ZZZ
Sve objavljeno od ZZZ
  1. Ma kakav prilozeni link - posmatraj iz ugla zdrave logike Sto je veca vrednost potenciometra to je veci R serijski sa paralelnim kapacitivnim opterecenjem. Kada jer BILO KOJI pot pri 0 skoro sva njegova vrednost je cinioc RC konstante... Max vrednost pota se i IZRACUNAVA na osnovu podatka o narednim kapacitivnostima da bi se postigla zelejna granica opsega. Proveri i u bilo kom simulatoru, i videces da je tacno ovo sto sam napisao. Ustvari prepisao iz manuala clanaka i udzbenika... I nemojte da saljete i da pisete elementarne gluposti i da o netacnim stvarima razglabate, do u besvest...
  2. ZZZ
    P.audio horne
    Za svetliji furnir da ne bi pozuteo koriste se izbeljivaci za drvo. Tu informaciju sam dobio od coveka koji je radio u drvno preradjivackoj skoli. E sada koji su to izbeljivaci i gde se nabavljaju nemam pojma. Jedan poznanik pre dosta godina je radio i sa obicnim hidrogenom posle je koristio neki UV lak i dobio super rezultate.
  3. And how Your design look a like? Is there any sense, relationships, or it is totaly arbitary without any design at all? At least they, slovenans, dont hide natural, true wood. Tremendous amount of handy work does not guaranties the well soud. The goal is to impress the potential buyer at the first second and sell as soon as possible. Your "design" is wrong, your measurements with a water is wrong, that is not the real volume drivers deserves. with these numerous chambers you divide total volumes into milion small chambers. every one have own center of mass. these center of masses are farr from each other and form much smaller volume driver can see than measure simple volume. But You are unable to understand this. That is all try to find on this forum measurements and resuls that one member did with and without chambers. He cut out "bracing" and report.... cheers
  4. ZZZ
    RCA LC1 kabineti
    Ne vidim zasto smeta da se nazire i spolja poznata konstrukcija... . A mislim da se nema potrebe ni prikrivati prirodne materijale. To se radi sa ivericomi i medijapanom... Ima jos jedna stvar imao sam samo 3 elektricne masine ubodnu pilu i busilicu. Kao i odvrtac na baterije. Keksericu me mrzelo da kupujem za 2 kabineta u 5 godina... Nisam imao ni stege. Mogao sam pozajmiti dugacke stege ali mrzelo me je da pranosim vecu kolicinu stega posto su 4 kabineta u pitanju. I poterbno je uraditi operciju u jednom danu a ne razvlaciti sto godina...
  5. ZZZ
    RCA LC1 kabineti
    Da to moze kada je drvo tvrdje od tipla. Pa onda smirglanjem poravna. I to je super ako je potrebno da se zameni daska i da se odstafi sraf ispod tog tipla. Medjutoa ovde je sperka mekana a tipl tvrdji. Probao sam sve. ovo mi je najbolje i najbrze. Nema nikakvog smirglanja, sve legne na 0...
  6. ZZZ
    RCA LC1 kabineti
    procedura za tiplovanje: tipl se namaze malo manje od polovine lepkom, tanak sloj. Najbolje ga je rolati po lepku. Ova piljevina od razbusivanja rupa se ne cisti. tipl se skuca ravnim cekicem ili izmedju cekica i tipla tvrdo ravno parce drveta. zakuca se do linije spera. Visak lepka se pokupi piljevinom. posle ide blago smirglanje. Sve bude idealno ravno. Sipke tiplova se veoma jako spoje trakom u cvrsti snop. obelezi se duzina i napravi prsten od kartona koji se pomera. Onda se sece ubodnom testerom po ivici kartona. Jako precizno se iseku tiplovi na ovaj nacin... Neuporedivo bolje deluje ngo srafovi ili gitovane rupe, a u ovom slucaju je povrsina sperke jako ravna i nije uopste cupava, pa se ne mora uopste mnogo smirglati. Mislim da nema potrebe furnirati.
  7. ZZZ
    RCA LC1 kabineti
    Malo kasnim, evo nekih fotki od juce i prekjuce :). Tiplovanje trajalo celo popodne, tri operacije povaditi zalepljene srafove, razbusivanje rupa, lepljenje i zakivanje tiplova smirglanje...
  8. ZZZ
    P.audio horne
    Vidim da se razumes u te materijale. Da li ima neki UV lak koji sprecava da svelije drvo (sperke) pozute tokom vremena? Da li je to karbon platno tanko? Mislim da je clan foruma od toga pravio membrane i fenomenalno su ispale. Ali nije bio jednostavan tehnoloski postupak. Nemam pojam mislim da su bile u pitanju neke male tolerancije temperture tako nesto...
  9. Pa uvek "precizno" iseku, cak i na orizontalnim cnc masinama... Smirglanje ne gine.
  10. ZZZ
    P.audio horne
    Svaka cast Dacho Dobro izgleda. A i izrada je prva klasa nema sta...
  11. izvini ali vidim u naslovu oglasa pise - nekorisceno? Da li to znaci da drivere ti nisi koristio, ili nisu uopste upotrebljavani ili nesto trece? Zbog cega postoji potreba da se za ocigledno stare i veoma upotrebljavane PA drivere u naslovu teme napise nekorisceno? Nemoj odgovarati na ova pitanja please, na kraju recenica je znak pitanja samo zbog sintakse...
  12. ZZZ
    RCA LC1 kabineti
    Evo jos malo fotografija. Upornice isrezane i napasovane. Sledi lepljenje.
