Showing content with the highest reputation on 12/13/23 u svim oblastima
  1. grone
    Danley THSPUD
    Napravio sam ranije prije 2-3 god Danley DTS-10 "clone" origigi je ovaj: DTS10 | Danley Sound Labs WWW.DANLEYSOUNDLABS.COM The DTS10 theater subwoofer is the ideal subwoofer for home theatre and cinema use with a powerful low end sound. Pratio sam temu u AVS forumu ima i na drugim forumima: https://www.avsforum.com/threads/danley-dts-10-super-spud-diy-kit.1189404/ Ispostavilo da Alpine R2-W12D4 drivers 2 komada rade bolje nego ono sto Danley koristio custom Eminence koje ne moze se kupiti. Sve to lepo i jeftino uradio jos ga koristim zavisi sta slusam gledam. Posto imam dosta PWR amps na njega je povezano 2500w crown xls2501 na bridge modu. Kao taped horn ima oko 7m lavirint unutra, znam da sam stavio negde ovde u forumu... ide veoma nisko oko 15 Hz sa dosta Spl, rezano je na 60Hz, podesen je aktivno sa time delay i PEQ dosta sam se bavio stime. Vise se to primecuje u filmovima na dobar source i ne smeta uopte u muzici. U toku svega toga sam primetio da Danley ima manji model THSPUD koji isto moze se klonirati sa isto tako Alpine SWR-843D Origigi je ovaj: THSPUD | Danley Sound Labs WWW.DANLEYSOUNDLABS.COM The THSPUD subwoofer is ideal for a home theater and is a great way to bring Danley Sound Labs products into your home. Ima dosta oko Clone toga: DIY THSPUD clone - Subwoofers - The Klipsch Audio Community COMMUNITY.KLIPSCH.COM So I decided to start a actual build thread on the THSPUD clones I will be building, instead of hijacking the thread I have on plywood. Now I am going to be lazy and copy what I wrote on another thread. First if this isnt allowed then I apologize in advance, and please delete it. If not, then enj... Danas su stigli i nisam hteo temu da stavim u "novo pristigle skalamerije" da bude tema ovde. Nastavak sledi ubrzo...
  2. ... a cefka za bas-refleks služi za bolju promaju ...
  3. U medjuvremenu...
  4. Olovka i papir, slikaš ili skeniraš i okačiš. Ebeš programe, naoštri grafitnu a možeš i rapidografima a ni guščjim perom neće ispasti loše 😅
  5. Vidi, takođe kod D klase ide na izlaz L pa C, pa onda kabli sa nekim svojim parazitnim kapacitivnostima, pa ga dočeka C ponovo, a na kraju L od trafoa, pa iza magnetnog kola još jedan L. Ne kažem, ali može da dođe do svakakvih tranzijentnih struja na frekvencijama višim i od 500 herca, kamoli 5kHz i više, a bude tu struje iha, još ako si žario to malo jače... Kao što napisa Damic, treba to rezati sa 24db/oct, 12 minimum.
  6. Mislim da D klasa nema veze, ja sam davno sa Luxman L-530 (2 x 15W A, 2 x 120W AB) spalio 26-incni ribbon od Apogee Stage, jesam ga malo jače odvrnuo. Sigurno je pojačalo generisalo neki peak koji je upropastio ribon. Skretnica može negativno da utiče ako je suviše blaga i nisko postavljena. Ako se na ribonu primete nagužvani delovi, bio je previše panjen. Na to obratiti pažnju kod kupovine polovnih. Od kad koristim kod rezova isključivo 24LR, nemam problema.
  7. Pa bio povezan na Hypex NC502, imao samo 11R i 3.9uF znaci oko 5Khz tako je bilo preporuceno od Ace, Ali nismo pricali da ce biti korisceno u D klasi... i da ja ono ponekad nagazim kao na Jbl... 140-15D ide 500Hz~100KHz i verovatno Hypex negde na infra freq imao cliping! Polako je poceo da se pojavi rupa kao sa iglom u sredini ribona i pucao posle neko vreme. Pricao sam sa Acom objasnio mi da treba i 0.1Mh da stavim zbog toga. I poslao mi nove ribone bez ikakvih troskova tip je car. To je bilo prije 2 god ali veceras dosao red da promenim jer previse toga je doso&desilo i nisu mi bili potrebni. Inace radi do 00 ustvari ubija kako radi I tako.
