2371 -
14
Postovi objavljeno od skrstic
To sam i napisao.
6BQ5 / EL84 / 6P14P
4 hours ago, Doktor said:
Ja tu razliku između pentodnog u odnosu na triodni mod ( na stranu duple razlike u snazi ) doživljavam upravo ovako kao je napisao član @Billm sa The Gear Page foruma ( forum za muzičare ).
https://www.thegearpage.net/board/index.php?threads/triode-vs-pentode-mode.647871/
" It's an inexpensive way for manufacturers to add a feature to an amp and to make a somewhat different tone available.
Your output tubes are typically pentodes, meaning that they have five elements inside (plate, cathode, control grid, screen grid, suppressor grid). Pentodes (and beam power tetrodes, such as the 6L6/6V6 family) are very efficient... as tubes go. The screen grid eliminates the capacitance between the plate and the control grid, which makes the tube more linear and controls electron flow more accurately, for more power.
Connecting the screen grid directly to the plate supply (same voltage as the plate) makes the tube function more like a triode, hence the name. It almost halves the maximum power, so people sometimes call it a half-power switch. The tube wastes power in triode mode.
At anything less than full volume, the difference between full and half power is not that noticeable. It definitely does not halve the loudness of the amp.
Triode mode on a pentode sounds thicker, mushier, less articulate. Some people think it sounds more bluesy; I think it just sounds sloppy, like the difference between sober and drunk. "Ono što sam ja slušao više volim tu lampu kao triodu od pentode. Naravno moje mišljenje i podrška ugrađivanju otpornika i prekidača.
Utakmicu slušam, učim C# i radim klincu domaći.
Kad mi dosadi odo da skroz poskidam jedan kanal pa da puštim tako. Ako ima bruma onda ću i trafo da skinem i da obrnem za 90 stepeni. Taman sam na odmoru. Zabava.
Kako li će biti s 4П1Л... za godinu/dve dok ne završim ovo čudo.
16 hours ago, Aleks said:
Probao direkno s pina. Isto. Sad ću jednu lampu da izbacim i da probam tako.
Edit: Probao i tako. Ima bruma. Ima na oba kanala.
@Aleks Znači ne sa pločice nego sa pina? OK. Probam na obe direkno s pina. Ako ima bruma jel dovoljno da ne stavim jednu lampu ili moram sve da rasturam? Jel sigurno zbog struje. Ipak je samo jedna lampa a predvieno je za dve.
Jel bitno koji od pinova 2 i 7 su + i 0?
Podigo potencijal grejanji i čini mi se da je malo jače brujanje. Znači nije pomoglo.
Vezano je na masu.
Brum ima veze sa okretanjem utikača. Jena strana manje bruji. Sugestije?
11 hours ago, guja011 said:
isto u smislu prvo uključenje i kasnije isključenje uključenje kada je hot
kad spavaš ne čitaj.
ukapirao sam. probaću dsnas pa javljam.
Grejanju nisam dizao potencijal. Večeras. Valjda.
jeste. nema veze sa pojačanjem.
1 hour ago, guja011 said:el to brujanje uvek isto?
da.
skinuo šant, opet isto. predpostavio sam. ovih dana rasturanje pa sve mase na jedan šraf ću da natakarim.
http://www.diyaudio.com/forums/tubes-valves/102352-6v6-line-preamp-334.html#post5381222
Baci pogled na drugu sliku. Tu je takođe s jednim šantom. Šant ima 2+ i 2mase. Kod mene su spojene pošto je jedan šant za obe lampe.
Probaću danas bez šanta, dodam još jedan otpornik i kond i taman.
Ovo je bio planirani sledeći korak. Sve u tačku. Regulator mora da ima ulaznu i izlaznu masu valjda. Ako ne povežem obe strane ima kratko da radi a mrzi me novi šant da pravim.
Nisi povezo na masu otpornike sa izlaznih kondova i da konda koji se ne vidi ova bela oz rupe. Sutra ću da prebrojim koliko tačmo ima vodova do mase.
Kutilu radio drugar Sale. Uživo još lepše. Daska iz Uradi sam, neko Afričko drvo za terase, bazene, saune...
Pustio malopre i ima 50Hz brum. Kreće sa više hercaže pa se smiri.
