Showing content with the highest reputation on 09/08/17 u svim oblastima
  1. a šta će vam domaća pamet kad sve što ste nabrojali da volite sem hrane i babinog nameštaja je iz inostranstva?
  2. ZZZ
    RCA LC1 kabineti
    ovako izgleda na nogama
  3. ZZZ
    RCA LC1 kabineti
    Sve zavrsio - samo jos damping mobilne nogice, portovi, lakiranje...
  4. ZZZ
    RCA LC1 kabineti
    Hvala, ALI to ipak nije rad majstora, nego neka vrsta OTO-a Nije mi bila namera a nije ni bilo moguce da to izgleda i bude uradjeno onako kako bi to neki profesionalac u tom domenu izveo. DIY sistem uz pomoc lokalnih radnjica materijala. Da podsetim, sve uradjeno bez stega, od masina samo busilica, ubodna pila, baterijski odvijac. I neizbezna hrpa sablona. Ako neko hoce da skenira 1:1 u fotokopirnici neka se javi posto uskoro bacam. Ovih mera nema i nema sablona za cut/oute za ove drivere. Sve sam rucno skidao...
  5. The above statement is not quite correct:- Sorry No, this is wrong, Magnum was formed from my company MIH, which became Pro-Ac Magnum, then Tony Relph joined me as a business guru, then after 3 yrs managed after locking me out after a holiday stole the company and I was force to take legal action for use of some patents. and stealing my company. Meanwhile I started Inca Tech producing no electronics until the legal action was resolved but the world first Gold Plated Power Connectors for the audio world, now be warned never share a company 50/50 if you have started it you partner may not be so trustworthy as you. And for folk out there here is a rough list of other things I have designed. In order:- Pushpull 1 Germanium Amp 1971 V1 Tube amp 1972 12W Single Ended A Class 1974 MIH 100W 1975 MIH 400W ProAc stereo 100w 1980 ProAc 3 Channel 100W Magnum A100, 400W 1982 Magnum A200 Magnum Pre-amps IncaTech Gold Plated Power Plus and Sockets 1982 Inca Tech Sabre iss 1 1983 Inca Tech Prelude Inca Tech Claymore 1 1983 Inca Tech Claymore Gold Inca Tech Claymore S Inca Tech Claymore 2 Inca Tech Quatra Inca Tech FMT Tuner Inca Tech IT50,IT100,IT200 Inca Tech IT1P preamp Inca Tech Sabre iss 2 Inca Tech Dirk Inca Design ID25,ID50,ID75 Inca Tech MSB (a monster) Inca Design Oberon Classic Inca Design Oberon (standard) Lescon Quatra Oxford Acoustic's "Mystic" TOCA SECA 20W,50W,100W,200W,300W single ended class A,s 1995 TOCA I75 TOCA Pre A TOCA 75W Tellurium Q Cables 2009 Tellurium Q, A Class 20W, 100W 2011 Tellurium Q Headphone/Phono Amp Tellurium Q Pre-Amp EWA (Elsdon Wonfor Audio) A complete range of new designs after yet another twit full of greed stole by waiting for me to become very ill yet another company from my original company called Catch 22 then it became Tellurium Q. EWA have cables, Power Amps, Pr-Amps, SECA Amps. Read on:-http://seca.freeforums.net/ https://www.elsdonwonforaudio.com/ Products worked on Naim Nait 5i, other bits also for Naim and Cambridge Audio. 2008- 2010
  6. Zflazar
    Kupuj dok nije otišlo...
    globalno sam zadovoljan sa celim gramofonom pa ne mogu da ti kažem koji je deo ponaosob razlog mom zadovoljstvu. Braun PS500 takav kakav je sa dobrim osveženjem od strane lokalnog servisera starih gramofona plus minimalnom korekcijom sheme ožičenja i uzemljenja unutar gramofona od strane mog burazera je poslao u istoriju Stabi Mk I i Stabi Mk II sa hifi police. Kod brata su na skupljanju prašine. Možete oba sa- ili bez pripadajuće Roksan Artemiz ručke da kupite ako ste zainteresovani. 150EUR za ovaj gramofon su presmešne pare.
  7. Resimo ? Nema razloga da govoris u moje ime. Ja uipravo krecem u "Slon"-a na mutni Paulaner. https://foursquare.com/v/slon/4f66618de4b0eae10c2214b8 Jbga, poceo vikend, pa da se pocastim malko. Ti se vec snadji u Nish ( vec ti rekoh, ali ti mnozina, pa mnozina ).
  8. Okibokis
    Magnum mc 250
    Pozdrav svima!Nabavio sam ovog dedu za svog Crown d-150 ,da mu bude predpojacalo,a on nece da radi?Da li je ovo namenski pravljen preamp koji bi ja morao da modifikujem da bi radio sa mojim snagasem,ili je u pitanju i neka vrsta nekompatibilnosti,jer sam cuo da postoje dve vrste preampa,aktivni i pasivni,i da je potrebno podesiti nekakvu ulaznu impendansu.Za te stvari sam laik,ali sam slikao oznake od pozadi i preamp unutra,pa ako neko hoce da mi pomogne zahvaljujem:)...............
  9. крокодил
    Magnum mc 250
    Kasno se javio konstruktor. Nije me pre interesovalo, ali sam sad sve iscitao, i proguglao, tako da je ovo po svemu sudeci zavrsni rezultat; evo slike sa komsijskog fifi foruma. Opis u oglasu je, pa da tako kazemo - neodoljiv!
  10. Upravo tako. Nissan na parkingu, Quad u dnevnoj sobi.
  11. Mala korekcija - mi smo bili u magli, ali smo i ostali. Sa druge strane smo uvek raspolozeni da kritikujemo, mrsomoodimo, pametujemo etc. Verovatno je to zbog konstantnog boravka u magli, pa je koncentracija kiseonika niza od uobicajene.
  12. 1 poen
  13. apexaudio
    APEX AX-11
    AA9
  14. apexaudio
    APEX AX-11
    AX11, TB1, TB3...
  15. vdzele
    Kompilacije by vdzele
    Voleo bi da čujem mišljenja koje su razlike između ovih snimaka i onog što ste imali do sada.
  16. Iz iste prodavnice kao Zsofia
  17. Colin Wonfor
    Magnum mc 250
    Setting bias I have learnt for FET amps is a bit hit or miss. I load the amp with the current set to zero on the pre-set. Then a 10KHz signal is plug in so the the 8 Ohm load RESISTOR has just 2 Volts Pk-Pk You can then clearly see the Cross Over distortion on a scope. Adjust the pre-set with care until the distortion is gone, keep a careful monitor of the heat sink temperature and it is best a a ambient of 25C The Amp will sound amazing and run slightly warm and low levels. I hope this helps? Best Col
  • Trenutno na sajtu   4 članova, 1 Skrivenih, 1494 Gosta (Pogledaj celu listu)
