47005 -
661
Sve objavljeno od Mikorist
Nece nam trebati nista vise posle ovoga. Pajpovi i Xenmod su kraj price. Bar trenutno.
Ne ovaj sto je sad na Gugle Drajv - nego buduci sa pajpovima
Ama ide zvuk na Linux u potpuno drugom pravcu nego sto je sad. Sistem pajpova od kernela do USB prikljucka
Neka napise ponovo isto na drugoj temi..
default.clock.allowed-rates = [44100 48000 96000 192000] Bas suprotno radimo sad. Eliminisemo to. Ne moras da udjes u plejer da bi se klok menjkao - bilo koja aplikacija koja moze da pusta zvuk menja klok. sad je na 48K - druga pesma na youtube Sink Input #67 Driver: PipeWire Owner Module: n/a Client: 66 Sink: 49 Sample Specification: float32le 2ch 48000Hz Channel Map: front-left,front-right Format: pcm, format.sample_format = "\"float32le\"" format.rate = "48000" format.channels = "2" format.channel_map = "\"front-left,front-right\"" Corked: no Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Buffer Latency: 0 usec Sink Latency: 0 usec Resample method: PipeWire Properties: client.api = "pipewire-pulse" pulse.server.type = "unix" application.name = "Google Chrome" application.process.id = "1672" application.process.user = "diya" application.process.host = "diya" application.process.binary = "chrome" application.language = "en_US.UTF-8" window.x11.display = ":0.0" application.process.machine_id = "a729c56165d34535ae765ba31ee7e57c" application.process.session_id = "c1" application.icon_name = "google-chrome" media.name = "Playback" node.rate = "1/48000" node.latency = "1024/48000" stream.is-live = "true" node.name = "Google Chrome" node.autoconnect = "true" node.want-driver = "true" media.class = "Stream/Output/Audio" adapt.follower.spa-node = "" object.register = "false" factory.id = "6" clock.quantum-limit = "8192" factory.mode = "split" audio.adapt.follower = "" library.name = "audioconvert/libspa-audioconvert" client.id = "60" object.id = "61" object.serial = "67" pulse.attr.maxlength = "4194304" pulse.attr.tlength = "16384" pulse.attr.prebuf = "12296" pulse.attr.minreq = "4096" module-stream-restore.id = "sink-input-by-application-name:Google Chrome"
Klokovi se menjaju interaktivno...A jos nisam sabio na ovo Xenmod. Soon
diya@diya:~$ pactl info Server String: /run/user/1000/pulse/native Library Protocol Version: 35 Server Protocol Version: 35 Is Local: yes Client Index: 79 Tile Size: 65472 User Name: diya Host Name: diya Server Name: PulseAudio (on PipeWire 0.3.58) Server Version: 15.0.0 Default Sample Specification: float32le 2ch 96000Hz Default Channel Map: front-left,front-right Default Sink: alsa_output.usb-JLsounds_JLsounds_Hi-Rez_Audio_2.0-00.analog-stereo Default Source: alsa_output.usb-JLsounds_JLsounds_Hi-Rez_Audio_2.0-00.analog-stereo.monitor Cookie: b146:f672
Ovde se cak i iz Chrome menja frekfencija automatski Sink Input #73 Driver: PipeWire Owner Module: n/a Client: 72 Sink: 49 Sample Specification: float32le 2ch 96000Hz Channel Map: front-left,front-right Format: pcm, format.sample_format = "\"float32le\"" format.rate = "96000" format.channels = "2" format.channel_map = "\"front-left,front-right\"" Corked: no Mute: no Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB balance 0.00 Buffer Latency: 0 usec Sink Latency: 0 usec Resample method: PipeWire Properties: client.api = "pipewire-pulse" pulse.server.type = "unix" application.name = "Google Chrome" application.process.id = "1627" application.process.user = "diya" application.process.host = "diya" application.process.binary = "chrome" application.language = "en_US.UTF-8" window.x11.display = ":0.0" application.process.machine_id = "a729c56165d34535ae765ba31ee7e57c" application.process.session_id = "c1" application.icon_name = "google-chrome" media.name = "Playback" node.rate = "1/96000" node.latency = "2048/96000" stream.is-live = "true" node.name = "Google Chrome" node.autoconnect = "true" node.want-driver = "true" media.class = "Stream/Output/Audio" adapt.follower.spa-node = "" object.register = "false" factory.id = "6" clock.quantum-limit = "8192" factory.mode = "split" audio.adapt.follower = "" library.name = "audioconvert/libspa-audioconvert" client.id = "66" object.id = "67" object.serial = "73" pulse.attr.maxlength = "4194304" pulse.attr.tlength = "32768" pulse.attr.prebuf = "24584" pulse.attr.minreq = "8192" module-stream-restore.id = "sink-input-by-application-name:Google Chrome"
https://trendoceans.com/enable-pipewire-and-disable-pulseaudio-in-ubuntu/
Ja sam zaglibio sad sa pipewire Ovo bolje peva od pulseaudio i bez RT kernela
