Mikorist
Sve objavljeno od Mikorist
  1. Koja to aplikacija zahteva striktno staticku adresu ? Imate WEB server ? IP kamere ?
  2. CPU scaling governor je na perfomance miko@miko:~ $ cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor performance performance performance performance performance performance performance performance miko@miko:~ $ $ grep swap /etc/sysctl.conf vm.swappiness = 10 miko@miko:~ $ swappiness je na 10%
  3. A ovako su podeseni IRQs za onaj DAC USB i ALC hda codec USB port xhci_hcd with IRQ 30 does not share its IRQ. USB port xhci_hcd with IRQ 32 does not share its IRQ. Soundcard snd_hda_intel:card0 with IRQ 33 does not share its IRQ. Soundcard snd_hda_intel:card1 with IRQ 34 does not share its IRQ.
  4. miko@miko:~ $ grep irq /etc/default/grub GRUB_CMDLINE_LINUX_DEFAULT="quiet iommu=soft mitigations=off threadirqs splash" miko@miko:~ $ grep NO_HZ /boot/config-6.0.0-10.1-liquorix-amd64 CONFIG_NO_HZ_COMMON=y CONFIG_NO_HZ_IDLE=y # CONFIG_NO_HZ_FULL is not set # CONFIG_NO_HZ is not set miko@miko:~ $ grep noatime /etc/fstab UUID=f1f947c8-da79-494b-aed6-785d48522abd / ext4 discard,noatime 1 1 UUID=ec53ea3d-267a-45cc-bf08-e425d5b3c7e1 /home ext4 discard,noatime 1 2 UUID=95F5-0D86 /boot/efi vfat noatime,dmask=0002,fmask=0113 0 0 miko@miko:~ $ sudo cat /proc/timer_list Timer List Version: v0.9 HRTIMER_MAX_CLOCK_BASES: 8 now at 14125999003449 nsecs cpu: 0 clock 0: .base: 0000000060acd70a .index: 0 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <000000008d9165ca>, tick_sched_timer, S:01 # expires at 14125999252250-14125999252250 nsecs [in 248801 to 248801 nsecs] #1: <0000000056918a32>, hrtick, S:01 # expires at 14125999562309-14125999562309 nsecs [in 558860 to 558860 nsecs] #2: <000000009891ea5c>, hrtimer_wakeup, S:01 # expires at 14126000000275-14126000893616 nsecs [in 996826 to 1890167 nsecs] #3: <00000000a50d065f>, hrtimer_wakeup, S:01 # expires at 14126246670528-14126247670297 nsecs [in 247667079 to 248666848 nsecs] #4: <00000000fe61dc49>, hrtimer_wakeup, S:01 # expires at 14126504585649-14126505105648 nsecs [in 505582200 to 506102199 nsecs] #5: <00000000c02b8651>, hrtimer_wakeup, S:01 # expires at 14126619614659-14126620613658 nsecs [in 620611210 to 621610209 nsecs] #6: <000000003040ec4d>, hrtimer_wakeup, S:01 # expires at 14126836532134-14126836582134 nsecs [in 837528685 to 837578685 nsecs] #7: <00000000a215aec1>, hrtimer_wakeup, S:01 # expires at 14126839754630-14126839804630 nsecs [in 840751181 to 840801181 nsecs] #8: <00000000c874e835>, hrtimer_wakeup, S:01 # expires at 14127000300318-14127004296317 nsecs [in 1001296869 to 1005292868 nsecs] #9: <00000000df4d4887>, hrtimer_wakeup, S:01 # expires at 14127941398376-14127943398375 nsecs [in 1942394927 to 1944394926 nsecs] #10: <00000000b659340a>, hrtimer_wakeup, S:01 # expires at 14128620306948-14128624302947 nsecs [in 2621303499 to 2625299498 nsecs] #11: <0000000046329190>, hrtimer_wakeup, S:01 # expires at 14129000416429-14129050206427 nsecs [in 3001412980 to 3051202978 nsecs] #12: <000000002d8cc090>, hrtimer_wakeup, S:01 # expires at 14130008674678-14130038682677 nsecs [in 4009671229 to 4039679228 nsecs] #13: <00000000435e4885>, hrtimer_wakeup, S:01 # expires at 14130436315636-14130441315635 nsecs [in 4437312187 to 4442312186 nsecs] #14: <000000007f9926de>, hrtimer_wakeup, S:01 # expires at 14133656001782-14133656051782 nsecs [in 7656998333 to 7657048333 nsecs] #15: <0000000007e344a0>, hrtimer_wakeup, S:01 # expires at 