 Share #1482 Napisano Februar 25, 2015 za EL34 SE nije mi žao što pocepa prst dok sam rasturao al sto okrnji kalemsko telo, jooj, samo pitam se koj ce da gu proračuna Link to comment Podeli na ovim sajtovima More sharing options...
Fukushima Napisano Februar 25, 2015 Share #1483 Napisano Februar 25, 2015 Bravo Gujo, ti si bas temeljan Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Februar 26, 2015 Share #1484 Napisano Februar 26, 2015 e, hvala. sad je novi problem gde naći mat bele led od 5mm koje svetle zeleno i crveno ono, jedna boja ali kućište belo, difuzno. imam diode od bar nekokoliko hiljada mcd al su bistre pa kad se upali to je šlog za oči. jedino što sam našao je u elementi dvobojne dvopinske (antiparalelne r i g led) obićnih nema nigde ili ja ne gledam detaljno. bgd izgleda totalna 0 Link to comment Podeli na ovim sajtovima More sharing options...
ManicP Napisano Februar 26, 2015 Share #1485 Napisano Februar 26, 2015 Jes probao da izmatiraš LED (čelična vuna, žičana četka ili sl. ja sam svojevremeno provozao šmirglu po nekim diodama al to već nije lepo) i da malo smanjiš struju? Jest malko budž al možda završi poso. Ja imao sličan problem na DAC, plava i bela dioda oči isteraju. Na kraju prigušio svetlo, trimer mesto otpora i naštelovo na slične nivoe. Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Februar 26, 2015 Share #1486 Napisano Februar 26, 2015 manicu, jel ti to vladaš telepatijom probao, može koja da se baci na par iljada komada, al nije to to. optički akril providan ko staklo, nema šta nisam probao. a vidi slidžu, "tako blizu a tako daleko". tri dana im treba, ko dajca da šalju Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Februar 26, 2015 Share #1487 Napisano Februar 26, 2015 Jes probao da izmatiraš LED (čelična vuna, žičana četka ili sl. ja sam svojevremeno provozao šmirglu po nekim diodama al to već nije lepo) i da malo smanjiš struju? Jest malko budž al možda završi poso. Ja imao sličan problem na DAC, plava i bela dioda oči isteraju. Na kraju prigušio svetlo, trimer mesto otpora i naštelovo na slične nivoe. Kakva bre vuna, smirgla,...? Aceton. Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Februar 26, 2015 Share #1488 Napisano Februar 26, 2015 genije, ništa acenton/nitro. ne utiče. možda kod turbojeftinih kinesko/turskih. Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Februar 26, 2015 Share #1489 Napisano Februar 26, 2015 Aceton rastvara akril. Tacka. ( Ostavi malo vremena da deluje.) Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Februar 26, 2015 Share #1490 Napisano Februar 26, 2015 optički akril ne. jedino da ti pošaljem pa eksperimentiši do mile volje. ja znam šta sam im sve radio i tvrdim, a ako je potrebno tebi da kreiraš "tačka" iskustvo, samo kaži Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Februar 27, 2015 Share #1491 Napisano Februar 27, 2015 danas je tasovac bio kod frizera, malo je urednije.. inače rack stoji ovako a ne položeno sablasna boja papirne podloge je od UV lampe prophet je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
John Coltrane Napisano Februar 28, 2015 Share #1492 Napisano Februar 28, 2015 Kakav bre Tasovac ovo je frizura Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Mart 1, 2015 Share #1493 Napisano Mart 1, 2015 ko ćuti taj ne pravi adapter. naravoučenije: nikad ne ispunjavati muzićke želje, od 1 postane album. Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Mart 1, 2015 Share #1494 Napisano Mart 1, 2015 e, danas je na red došla prednja ploča... metalni dugmići su samo pozeri, nemam trenutno "prave plastične" za 6,3mm fi. prophet je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Mart 8, 2015 Share #1495 Napisano Mart 8, 2015 ispala prednja žešći tasovac a bogami i ladnjaci probani kako stoje Link to comment Podeli na ovim sajtovima More sharing options...
guja011 Napisano Mart 8, 2015 Share #1496 Napisano Mart 8, 2015 malo mrdnja bakra po ladnjacima i ostalih delova "dal će da stane" Fukushima je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
