Showing content with the highest reputation on 04/18/22 u svim oblastima
Poređenje XA30.5 vs. XA30.8 a bogumi i XA60.8
LightMatic i jedan drugi je reagovao/la na Srecko za temu
Ovoliki trud odjednom, mora da je zbog toga što se bližimo prazniku rada😁. Sjajno!2 poena -
SissySIT P ..... or how I proved fact of making more Hats than Pa did
https://www.diyaudio.com/community/threads/sissysit-p-or-how-i-proved-fact-of-making-more-hats-than-pa-did.385400/#post-7000665 Well, anyone at least partially partial with my omnipresent babbling, knows about endless series of M2 derivatives, I made sorta recently All of them having M2-like Front End (my biggest Fetish), so entire voltage gain got from autoformer, so no (overall) NFB involved Also - all of them having second of my recent Fetishes - Square Law OS Ok, that is line of unnecessary long line of M2 derivatives, difference being that each is having different quirk of OS parts Then came next fixation point... when I concocted FE for Babelfish XA252, biggest part of invention was proper name for same FE - Plethora of Pinjatas ....... so I ( naturally) came to idea of making second totally unnecessary line of derivatives, now having Plethora of Pinjatas FE, and simply varying already proven SL OS iterations This line having slightly different ( sorta mirrored/flipped/downundered/whatever) biasing mechanimus, comparing to older specimens, this one directly taken form Babelfish XA252 Comparing to older ones ( having opto between Mosfet Gates and fixed resistors from rails to gates), there are current mirrors from rails to fixed resistor(s) between Mosfet gates; result is better Iq behavior in domain of rails change, same as better Iq behavior in thermal change domain, and also firmer relaxation factor (Iq stability in dynamic domain; think recovery time if change occurs with long large signal) Anyway, let's ignore Babelfish XA252 as first one, declare SissySIT P (P suffix for Plethora of Pinjatas family) as first one Am I happy ...... yes! (this one done, so I can think of working on next ) Confirming same amp sound character, for amps made without NFB and with Autoformer gain and amps made with sorta heavy NFB and active gain ....... well, not exactly a novelty per se this post intentionally made pic-less - in case of later edits, lesser mess1 poen -
1 poen -
1 poen -
1 poen -
gluv_i_udaren je reagovao/la na ninja za temu
Nisi jedini, imam i ja mojih kostura u garderobi koje nikako da ozivim ... a godine prolaze, novi planovi se mnoze a realizacija ne prati1 poen -
Thelonious Monk and Gerry Mulligan - Mulligan meets Monk, Riverside... je npr. ploca za preporuku, postoji japansko izdanje koje je odlicno.1 poen
kad je Djokica aktivan onda smo svi aktivni1 poen
Speakers corner/Columbia Imam odavno digitalni format ovog albuma, ali sam silno htio i ploču. Za početak, mjuza mi baš paše. Pitka, naizgled jednostavna sesija. Dovoljno slojeva da ne bude banalna, a dovoljno pitka da ne smara. Kao dobro odmjeren film za provesti veče. Nije te bacio u bed, nisi se sekirao dok si gledao, uživao si u pitkim dijalozima i pitaš se pokraj svega što je nominirano za Oscara kako i ovo nije dospjelo tamo? Što više slušaš to je bolje! Ovo je dobar uvod za sutrašnju sesiju sa Hooker & Heat..... ukućani su izrazili želju za spavanjem i budući da su ih komšije došle pod prozor podržati sa bakljama, vilama i motikama morao sam povuči diplomatski mudar potez i udovoljiti zahtjevima.1 poen
gluv_i_udaren je reagovao/la na vladd za temu
Ovi decaci sto se igraju sa nozevima, kriogeno temperuju celik, pa ako zaokruzis proces, od jaja do noza, nece da valja, a posle dominiraju visoki1 poen -
cu ga ja derati ... pa sto ce mi onda hanuma1 poen
gluv_i_udaren je reagovao/la na zerowaf za temu
Ja nisam na žalost nikad do sad čuo to na gramofonu. Prije parsto godina mi je frend pustio kod sebe CD na nekom Esprit Sony playeru, ne sjećam se kakih krmača od pojačala i na starim B&W 801...oni sa "kockastom" kutijom za srednjotonac. Soba je bila, pa ne znam, možda 50 ili čak i više kvadrata. Čovjek ju je sam pravio za hifu i odmah akustički tretirao. Kažem, sam od sebe ne bih vjerojatno nikada uzeo CD od Belafontea da slušam, ali ovo je takav pogodak da se jednostavno mora imati, pa kad sam vidio plou nisam imao izbora nego ju i naručiti.... Kao onaj što ga je mati ujutro pitala: "Zašto si se, sine, napio?" On će: "Pogodila me pjesma majko!" Ona dalje pita: "Pa koja pjesma, sine?" On: "Pa svaka majko!"1 poen -
@Aleks me navlaci na blud...probace se prvo mono u Aleph kutiju sa novom maticnom plocom 😁1 poen -
How it sounds? Well, as close Cousin ( younger one) of Babelfish XA252 SIT Good enough for Mighty Moi0 poena -
Pa ako hoces jos koje iskusenje, jedna vrlo jednostavna, mehanicka, tangencijalna rucka. Nije je nesto tesko za napraviti. Ja ti mogu dati mjere pa probaj Dodaj samo mogucnost VTA i vozi misko ... cita kako je i rezano a ide ko jedrenjak i po valovitim plocama. Evo malo mojih starijih filmica0 poena
Trenutno na sajtu 3 članova, 1 Skrivenih, 2158 Gosta (Pogledaj celu listu)
