Showing content with the highest reputation on 01/17/25 u svim oblastima
  1. Upravo izašlo na musicYt. https://music.youtube.com/watch?v=NS6mFNACdkA&list=OLAK5uy_m9u2pnhWFI-p0j8G2qZnRgtCjg88_fECw Recorded Live at Theater De Oranjerie, Roermond, NL, March 24, 1974 EXCELLENT Soundboard Recording // 57 min Chick Corea - Fender Rhodes, keyboards Bill Connors - guitars Stanley Clarke - bass Lenny White - drums 1. CAPTAIN SENOR MOUSE 2. AFTER THE COSMIC RAIN 3. Lenny White Solo on Drums 4. THEME TO THE MOTHERSHIP 5. SPACE CIRCUS - Part I 6. SPACE CIRCUS - Part II - AFTER THE COSMIC RAIN (Coda) - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Preporuka za ući u svet RtF. Za nas Korija lover-e, obavezno štivo.
  2. Zen Mod
    ZM, random zanimacije
    https://www.diyaudio.com/community/threads/babelfish-f8.419127/post-7903434
  3. ^ Kud ide ovaj svet? Ovo je super način za SuperExpres kurirsku službu.
  4. Mikorist
    Linkovi i Literatura
    Mikrofotografije integrisanih kola operacionih pojačavača Bipolare Eingänge HS-1135RH Harris Semiconductor strahlungsresisenter High-Speed-Operationsverstärker LM318 Raytheon LM318 Thomson Semiconducteurs hohe Slewrate LM358 National Semiconductor (Querverlinkung) LM358 Signetics (Querverlinkung) Zweifach-Operationsverstärker LT1012 Linear Technology Präzisions-Operationsverstärker mit Picoamp-Biasstromkompensation LT1013 Linear Technology Zweifach-Präzisions-Operationsverstärker LT1037 Linear Technology hohe Slewrate µA709 Varianten Fairchild, HFO, Microsystems International, Mikroelektronika Botevgrad National Semiconductor, Siemens, Telefunken, Texas Instruments, Toshiba und Transitron µA741 Varianten Analog Devices, Intersil, Microsystems International, National Semiconductor, RCA, Sanyo, Sescosem, SGS, ST Microelectronics und Tungsram µA776 Fairchild extern einstellbarer Arbeitsstrom NE1037 Signetics hohe Slewrate NE5532 Philips NE5534 Signetics SA5532 Texas Instruments NE5534 Texas Instruments Fälschung geringes Rauschen OP01 PMI (Revision S) OP01 PMI (Revision S) (Querverlinkung DAC800) OP01 PMI (Revision T) (Querverlinkung DAC80) OP02 (Querverlinkung DAC80) OP07 PMI (Revision Z) OP07 PMI (Revision U) (Querverlinkung AD1139) sehr kleiner Offset OP177 PMI sehr kleiner Offset OP27 PMI (Querverlinkung AD1139) OP283 PMI Zweifach-Operationsverstärker / Single Supply 3-36V OP284 PMI Zweifach-Präzisions-Operationsverstärker / Single Supply 3-36V / Rail-to-Rail Eingang und Ausgang OP295 PMI Zweifach-Operationsverstärker / Single Supply 3-36V / Rail-to-Rail Ausgang OP400 PMI Vierfach-Operationsverstärker OPA676 Burr-Brown schneller Operationsverstärker mit Eingangsumschaltung TA75558 Toshiba THAT 1240 THAT THAT 1240 THAT (Fälschung) TL592B Texas Instruments (Querverlinkung) TP1321 Teledyne Philbrick hohe Bandbreite, geringer Eingangsstrom TP1322 Teledyne Philbrick hohe Slew-Rate ZN459 Ferranti spezieller, sehr rauscharmer Verstärker JFET-Eingänge AD549 Analog Devices Ultra Low Input Bias Current AD712 Analog Devices (Querverlinkung AD1139) Zweifach-Operationsverstärker ICL8007 Intersil LF355 National Semiconductor LF356 National Semiconductor LF355 Texas Instruments LF411 National Semiconductor LH0042 National Semiconductor Hybrid basierend auf LM741 OPA140 Texas Instruments OPA2140 Texas Instruments Zweifach-Operationsverstärker OPA604 Burr-Brown Fälschung OPA627 Burr-Brown Präzisions-Operationsverstärker OPA656 Burr-Brown TL062 Texas Instruments Zweifach-Operationsverstärker TLE2072 Texas Instruments Zweifach-Operationsverstärker MOSFET-Eingänge LMC660 National Semiconductor Vierfach-Operationsverstärker LMC662 National Semiconductor Zweifach-Operationsverstärker LTC1051 Linear Technology Zweifach-Auto-Zero-Operationsverstärker TLC074 Texas Instruments Vierfach-Operationsverstärker TLC2262 Texas Instruments Zweifach-Operationsverstärker TLC272 Texas Instruments Zweifach-Operationsverstärker TLC274 Texas Instruments Vierfach-Operationsverstärker Ovo su neki standrdni tipovi iz kojih su se razvili svi ostali. Postoji i forum na kome se kače ove fotografije (sa raznim pojašnjenjima u crevca sitna) Opamps - Die pictures - Page 1 WWW.EEVBLOG.COM Opamps - Die pictures - Page 1 Ove dve stranice pružaju detaljne mikrofotografije različitih integrisanih kola, uključujući operacione pojačavače. https://siliconpr0n.org/map/ http://www.visual6502.org/
