mutayu
Sve objavljeno od mutayu
  1. U prozorcicu Edit za vrednosti kondenzatora treba postaviti i odgovarajuci series resistance za primenjeni kondenzator. Evo ga i proracun impedanse trafoa iz PSUD2 help-a : Edit Transformer Properties Enter the voltage for the secondary of the transformer. Note that this must be the off-load voltage, which is generally higher than the rated voltage of the transformer. For full wave rectifiers, use the voltage for one side only. For example, if the transformer off load voltage is 350-0-350V (700V end to end), the correct value to enter is 350. Enter the source impedance of the transformer. If you don't know this, you can click on the [...] buttons to invoke the off load voltage calculator, or source impedance calculator respectively. Source Impedance Calculator The source impedance of the transformer is required in order to simulate the transformer "sagging" under load. Supply voltage: (VP) The voltage primary supply into the transformer, normally 110/115/220/230/240 volts. Winding resistance: (RP) The measured resistance of the primary winding. Off-load voltage: (VS) The measured voltage on the secondary of the transformer before any load is applied. Winding resistance: (RS) The measured resistance of the secondary winding. Resistance for simulation: R.equiv = ((VS/VP) x RP) + RS
  2. Stara Ei Melodija je postala RH84. Doduse sa switcherskim napajanjem i regulatorima pa susti kao luda. RH.jpg.heic
  3. Krco, samolepljivi bitumen ce da ti se topi vremenom pa ce trafo da ti "potone" kroz njega.
  4. Za ovu robu treba pratiti i "Temu". Cene su obicno akcijske a shipping je free.
  5. mutayu
    DIY fluks pasta
    Lakiranje rastvorom kalafonijuma moze elegantno da se uradi airbrushem, najbolje vecim- suction feed tipom. Moze i da se upotrebi Izopropanol, bezbedniji je od nitro razredjivaca a dostupan je za kupovinu na litar u poslednje vreme.
  6. Javi kako se zavrsila ta akcija u Kljucu! Ovo u Sokolu je izgleda bila neka improvizacija. Nekada su imali odliicne farbare,tehnologiju i prajmere, antikorozivnu zastitu i zavrsne boje ali izgleda da nije ostalo nista od toga.
  7. Budi oprezan sa Gyurgyevcima! Moze da ti se desi da prestanes da pravis druge ili bolje zvucnike 😁
  8. Ja tek sad vidim sta je sve nestalo od slika a da ja to nemam sacuvano 😦 Prava mala katastrofa. Zene moracu da ti dosadjujem oko sema za Iskra lampase i Quad 405 mod...
  9. Sad cu da vidim...
  10. Kako rekoh u naslovu: -dva univerzalna daljinca sa prijemnim modulima, ja ih namenio za Sony PS1 cd player. -maleni DAC -opticki toslink kablic 1,5m Ostalo visak od raznih eksperimenata, ispravno, citavo, neupotrebljavano ili sasmim malo upotrebljavano. Prodajem da prodam, cena recimo 500 dinara za sve, moze i zamena za delove. Najbolje licno preuzimanje u bloku 70 ali mogu i da posaljem postom. Ako je nekome hitno i neophodno moze i kao poklon uz licno preuzimanje.
  11. Naidjoh na podatak da je "autoignition temperature" za Ikea particle boards oko 200 stepeni C.
  12. Ne znam da uradim u ovom trenutku ali mogu da ukazem da je relativno lak put konverzija JPG u GBR.
  13. Boze, kak je plavi!
  14. Da ne bi prefarbavao mozes to elegantno da ispravis nalepnicom na vodolepivom dekal papiru. Crna laser stampa, beli dekal papir. Bele ivice prodjes Sharpijem.
  15. Hvala! To bi vec bila gradnja novog Quada.
  16. Ostao je da me kopka jedan detalj. Moze li se Maxwell-Wien most dovesti jako blizu balansu postavljanjem trimera vezanog kao potenciometar na poziciju R38 i onda njegovim finim podesavanjem AC napon izmedju tacaka zeleno 1 i 2 dovesti na nulu (uz doveden neki signal na ulaz i vezano opterecenje na izlaze i mereno multimetrom)? Pretpostavljam da bi se moglo pratiti i na osciloskopu ali ne znam kakvo pokazivanje da ocekujem.
  17. Ja uradio i zavrsio. Sad slusam. Moj je 405-2 (12565 iss.7 PCBs) pa je bilo lako ispratiti dokumentaciju i seme. Nece da uploaduje slike.
  18. Sorry sto vaskrsavam staru (ali dragu i aktuelnu) temu. @Zen Modna slikama se vidi da je na poziciji R44 postavljeno dva paralelna otpornika (po jedan sa obe strane PCB). Ne vidim jasno boje pa nisam siguran koje su vrednosti otpornici. Po semi je R44 otpornik 75R. O cemu se zapravo radi? Slusao sam desetak dana svoj novonabavljeni Quad i onda mi djavo nije dao mira, iscitao tekstove Snooka i Ludwiga, izucio Zenove modifikacije Quada i uzeo i modifikovao plocice. Uradio sve prema Zenovoj semi i dodatno premestio C8 na emiter Tr2. Sad ide dorada napajanja, povezivanje i proba.
  19. Dodjoh do finog primerka P.J.Walkerovog uratka! Neki dobri ljudi u Novom Sadu su mu prilagodili ulaze i izlaze za upotrebu u studiju pa sad cackam oko toga ne bih li ga sto pre cuo kod mene.
  20. Urezivao sa M3, prilicno duboke slepe navoje (oko 3cm) u ploci debljine 10mm. Hladio sa WD40. Uradio bez problema.
  21. mutayu
    M3 šrafovi...
    Radnja se zove M2.
  22. Saljem ti link u poruci, da ne reklamiram. Termin za pretragu na ebay je: "Speaker Protection Board Audio Amplifier Boot Delay DC Protect Component". Meni je poslao sa free shippingom a sad je postavio cenu 0,99$ za shipping.