Uopšte nisam zadovoljan rasporedom, ožičenjem. Šta ću. Par nedelja pokušavam da uradim ono za šta je dovoljno popodne. Valjda ću danas i da uključim. PP aparat spreman . Onda rasturanje i stavljanje pota, selektora i prekidača. Valjda ću i IEC sa osiguračem da stavim. Poklopac za trafo, zavojnicu i kond takođe treba da napravim. Mnogo mi se oduži.
7 minutes ago, Srecko said:
Potpuno sam saglasan jer sam kao sto rekoste i ja čovek a ne mašina sa svim manama i vrlinama (isti, možda i gori, kao i najveći broj članova foruma ) pa zbog toga i “nesposoban” da kontrolišem telesnu masu (igram tenis nekoliko puta nedeljno i dalje u veoma jakom tempu; no nisam smanjio obroke-mozak ).
Nažalost (na sreću moj senzibilitet i ljudskost-slabosti ) ne mogu dovesti u pitanje racio i nauku.
Moj ti je savet da se uobročiš. Meni je doručak oko 9, ručak oko 13 i večera oko 19. Budi uporan i videćeš rezultate. Ovo iz ličnog iskustva.
38 minutes ago, vladd said:1 hour ago, skrstic said:
Ima dosta dobro ocenjenih zvučnika
To smo naucili da je zona prevare. Mislis ocenjeni po audiofilskoj stampi, ocenjeni od fensera, ocenjeni od pozera, ocenjeni u zamenu za novac....ili ocenjeni od nekoga ko nije sve to, ali je pod pritiskom trgovaca, bakalina, hipstera?
Ima naduvavanja, prodavanja magle... ali nisam mislio o tome nego brate obični ljudi kupovali i bili zadovoljni.
Krajnji cilj ove igrarije je subjektivno uživanje u muzici i džaba perfektna merenja, grafovi, magla sa svih strana ako mi se ne sviđa onda mi se ne sviđa i. Za one koji neće da pamte da ponovim
1 hour ago, NIXIE said:Nikad nisam sporio svrhu merenja, osciloskopa i sl.
30 minutes ago, Srecko said:
Moram reci da ne delim Vaše mišljenje. Ja npr. imam visak kilograma upravo zahvaljujući mom mozgu koji mi diriguje apetitom.
Da li je u redu taj moj visak kilograma (koji moj mozak očito čini srećnim čim mi ne dozvoljava da unesem normalan broj kalorija za moj nivo aktivnosti a koji je lako izračunati i merenjem korigovati)? Naravno da nije i to po bilo kom osnovu: zdravstvenom, izgledu pa ako hoćete i “uspehu” kod suprotnog pola . Znaci ja bih trebalo pod hitno da omrsam a neki da se bar upitaju šta se dešava sa njihovim čulima i mozgom kada ono sto vole se “toliko” razlikuje od: izračunatom, izmerenog .... Nešto što se nekome sviđa ne mora da znaci da je i dobro (znate ono “Sve sto mi se dopada ili goji, ili je kažnjivo ....”).
Naučni postulati, matematički aksiomi se ne mogu dovoditi u pitanje poput npr. da je 2+2=4 zarad toga da bismo bili različiti a ne “jednoumni”.
Na forumima (pa i ovom) se inače pojam jednoumlja često redefiniše, naravno pogrešno.
A da li sam nešto drugačije reko? I ja sam još uvek debeo, i sam sam svestan svega. Slažem se da su naučni postulati postulati dok se ne dokaže suprotno i da je 2+2=4. Ali pitaj statističare, pravnike pa će ti biti jasno. Pošto si, valjda, žderonja ko ja ista priča sa muzikom. Volim ljuto. Neko ne može ni pod razno. Stvar je u tome da poštujem a ovde malo malo neko provuče bezobrazno ili USB kabl ili osigurače. Osigurače nemam i nisam išo da čujem. USB sam bio ubeđen da je 0 i 1 ali kod prijatelja se razuverih da to baš ne pije vodu. To i napisah i postadoh vernik, neobrazovan, onaj kome se podvaljuje magla... ma pišu ljudi šta im volja. Nemam problema ni s tim ali do neke granice. Ja još uvek kući imam iste USB kablove i za sebe tvrdim da sam doživotni neozbiljni početnik.
Trenutno na sajtu 11 članova, 2 Skrivenih, 45 Gosta (Pogledaj celu listu)
Ukupan broj tema435.2k
https://www.audiosciencereview.com
in Digital
Za one koji vole merena.