14136104013401-14136104063401 nsecs [in 10105009952 to 10105059952 nsecs] #16: <000000007df657fb>, hrtimer_wakeup, S:01 # expires at 14140257902569-14140257952569 nsecs [in 14258899120 to 14258949120 nsecs] #17: <000000004dc27bc2>, hrtimer_wakeup, S:01 # expires at 14140462273684-14140492273683 nsecs [in 14463270235 to 14493270234 nsecs] #18: <00000000cc04a95f>, hrtimer_wakeup, S:01 # expires at 14152457067926-14152487067925 nsecs [in 26458064477 to 26488064476 nsecs] #19: <0000000093fec01d>, hrtimer_wakeup, S:01 # expires at 14155570230451-14155570280451 nsecs [in 29571227002 to 29571277002 nsecs] #20: <000000004a63d8b8>, hrtimer_wakeup, S:01 # expires at 14157916176946-14157916226946 nsecs [in 31917173497 to 31917223497 nsecs] #21: <00000000442abebd>, hrtimer_wakeup, S:01 # expires at 14406541245662-14406541245662 nsecs [in 280542242213 to 280542242213 nsecs] #22: <00000000523d9142>, hrtimer_wakeup, S:01 # expires at 86408998931119-86409098931119 nsecs [in 72282999927670 to 72283099927670 nsecs] #23: <0000000010575e92>, hrtimer_wakeup, S:01 # expires at 99072000498747-99072100498747 nsecs [in 84946001495298 to 84946101495298 nsecs] #24: <000000000fe68944>, hrtimer_wakeup, S:01 # expires at 2148093466983124-2148093566983124 nsecs [in 2133967467979675 to 2133967567979675 nsecs] clock 1: .base: 000000000bff3270 .index: 1 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1676524038303812479 nsecs itd ponavlja se za sve nastavak... Tick Device: mode: 1 Per CPU device: 4 Clock Event Device: lapic-deadline max_delta_ns: 1296538872401 min_delta_ns: 1000 mult: 14227683 shift: 25 mode: 3 next_event: 14126834903539 nsecs set_next_event: lapic_next_deadline shutdown: lapic_timer_shutdown periodic: lapic_timer_set_periodic oneshot: lapic_timer_set_oneshot oneshot stopped: lapic_timer_shutdown event_handler: hrtimer_interrupt retries: 94 Wakeup Device: <NULL> Tick Device: mode: 1 Per CPU device: 5 Clock Event Device: lapic-deadline max_delta_ns: 1296538872401 min_delta_ns: 1000 mult: 14227683 shift: 25 mode: 3 next_event: 14140066478539 nsecs set_next_event: lapic_next_deadline shutdown: lapic_timer_shutdown periodic: lapic_timer_set_periodic oneshot: lapic_timer_set_oneshot oneshot stopped: lapic_timer_shutdown event_handler: hrtimer_interrupt retries: 1106 Wakeup Device: <NULL> Tick Device: mode: 1 Per CPU device: 6 Clock Event Device: lapic-deadline max_delta_ns: 1296538872401 min_delta_ns: 1000 mult: 14227683 shift: 25 mode: 3 next_event: 14126840015058 nsecs set_next_event: lapic_next_deadline shutdown: lapic_timer_shutdown periodic: lapic_timer_set_periodic oneshot: lapic_timer_set_oneshot oneshot stopped: lapic_timer_shutdown event_handler: hrtimer_interrupt retries: 147 Wakeup Device: <NULL> Tick Device: mode: 1 Per CPU device: 7 Clock Event Device: lapic-deadline max_delta_ns: 1296538872401 min_delta_ns: 1000 mult: 14227683 shift: 25 mode: 3 next_event: 14126000252250 nsecs set_next_event: lapic_next_deadline shutdown: lapic_timer_shutdown periodic: lapic_timer_set_periodic oneshot: lapic_timer_set_oneshot oneshot stopped: lapic_timer_shutdown event_handler: hrtimer_interrupt retries: 212 Wakeup Device: <NULL>
  5. apgrejdovat cu kernel na 6.1 stoji ovako podeseno CONFIG_NO_HZ_COMMON=y CONFIG_NO_HZ_IDLE=y # CONFIG_NO_HZ_FULL is not set # CONFIG_NO_HZ is not set
  6. Ovaj sitem mi je glavni sad - ovaj ko je ovo napravio je bogotac za audio Jako imam malo da doinstaliram i ispodesavam dodatno....finese neke. Ovaj ga je ubio......
