5307 -
42
Sve objavljeno od ZZZ
Danke (Bilo bi super kada bi ostala ova boja - ali nece... Pozutece vremenom)
Harbeth C7ES-3, Magnum MP150/MF125, Dayens i ostale fifi trice
ZZZ je odgovorio/la crni.'s temus u Galerija sistema
ProAc stereo 100w 1980 ProAc 3 Channel 100W Magnum A100, 400W 1982 Magnum A200 Magnum Pre-amps IncaTech Gold Plated Power Plus and Sockets 1982 Inca Tech Sabre iss 1 1983 Inca Tech Prelude Inca Tech Claymore 1 1983 Inca Tech Claymore Gold Inca Tech Claymore S Inca Tech Claymore 2 Inca Tech Quatra Inca Tech FMT Tuner Inca Tech IT50,IT100,IT200 Inca Tech IT1P preamp Inca Tech Sabre iss 2 Inca Tech Dirk Inca Design ID25,ID50,ID75 Inca Tech MSB (a monster) Inca Design Oberon Classic Inca Design Oberon (standard) Lescon Quatra Oxford Acoustic's "Mystic" TOCA SECA 20W,50W,100W,200W,300W single ended class A,s 1995 TOCA I75 TOCA Pre A TOCA 75W Tellurium Q Cables 2009 Tellurium Q, A Class 20W, 100W 2011 Tellurium Q Headphone/Phono Amp Tellurium Q Pre-Amp EWA (Elsdon Wonfor Audio) A complete range of new designs after yet another twit full of greed stole by waiting for me to become very ill yet another company from my original company called Catch 22 then it became Tellurium Q. EWA have cables, Power Amps, Pr-Amps, SECA Amps. Read on:-http://seca.freeforums.net/ https://www.elsdonwonforaudio.com/ Products worked on Naim Nait 5i, other bits also for Naim and Cambridge Audio. 2008- 2010 Hi I am interested in Your first designs Would You be kind and share these 3 circuits? Pushpull 1 Germanium Amp 1971 V1 Tube amp 1972 12W Single Ended A Class 1974 thanks -
Hvala, ALI to ipak nije rad majstora, nego neka vrsta OTO-a Nije mi bila namera a nije ni bilo moguce da to izgleda i bude uradjeno onako kako bi to neki profesionalac u tom domenu izveo. DIY sistem uz pomoc lokalnih radnjica materijala. Da podsetim, sve uradjeno bez stega, od masina samo busilica, ubodna pila, baterijski odvijac. I neizbezna hrpa sablona. Ako neko hoce da skenira 1:1 u fotokopirnici neka se javi posto uskoro bacam. Ovih mera nema i nema sablona za cut/oute za ove drivere. Sve sam rucno skidao...
evo jednog dobrog gledao ga zamislite u bioskopu,... ali pre mnogo godina. http://www.imdb.com/title/tt0269329/?ref_=nv_sr_1
Da Da vracar pardon, bas tamo... Pomesao sam te silne BG lokalne samoupravne jedinice... Imaju ali sve bofl standard... Kad nema bolje i to je OK Jebes sraf izvlacen na presu. Pravi se narezuju navoji. To ide u maticu samo tako - masno i bez ikakvog zazora ovi kineski, turski sta su sve klimavo...
Pa ja to skuplam cetvrt veka... pre bih rekao spora pravda
Te crne rucne matice da ih tako nazovem, sam kupio u prodavnici srafova preko puta opstine stari grad i kalenica pijace. Ali nisu ni za kakvo dugme, samo za ove namene. Matice se ne izvlace i solidno su zalivene unutra. Nisam bas zavrtao preterano nego vrlo cvrsto. Ali jednostavno izrada je losa, ekscenricni su i matice cesto nisu ok pa je potrebno proveriti svaki primerak zavrtanje m na sraf na licu mesta. Da ne bi isli 2 puta kao ja, od 16 kom 5 sam morao zameniti.
Platno kupio u prodavnici metraze u zemunu kod pijace u Prvomajskoj. Ali ne moze samo to platno. Jako je mekano. Postavio sam aluminijumsku mrezicu ispod platna kao ojacanje. Isto kao i na onim eksperimentalnim kabinetima.
Ne moze. To su dugmad sa ugradjenom maticom unitra. Kupljeno u prodavnici srafovske robe. Lose izgledaju uzivo. Losa plastika. Jedino je oblik dobar, a izrada - morao sam juce da idem da zamenim 5 komada, zbog losih matica. Mislim ovde za ovu namenu je OK. Ali nije za pot kojem se konstantno prilazi i koji se dodiruje. Tu moraju oni lepi vintage bakelitni.