  8. Izvinite za off
  9. Zen Mod
    Iskustvo sa 6KN6 cevima ?
    back of napkin perfect
  10. asimze
    @shonne insan se treba bojati samo teških metala i nuklearne radijacije! A droga, droga je voda duboka što reče BBBB! @Woland hvala za prvi zvaničan čas u ime ponavljača iz zadnjeg reda.
  11. zerowaf
    Drogu ne! Pazimo na sebe! Ja sam si donio komad betona u sobu, pa onda otvorim prozore da napravim promaju i sjednem na 'ladan beton i tako slušam. Zaključio sam da propuh u glavi nije dovoljan.
  12. shonne
    Nemojte samo drogu da koristite uz @Woland muziku 😁
  13. BANAT
    Tako sam i mislio da je izlazni stepen ali i jos po nesto (cekamo shemu) prepravljeno na pentodni mod rada ,mislim da je taj M.Porzili tacno znao sta hoce i sta moze da se napravi a da se dobiju zvucno optimalni rezultati sa tim 6KN6 TV lampama , slicno radi i Bob Carver u njegovim raznim lampas HI-FI pojacalima snage gde su za izlazni stepen snage razne lampe uvek vezane pentodno , po mom iskustvu u takvom rezimu rada distorzija u otvorenoj petlji nije bas najbolja ali je zato dobijena dinamika zvuka neprevazidjena , btw , slicne 6KN6 TV lampe ali Niske PL519 koristili smo u snaznim push-pull pentodnim modulatorima za amplitudno modulisanje srednje-talasnih lampas piratskih snaznih predajnika , ganjali smo ih sa sve do 1KV B+ anodnog napona ali zato g2 napon nikada nije prelazio 150V , obicno je to bilo oko 100V iz posebnog izvora napajanja , u takvom pentodnom rezimu rada te sjajne Niske TV lampe trajale su u nedogled.
  14. zika
    Sav Taj Jazz !
    Ovo me vraća u devedesete godine. Ukrao sam to od mlađeg sina i uživao, nekako lakše dišući u smogu tog vremena. Počeci ozbiljne zavisnosti od PC music...
  15. Zen Mod
    naravno, uvek moze da se nauci nesto korisno
  16. Izgleda da ne vole bas D-klasu reko mi Aca da stavim i L osim konda u skretnici Poceo kao rupa u sredini dok pucao skroz...
  17. asimze
    Izgleda da čemo morati poslati @Woland molbu taksiranu sa 100€ sudske takse da nam malo češče otvara prozor u svjet muzike. Nama ponavljačima iz zadnjeg reda!
  18. asimze
    Ezio Bosso! E jesi me sjebao @zerowaf, nikako da mi izađe iz uha. fantastično! Deezer WWW.DEEZER.COM Podsječa me na Glassa i Metamorfoze!
  19. zerowaf
    Opet Ezio Boso. Sad već imam 4 ploče, pa bi se moglo reći da mi se sviđa. Glazba koju je pisao ima prepoznatljiv potpis, pa će kao i uvijek nekima biti odlična, a nekima dosadna jer se potpis ponavlja. Ovo nije opis ovog albuma nego onoga što sam do sada čuo od njega. Meni odgovara atmosfera koju gradi raznim gudalima, pianom i orguljama. Inspiriran pjesmama E. Dickinson nastao je ovaj projekt koji nije nikad doveden do kraja onako kako ga je Ezio zamišljao.
  20. Relativno jeftina igranka, varijacija na Pico Lino 2 sa Vifa TC9. Otvori za zvučnike su okrugli a preko drajvera ide aluminijumski prsten u ravni sa prednjom pločom, isprobana varijanta za ovaj drajver i dobija se bolji odziv. To be continued...
  21. zerowaf
    Nisam ja! Woland je opet bio moj prozor u svijet!
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 1673 Gosta (Pogledaj celu listu)