  7. E ova podešavanja nema ni SnakeOil. Sva podešavanja sistema se vide iz menija i tajmeri i IRQs i sve A kad skockaš svoj sistem sa željenim programima i podešavanjima ima MX tool da se napravi svoj ISO - MX Save system to ISO - može da se podigne lajv - pa ponovo da se instalira - prenese na drugu mašinu - ili na istu kao backup celog sistema.
  8. Evo još jedan biser AV Linux MX Edition – bandshed.net WWW.BANDSHED.NET MX Linux Customized, Molded and Shaped for Content Creators.. The multimedia content-creation focus AV Linux has provided since 2008 is now combined with the powerful versatility of MX Linux! AV Li… Audio Linux zasnovan na MX Linux-u - sa liquorix RT kernelom AVL-MXE Features at a Glance ➔Based on MX Linux (powered by Debian/GNU Linux). ➔Available in amd64 architecture only. ➔Includes the phenomenal ‘MX Tools’ Utilities. ➔Custom-Themed XFCE4 Desktop Environment. ➔Extensive Audio/Video and Administrator-friendly Thunar Custom Actions. ➔Liquorix performance-tuned Kernel. ➔Tuned for best potential low-latency Audio performance (threaded IRQ’s, rtirq-init) ➔Seamless ALSA, JACK and PulseAudio integration through ‘Qjackctl’ and ‘pajackconnect’. ➔CPU Governor Set to ‘Performance’ by default. ➔Custom scripts and Utilities to simplify optimal System setup. ➔Fully supported and functional ‘bundled’ version of Ardour DAW. ➔Commercial Demo of Reaper DAW. ➔Commercial Demo of Harrison Mixbus32C. ➔Commercial Demos of selected Audio Plugins. ➔‘One-Click’ removal of all Demo-ware for those who would rather not have Commercial options. ➔Included Custom Packaging of Plugins not available in any other Repositories.
  9. Mikorist
    IT razno.
  10. Ako se može za one naponske kablove - Akasa je najmanji problem
  11. Ko neće da meri ništa kupi ko čovek dobar PC. Sve izmerili na tajvanu. Nema šta da menjaš na matičnoj sem OPA Dakle sve što je @vladd napisao za USB kabl i za AORUS matične je tačno. Sve što sam ga poslušao se isplatilo.
  12. Da li se isplati uložiti isto para u PC kao i u PCM63P DAC ? Isplati se. Svaki evro se čuje. A najviše napajanje i pasivno hlađenje. Znači napajanje se prvo kupuje. Da je Fanless da ima tolreanciju 2% na napone - i da je noiseless strujno. Da je sertifikovano na Cybenetics Labs – PSU Efficiency & Noise Level Certifications WWW.CYBENETICS.COM da ima sertifikovane RIPPLE MEASUREMENTS Kad slušaš muziku je oko 20% load. Ne isplati se praviti/kupovati uopšte linearno za PC kad ima ovo na tržištu.
  13. Ne moj da staviš za sad. Drži na dasci DAC dok @NIXIE ne izmeri njegov na dasci na osciloskopu
  14. Drugačije ni ne može kućište.Matična Ploča je king sajz. Deo za audio je 11cm dugačak pa pseban odeljak za DAC USB - jedno 5cm - Full ATX - 7 slotova.
  15. Mikorist
    Uvod
  16. jasam te dve wima od 33 paralelno sa Z Fil a te od 470p cuvas ako imaju glicevi...ja nisam imao pa nisam stavio
  17. Ovo nije normalno kako se podiže i radi kod mene. Znači za nano sekundu se digne sistem
  18. Zanimljiv mi sad ovaj Tiny Core - kao damn small linux - samo debian orjentisan. 11MB do 100MB sistem Ovo može da radi na digitron da instaliras
  19. 500MB zauzima u RAM - sve je u RT - komplet ceo sistem radi iz RAM.
  20. Ne. Rusi
  21. Tinycore sa RT kernelom...sve namešteno. UPnP/DLNA Renderer Ovo je bolje od SnakeOil