Jeste to je uobicajeno za cevne ampove. Ali meni je za sada Quad II tu odlican. Bukvalni ih kida. Doduse ima stvarno, kvalitetan izlazni trafo a i povretnu spregu pa kompenzuje to sa damping faktorom. A slusao sam te drivere u tom kabinetu ranije sa 2A3 gde je moj drugar namotao izlazne trafoe. Bukvaln je otkinuo. Daje onaj infra bas. Planiram naravno i jedan diy ali SE amp. Namotao sam svojevremeno jako kvalitetan OT za 2A3. Naravno moze da se doda na izlaz ampa jedan 1:1 transformator, sa jako debelom zicom u sekudaru i na velikom telu. Bez procepa posto tu ne protice jednosmerna komponenta kao na OTu. I to je pravo resenje. Ispronao sam jednom prilikom to sa nekim velikim 1:1 mreznim trafoom i neverovatan je bio ucinak
Mislio sa kasnije eventualno da probam Tesla ARO 15in alnico. Posto imam 4 komada kompletno repariranih. za nijansu veca Fs oko 22Hz ostali parametri slicni i nesto nepovoljniji ali u principu moze. I takodje Western Electric 2080E. Sve 16 oma jedinice, kako i RCA LC1 pa idu u praleli po kanalu na 8 oma...
Konektore sam prvo mislio da postavim ispod maske, ali stvarno ne mogu vise da pasujem, smirglam i doterujem. Stavio sam ih preko maske, ustvari kroz masku i nosecu plocu. Tako da sada maka ne moze da se skine a da se prethodno ne skidaju konektori. I rucke nisam mogao da nadjem a da mi odgovaraju po izgledu, bolji i ceni. Ali sasvim lepo moze da se driver ubaci i bez rucica. Isprobao sam bezbedno i lako. A necu skidati maske ni vaditi drivere svaki cas... Ne moze se sve izvesti...
Ovako koncipitan tip kabineta moze da primi i druge drivere. Naravno ako odgovaraju po TS paramertima i uz izmenu porta. Samo se zameni noseca ploca sa driverom E sad nije fi-fi posto konektori nisu iza zvucnika nego napred na nosecoj ploci
Pa to su neki old school konektori koje sam imao. tacno 8 komada. Veoma robusni, primaju standardnu bananicu, srafe se. Mislim da su neki americki. incna matica... Odlicnog materijala i izrade. Medjutim, po mom misljenju, nisu bas najbolji za audio, (izuzev za ch. gnd.) zbog tofa sto su jako debeli i premasivni. Ovaj metalni deo je oko 12mm precnika, a dugacak oko 25mm. Ovde su mi se fizicki jako dobro uklopili. Samo cu dodti neku tacku da obelezim vruci kraj
Bukvalno sve iz lokalne radnje. Jedino sam morao par puta ici po famozne srafove... Moram i sutra.
A danas sam napredovao ka kraju. Jos "samo" da zavrsim maske, montiram drivere na nosecu plocu, rascupam damping, i da nanesem 2 sloj laka i gotovo...
Da mislio jedno napisao drugo... mala vrednost pota u omima = veliko opterecenje za generator. Posledice su povecana izoblicenja, efekat kompresora, smanjen gain, itd Ali to je vec zadatak onog uredja i sklpa koji dolazi ispred predpojacala. A ti izvori uglavnom imaju buffere na izlazima koji su generaori sa malom impedansom Recimo ako se izracuna da je za preamp naulazu maximalna vrednost pota za -0.25db na 20KHz 22Koma, onda generator ispred recimo nije ose da ima oko 100 X manju unutrasnju impedansu. A to je oko 220 oma. Sto je recimo 1/S ECC88 cev sa oko 200 oma kao buffer, ili recimo oko 40oma sa 2SK170 JFET-om kao prethodnim bufferom.
I jos jedna netacna informacija koju plasiras je da impedansa zavisi od potenciometra. Ne impedansa je unutrasnja otpornost generatora (sklopa) koji je ispred potencioetra, a potenciometar je opterecenje tog generatora... Ako je premala vrednost pota u odnosu na Rgen generator ce imati malo opterecenje na izlazu pa nece moci pogoniti uspesno sklopove koji slede.
Trenutno na sajtu 1 član, 0 Skrivenih, 2320 Gosta (Pogledaj celu listu)