Pa sa ovim cemo da zavrsimo sve. Ne treba SnakeOil ako moze da se upravlja spolja sa ovim. A lako cemo web interfejs da napravimo kao sto ima SnakeOil. Msm na kraju mozemo i obe verzije
Ama ja cu da hakujem ovaj SnakeOil da nema izolaciju
Ama bre ovaj Snake Oil nema veze sa sistemom. Ovo je u potpunoj izolaciji. Dize se kao Virtualna masina sa svojim kernelom. SRANJE - prevedeno. Dzaba sva podesavanja kad ne moze da ucita kernel na masini. Ovo je masina u masini Ko kad imas Virtualbox pa se podize iz nje sistem i kaci se na mrezu. Ovo je bre emulator - duduci "Or drop your Snakeoil OS Firmware, Module or Kernel into this marked box to begin installation." znaci dzaba Xenmod kernel kad on pregazi sa svojim kernelom
Samo za duduke - sve na gomili. Ne morate da ustanete iz fotelje niti daljinski upravljac da ostavite. Ima da urastete u fotelju diya@diya:~/Downloads$ sudo bash snakeoil-installer-x86_64-1.2.6.sh [sudo] password for diya: # Begin installation of Snakeoil 1.2.6 + Checking pre-requistes... OK * Checking program (ip)... FOUND * Checking program (grep)... FOUND * Checking program (head)... FOUND * Checking program (tail)... FOUND * Checking program (sed)... FOUND * Checking program (pgrep)... FOUND * Checking program (sha1sum)... FOUND * Checking program (tar)... FOUND * Checking program (ip)... FOUND * Checking program (cat)... FOUND * Checking program (mktemp)... FOUND * Checking program (cut)... FOUND * Checking program (xargs)... FOUND + Checking CPU: OK + System identified as: Ubuntu * Updating repos... OK * Checking package: net-tools - Status: Installing... OK * Checking package: avahi-daemon - Status: Already installed * Checking package: icewm - Status: Installing... OK * Checking package: lighttpd - Status: Installing... OK * Checking package: php-cgi - Status: Installing... OK * Checking package: tigervnc-standalone-server - Status: Installing... OK * Checking package: libio-socket-ssl-perl - Status: Already installed * Checking package: libgomp1 - Status: Already installed * Checking package: cifs-utils - Status: Already installed * Checking package: nfs-common - Status: Installing... OK * Checking package: samba - Status: Installing... OK * Checking package: python3-future - Status: Installing... OK * Checking package: openssh-server - Status: Installing... OK + Creating media folders... OK + Checking installer integrity... OK + Extracting archive... OK - verifying component: snakeoil-rest... OK - verifying component: Logitech Media Server... OK - verifying component: snakeoil blob... OK + Install Snakeoil RestAPI server... OK + Installing Snakeoil blob, please be patient... OK # Prepping Your System For Snakeoil. + Startup script... OK + Web server... OK + Logitech Media Server... Already installed + Configuring network... Not using netplan or ifupdown. This might not work + Configuring virtual desktop... OK + Configuring boot options... OK + Configuring samba... OK # Cleaning up tmp files... OK # Installation complete. Please reboot your computer now.
Pravim trenutno drugi distro baziran na Xubuntu core - koji ce sve ovo da ima. Da izgleda kao ono predhodno. Ali jos minimalnije , brze - sa Zenmod kernel
90% da hoće. neće.... probao ja..... ako pređemo na ubuntu nema MX tools. snapšotovanja celog sistema. mogu da probam da ubuntu ubacim samo to ali pitanje je da li će da radi.
da umem da ga namestim već bi bio unutra - mrka kapa izbacuje grešku. ono uputsvo sa sajta je ZERO treba onaj njihov iso na sastavne delove da rastavis da vidis kao su namestili
90% da hoće.
Probaj prvo sa USB kako radi
Ma jok. Instaliraj šta god hoćeš. Ne može da se zezne optimizacija jer je u sistemskim fajlovima OS. Može preko i SnakeOil
PA naravno da je računar. Ovo je sistem sa koga trenutno tipkam po forumu,
GitHub - Mastermindzh/tidal-hifi: The web version of Tidal running in electron with hifi support thanks to widevine. GITHUB.COM The web version of Tidal running in electron with hifi support thanks to widevine. - GitHub - Mastermindzh/tidal-hifi: The web version of Tidal running in electron with hifi support thanks to widev... TIDAL Hi-Fi is made by Rick van Lieshout. It uses Castlabs' version of Electron for widevine support. Tidal-hifi Lets You Stream Music from Tidal on Linux - OMG! Ubuntu! WWW.OMGUBUNTU.CO.UK Listen to TIDAL on your Linux desktop thanks to this Electron-based desktop TIDAL client that integrates the official web player into the desktop. zadnja verzija instalirana. morate probati pa da vidimo.
