Mikorist
Sve objavljeno od Mikorist
  1. git clone https://codeberg.org/rtcqs/rtcqs.git cd rtcqs ./src/rtcqs/rtcqs.py ... rtcqs - version 0.5.4 Root User ========= [ OK ] Not running as root. Audio/Realtime Group ==================== [ OK ] User diya is in the audio group. CPU Frequency Scaling ===================== [ OK ] The scaling governor of all CPUs is set at performance. Kernel Configuration ==================== [ OK ] Valid kernel configuration found. High Resolution Timers ====================== [ OK ] High resolution timers are enabled. Tickless Kernel =============== [ OK ] System is using a tickless kernel. Preempt RT ========== [ OK ] Kernel 6.1.12-3-liquorix-amd64 is using threaded IRQs. Spectre/Meltdown Mitigations ============================ [ OK ] Spectre/Meltdown mitigations are disabled. Be warned that this makes your system more vulnerable to Spectre/Meltdown attacks. RT Priorities ============= [ OK ] Realtime priorities can be set. Swappiness ========== [ OK ] Swappiness is set at 10. Filesystems =========== [ OK ] The following mounts can be used for audio purposes: / IRQs ==== [ OK ] USB port xhci_hcd with IRQ 30 does not share its IRQ. USB port xhci_hcd with IRQ 32 does not share its IRQ. Soundcard snd_hda_intel:card0 with IRQ 34 does not share its IRQ. Soundcard snd_hda_intel:card1 with IRQ 35 does not share its IRQ. Power Management ================ [ OK ] Power management can be controlled from user space. This enables DAWs like Ardour and Reaper to set CPU DMA latency which could help prevent xruns. Ide sve direkt u JlSounds -nema ništa između..... Ko misli da može bolje - neka namešta sam sebi.
  2. A najvise me fascinira dokle renderovanje fontova, ikonica moze da ide. Mozes da ubacis Windows fontove a renderovanje kao na MacOs <?xml version='1.0'?> <!DOCTYPE fontconfig SYSTEM 'fonts.dtd'> <fontconfig> <match target="font"> <edit mode="assign" name="rgba"> <const>rgb</const> </edit> </match> <match target="font"> <edit mode="assign" name="hinting"> <bool>false</bool> </edit> </match> <match target="font"> <edit mode="assign" name="hintstyle"> <const>hintslight</const> </edit> </match> <match target="font"> <edit mode="assign" name="antialias"> <bool>true</bool> </edit> </match> <match target="font"> <edit mode="assign" name="lcdfilter"> <const>lcddefault</const> </edit> </match> <dir>~/.fonts</dir> </fontconfig>
  3. Eto i to. Moze da ide Volume do 150% na ALSA
  4. Nema link javan. Mora da se logujes.....
  5. ama mogucnost mofifikacije svega - svaki atom sistema je otvoren . ovo je bruka sta moze sve da se izmeni. vizuelno takodje ovo sve vise lici na MacOs sto ja pravim Samo MacOS nema sve ovo . Nema ni Windows podesavanje suma sistema
  6. Nije besplatan.
  7. za par minuta
  8. prodato.
  9. Ant-Man and the Wasp: Quantumania (2023) - IMDb WWW.IMDB.COM Ant-Man and the Wasp: Quantumania: Directed by Peyton Reed. With Paul Rudd, Evangeline Lilly, Michael Douglas, Michelle Pfeiffer. Scott Lang and Hope Van Dyne, along with Hank Pym and Janet Van Dyne, explore the Quantum Realm, where they interact with strange creatures and embark on an adventure that goes beyond the limits of what they... Kako su usrali MCU....Znaci piece of shit
  10. veselje
  11. Pa bolje nego alumijium...To sad trpaju svugde
  12. Pa da bojler je keva
  13. Pa nista. Ima verzija da vezes na radijator hifi uredjaje.
  14. Svi uzemljivaci izvedeni od materijala koji nije potpuno otporan na koroziju su opasni na duzi rok. Najbolje je ko ima u temelju temejni uzemljivac. Video sam i uzemljivace sa aluminijumskim cevima. Aluminijum je praktično vecan u zemlji, ne korodira.