  5. Mikorist
    diyAudio.rs Linux OS
    Pitao me @asimze kako d dođe od SACD/DSD - ISO fajla do FLAC-ova..... Evo ubrzani KGB kurs.....alti su već ugrađeni u ovaj linux. prvo kucaš u terminalu sudo wget -o /usr/local/bin/dsf2flac https://diyaudio.rs/skripte/dsf2flac pa sudo chmod +x /usr/local/bin/dsf2flac da se apgrejduje na zadnju verziju koristis u terminalu extract_dsd_iso convert_dsf PRIMER Folder gde ti je ISO fajl otvoris tu terminal pa extract_dsd_iso pa enter pronađeš podfolder gde su DSF fajlovi (ako je neko skinuo već zipovan DSF folder ono predhodno mu ne treba) ako nekome ne treba flac - samo ostavi (ogromne) dsf fajlove i slusa ih u full odatle ili odakle oće.... otvoriš tu terminal pa convert_dsf pa enter posle tog imaćes FLAC-ove umesto DSF/DSD format flac-a po defaultu je 24bit 88200 to je sve
  6. Mikorist
    Nove tehnologije i izumi
    A to se ni ne isplati. Zbog količine goriva.Više se isplati da se vrati Konkord avion - ili sličan model koji bi išao i višlje sub-orbital sa još i većim ubrznjem, pa bi se stizalo za 2 sata do merike....uz neke normlne cene trocifrene....
  7. BANAT
    GM70 / II (end of game)
    To je dosta dobar link ka GM70-SET pojacalu , meni se dopada ovaj grafikon gde je DCv napon na anodi +850V sa mirnom strujom od 120mA pri Ug1 od -70Vdc , sto proizvodi stalnu anodnu disipaciju od oko 102W , sto opet obezbedjuje oko 25W zdrave rezerve do max. kontinuale propisane anodne disipacije od 125W , sa pametno osmisljenim ispravljacko-napojnim delom u tom slucaju treba oko +900V za liniju napajanja anode GM70 , i automatski dobijena polovina od oko +450V za liniju napajanja ulazno-pobudne AF pentode .
  8. Lemić
    ( Dužan sam izvinjenje i pojašnjenje, Iva Jeličić je uspostavio "Neptun" fabriku pojačivača, Svrljig je radio Philips a gluvu sobu niški fakultet.) Što se tiče hlađenja cevi, Gosn Maričić mi je pojasnio, kad se hladi balon, jednakomernije je opstrujavanje elektrona na anodi i ta cev bude dominantnija u odnosu na vreliju, kaže da je to opšte poznato, objašnjavajući al ja to neću da pamtim. Večeras sam slušao, sa različitim temperaturama je slika blago u levo, rambl koji mi je bio reper, za nekih recimo tridesetak cm pomeren, kad sam vratio hladnjak i poravnala se temperatura, tačno u sredini. Buca je takođe primetio da postoji razlika iako nije direktno slušao, već po memoriji. (Da podsetim, on je profi operski pevač i sva svoja izvođenja je uvek znao napamet, ima godina ali još uvek ume da čuje.) Iz navedenog, hladnije staklo je dobitno, sinoć je bila sluška do iza ponoći, sve lepše zvuči.
  9. Neko za zanima sa velikim zvucnicima, a neko se igra s'maleckim Evo da ne bude da samo palamudim. Uzeh one zvucnike sto mi Deda Mraz doneo (jbg, omatorio valjda pa nikako da mi donese one vece, sto ih cekam vec godinu dana). Dakle Markaudio CHN50p. Posto sam vec imao neke melecke zvucnike koje sam koristio za testiranje i igranje, izvadim i stavim ove moje, a legli ko dupe na nosu. Otkacim visokotonac. Cisto radi info: Pojacalo Zen V9-ductor monoblokovi, pretpojacalo DIY Frontend 2022, DAC ono govance USB C na slusalice, izvor telefon. Subwoofer 8" sa pasivnom membranom. U manjoj sobi, bas lepo sviraju. Da, nije to to kao kod vecih zvucnika, ali nista ne zamara...
  10. Vix
    China's LARID radar detects plasma bubbles over Giza pyramids INTERESTINGENGINEERING.COM Chinese scientists used the powerful LARID radar in Hainan to detect plasma bubbles over the Egyptian pyramids and the Midway Islands, nearly 5,965 miles apart.
  • Trenutno na sajtu   1 član, 0 Skrivenih, 1683 Gosta (Pogledaj celu listu)