  13. ZZZ
    RCA LC1 kabineti
    Izdrzala bi ali je ovako manje elemenata i montaze. Samo se lepo izreze, posto se sklopi ceo kabinet
  14. ZZZ
    RCA LC1 kabineti
    Da, pa nije moguce montirati sa unutrasnje strane nista kada se kabineti zalepe...
  15. ZZZ
    RCA LC1 kabineti
    Port ide na plocu, to je ista ona izrazana za ARU480 jedinice i to je ploca 37x25cm. Tako da moze i da se izmeni. Driveri su na sopstvenim nosecim plocama pa se samo ubace u leziste. Sve je zamenjlivo.
  16. ZZZ
    RCA LC1 kabineti
  17. ZZZ
    RCA LC1 kabineti
    Bice valda mesto i u "slusalistu" nije zr daleko?
  18. ZZZ
    RCA LC1 kabineti
    Ovo mi dodje kao "vagina smoke", pre ovoga sam zavrsio dva velika crteza 3 x 2 m... E to slama volju. A bila je paklena vrucina u prostoriji posto skoro da ne mogu da se otvore stari zaribali prozori. Bio sam non stop skroz mokar. Potrosio ceo stok specijalnih olovaka (2 funte komad, ima samo jedna firma na svetu koja mi odgovara i drvo i srce). Da sam imao odmah jos za jedan crtez ove kabinete ne bih ni radio...
  19. ZZZ
    RCA LC1 kabineti
    Iskustvo cini svoje. (ne toliko u ovom domenu vec u drugim stvarima). Recimo ovde sam posle svake operacije (secenje, smirglanje itd) cistio pinjevinu i ostatke. I mnogo bolje se radi, brze i efikasnije. Ima tu jos drugih fora, ali mislim da je ovde bilo presudno odlicno prirodno svetlo. Bukvalno sam radio od oko 10-11h pa do 17-19h. Duze ne mogu da stojim a i ogladnim...
  20. ZZZ
    RCA LC1 kabineti
    Nista bez sablona... Evo jos malo fotografija. Zavrsio skoro sve pojedinacne elemente sa sva 4 kabineta. Ostavio sam mogucnost da se doda Acousticaly Resistance Unit. (Samo ovaj ARU je veci za 15ina driver 37 x 25cm). Posto se u praksi pokazala izuzetno dobro. Umesto porta koji ce ici kao prva verzija, samo se promeni nosac porta... Sklopio sam 2 komada, bez leplenja, tek da vidim kako pasuju elementi. I sve je OK Sklopicu i zasrafiti sva 4 pa onda jednu po jednu stranicu odsrafljivati i lepiti.
  21. ZZZ
    Woland
    To je zbog toga sto su fabricki dacovi jako pre-pojacani. Skoro svi bez razlike. Utrkuju se koji ce imati veci naponski izlaz... Kao i kod skandiranja ko je jaci taj je bolji... Probaj sa nekim standardnijimizvorom pa ces videti da ces koristiti i te druge polozaje?
  22. ZZZ
    RCA LC1 kabineti
    Zovu ga baltic sper a ruski posto je iz rusije i odlican je. Sa nim sam radio one eksperimentalne kabinete. I to je skup manih delova koje mogu sam pomerati i njima manipulisat. Ovo su nesto veci kabineti i nnjih ne bih mogao podizati i okretati bez naprezanja. A vec sam pravio iste sa topolovim sperom i stvarno je i vise nego OK. Usudjujem se da kazem da je mozda i bolji od brezovog spera. Evo zbog cega mislim da je sasvim OK za kabinete manje snage. Nema samo jednu rezonucu frekvenciju ili uzak spektar opsega vec se cuje skoro kompletan opseg. (naravno jako prigusen). Presudile su u mom slucaju dimenzije tabli koje su bile dostupne, a kojih je bilo potrebno svega 4 komada (inace 5 tabli), masa koja je manja (zbog toga sto ja to sam moram tegliti i tovariti). I kao treci razlog to sto sam vec imao neposrednih iskustava bas sa tim materijalom i tim driverima.
  23. ZZZ
    Woland
    Pogledajte sklopove recenica ranijih novinara i ovih danas - sve je jasno...
  24. ZZZ
    Woland
    Babic nije bio plejboj sigurno. Osnovna karakteristika plejboja je da nema profesiju. Uz to ide i mentalitet skorojevica, (pogledati resentiman od Selera...) kao jedna od osnovnih karakternih crta. Posto biti plejboj nije profesija za razliku od prostitucije. U tom smislu ni kazanova nije bio plejboj posto je bio strastveni matematicar kao i postovalac umetnosti. Recimo Kazanova je osmislio, proracunao verovatnoce i organizovao venecijansku lutriju. Babic je imao profesiju kojoj je bio predan. Iz toga je i proizilazio njegov integritet kao i kriticko misljenje. To sto je bio dobrog fizickog izgleda, i razvijenih socijalnih osobina je sekundarno...
  25. ZZZ
    RCA LC1 kabineti
    Tesko se upusta konus u sper ako nije prethodno lakiran. Redovno para ivice i rubove konusa. Cepa prbi sloj sperke. Sigurno. Narocito na meksem topolovom speru a i hoce u manjij meri i na tvrdjem brezovom. Kao i na bukovom speru. Ovo je sigurno posto sam proverio u praksi Relativno lako se vade masinom i dobrim nastavkom. Ravno iseceni i skucani ranom daskom, stvarno brzo ide. I nema dalje obrade. Mozda malo smirglanja. Radio sam to vec na onim eksperimentalnim kabinetima. I super je ispalo.
  • Trenutno na sajtu   1 član, 0 Skrivenih, 2320 Gosta (Pogledaj celu listu)