  15. Moj cale pokojni je to radio na sledeci nacin. Ode na otpad - kupi dva stara bojlera *(samo kazane ) - napuni peskom oba i zalije sa vodom. Iskopa rupu za njih na 4 metra dubine - veze kabletine za uzemljenje za oba bojlera....Pa njih nazad na kucu. Zatrpa sve zenljom i onda naliva vodu na tu zemlju. Nema sum da cujes tu sa tolikom dodirnom povrsinom uzemljivaca. Ali jbg ja to ne mogu u soliteru u BG.
  16. Desilo mi se jednom da sam pokrenuo FAI - dok sam otisao do klonje ponovo se reboot racunar i ponovo izgazio ceo hard . Sve dok je u USB ima da formatira i gazi sve i instalira Linux
  17. A za ove Lemice ima Faime FAI.me - build your own custom ISO FAI-PROJECT.ORG Ovo gazi sve na prvome disku bez pitanja i instalira Samo treba da zna da ubaci flash u USB Evo ga UBUNTU FAI https://fai-project.org/fai-cd/faicd64-ubuntu-only_5.10.3.iso Prebacis na USB - gazi sve Evo skrinshotovi kako izgleda Fully Automatic Installation - Slideshow FAI-PROJECT.ORG posle samo SnakeOil instalira
  18. to bi napravio za 10 minuta - no GUI Za to i ne treba ISO...okacis bash skriptu na github koja instalira iz konzole sve ono gore sto njima treba
  19. moram da upotrebim /etc/ jer se /home/ gazi prilikom instalacije - kreira nov user - itd... trenutno nemam config nigde jos nisam prebacio iz /usr/share/pipewire
  20. Direktno kroz plejer. Ali ja ocu Browser da mi svira isto kao plejer.......tako da nije visak. Meni ne treba OS da odaklegod startujes/pokrenes neki audio format radi. Recimo D10s iz ALSA ["node.nick"] = "Topping D10s", ["node.description"] = "Topping D10s", ["resample.quality"] = 4, ["resample.disable"] = false, ["channelmix.normalize"] = false, ["channelmix.mix-lfe"] = false, ["channelmix.upmix"] = true, ["channelmix.upmix-method"] = "psd", -- "none" or "simple" ["channelmix.lfe-cutoff"] = 150, ["channelmix.fc-cutoff"] = 12000, ["channelmix.rear-delay"] = 12.0, ["channelmix.stereo-widen"] = 0.0, ["channelmix.hilbert-taps"] = 0, ["channelmix.disable"] = false, ["audio.channels"] = 2, ["audio.format"] = "S32LE", ["audio.rate"] = 48000, ["audio.allowed-rates"] = "384000,352800,192000,176400,96000,88200,48000,44100", ["audio.position"] = "FL,FR", ["api.alsa.period-size"] = 256, ["api.alsa.period-num"] = 2, ["api.alsa.headroom"] = 1024, ["api.alsa.start-delay"] = 1024, ["api.alsa.disable-mmap"] = false, ["api.alsa.disable-batch"] = true, ["api.alsa.use-chmap"] = false, ["api.alsa.multirate"] = true, ["session.suspend-timeout-seconds"] = 0, ovo se prevodi u pipewire.conf: default.clock.rate = 48000 default.clock.allowed-rates = [ 44100 48000 88200 96000 176400 192000 352800 384000 ] default.clock.min-quantum = 1024 pipewire-pulse.conf pulse.min.req = 1024/48000 pulse.min.quantum = 1024/48000 Ovo ce da radi na svim spravama koje imaju ovaj XMOS ili slican. Znaci D30 D10 D50 - JLS USB Sve mi jedno dal je direkt ili nije. Isto svira.
  21. Ma jok . Neka se (m)uče....
  22. A kernel instaliras RT i krene da ti stuca zvuk kroz pipewire na sirovo .
  23. Kernel, napredna podesavanja. Da se izbaci pulseaudio - oslobodi ALSA - da sve prolazi kako treba. Nije sto su napredna nego ih ima strahovito mnogo. Ni Daphile ni AV - a ni Ubuntu Studio nisu podesavali sta sam ja u zadnja dva dana. Gledao sam sva tri kroz conf fajlove
  24. Dovoljno je otvoriti BIOS i gledati 20 minuta kako se menja frekfencija CPU na ovakvoj masini i na NUC. Koliko stabilno drzi frekfenciju - tj. klok. A Od njega zavisi sum sistema i DAC-a. Ne moze softver bez hardvera da radi - a i obrnuto. Sinergija je to. A odkad sam kupio i Kosmodisk ja vise problema nemam
