Zen Mod
Administrator
Sve objavljeno od Zen Mod
  1. ulazni stepen - imas Toshiba JFets ili ces bipolar ?
  2. a jes znam ja da je kod tebe
  3. napravis Altmanovu rucku za mono
  4. ne treba nikakva intervencija na ozicenju svakako , i da ima manje pina visak klipsi se parkira pored glave veoma lako
  5. ? jbte , ne sedas u auto da ga vozis dok ne sedne svih 5? sto ce ti 4 pina ? mislim , kakve to veze ima - kakvu god zvucnicu da nabavis , to je zadnja stvar koja je bitna i resava se u hodu nego gledaj da izaberes koja od silnije rucaka ce da bude za mono zvucnicu i na koju bazu ce je prisabacis
  6. dobro ......sad jos samo ESL-ove zameniti za LS 3/5
  7. dopuna : https://www.kabusa.com/stantonx.htm Detailed below is a listing of Stanton Cartridges and Styli that are interchangeable with each other within the same cartridge family. I.E. any stylus on the right will work in any of the cartridges on the left. Pickering part numbers are also listed since they are cross compatible too. Cartridges and Styli with links are currently in production now. Click on them to go to the product page. Stanton products are grouped by use: Hi Fi, DJ, 78 RPM and LP Mono. There are no longer any Mono Styli available from Stanton, Though KAB has a custom mono stylus available for the 500 series cartridges. How to use this chart: If you have the old needle, find it on the right hand side. Now within that entire group, find the corresponding one in red. For example, you have a D72E stylus, and your application is home hi fi, choose the D6800 Hi Fi or D6800EEE If you have just the cartridge. find it on the left hand side. Do Not Read Across, rather, look at the entire group on the right. Any of those styli will work. For Example, you have a 680EE cartridge, and your application is home hi fi, choose the D6800 Hi Fi or the D6800EEE Use the same method to find the corresponding 78 stylus, and or DJ stylus. ANY OF THESE CARTRIDGES CAN USE ANY OF THESE STYLI ------------------------ ------------------------------------------ 880E 890AL, 890SA,V3 D80E D81 IIS D810(MONO LP) 880S L837S XSV3000 D80S D83S D827(78 RPM) 881S L847S XSV5000 D81E D84S CS100 881MK2S 890V3 XSV4000 D81S N890(DJ) D88S,98S 980, 981, WOS100, EPOCH II D89AL(DJ) D3001E(HiFi) D4500S --------------------------- ---------------------------------------------- 680AL 681EEEMK2S D680 D6800SL D6800HP(DJ) 680EE 681EEEMK3 D680S D6800SE D605SK(DJ) 680EE-S 681EEE-S D6800AL(DJ) D6807A(DJ) D4510(MONO) 680 HI FI 681SE D6800 HI FI D6810(LP MONO) 680V3 L680EL D6800EE,EEE D6827(78 RPM) 680SL L727E D6800EEE MK3(Hi Fi) D72E 681A L737E 680EL D6800EEE-S D73E N680 681EE L737S Pro-46 D6800EEE-2-S D73S N680E 681EEE L747S XV-15 D6800EL(DJ) D74S D-11S --------------------------- ---------------------------------------------- 600A D6003EE D6027(78 RPM) 600E D6004E D6071A 600EE D6010(LP MONO) --------------------------- ---------------------------------------------- 500A 500EEMK2,3 D50A D50EE MK2 D5127(78 RPM) 500A MK2 500EL NP/AC D50A MK2 D5100EL(DJ) D5107DJ 500E 500AL V15 D50E D5100E D5110(LP MONO) 500EMK2 500DJ V15/DJ D71EE D5100EE D5100AL II 500EE 505SK D50EE D5107 D5200SK 500V3 520SK D50EE D5107AL(DJ) D5100SK 400V3EE D1510(MONO) N400,N500V3 500AL II PD07C D1507DJ --------------------------- ---------------------------------------------- L720EE TLE D71-2E D70E L725EE D71EE DLE --------------------------- ---------------------------------------------- EPOCH E-HiFi
  8. http://forums.stevehoffman.tv/threads/what-is-the-ideal-mono-and-78rpm-cartridge-stylus.278043/ mslm da se nesto moze poraditi u vezi so tim ....... novi stylus nabaviti koji bi radio posao ........ a mislim da i nisu poskupe Paja mu ono dodje strucnjak za Pickering i Stanton ....... a ima se koj i Stanton 500 iz zlatnog doba , mislim da ima i Pickering koji je identican Stanton 681 tela naravno , bez iglovi sorry ....
  9. zato za te lepo nabavis neki Pickering ili lepsiji Stanton , pa ih archi
  10. vidim , pralo se ........
  11. eto vidis kako znas ..... moj plan od pocetka zahajpujem , navucem ih da kupu delovi , pokupim delovi , dobijem od Neleta jos jedan neki SIT amp za trud probijanja i hajpa na izvanredno isplativom i perspektivnom srBskom trzistu ........... ih di ce mi kraj ima da krckam SITovi i da si pravim do kraja vecnosti , i phono sekcije i linije i ampovi
  12. uff jbte , ni ja te vise ne pratim ......... sebe odavno , ali ti me jos vise uzbuni .........
  13. and today is first day of evaluation on Dynaudio Contour 1.8 Mk2 4R impedance ..... after just 30min (after initial warm up) it is clear that Babelfish M25 is damn well improvement over regular (Papa's Koan) M2 ......... and that still even without trying/engaging (supposedly superior ) White Cathode Borbely JFet buffer ...... and that one is promising to have objectively lower distortions , driving that nice Edcor Iron and , we are speaking here about properly made M2 - dual mono (each channel having 250VA Donut and 4 x 33mF caps) with proper wiring inside ...... while T-Bed is having common supply for both channels , with old and tired caps and sooooo crappy wiring ........ and with flimsy 1A6 fuses inline with speakers
  14. well , I did one slight imrpovement of T-Bed added another set of (1/)5 way output terminals
  15. a pricamo o tube rolling ......
  16. a be mi se za radne krive posle , kad vec napravim onda samo merim jel' tu , u 10%
  17. jeble vas firme ceve i audiofifilisticarstvo. kod malih lampi je daleko bitniji kvalitet primerka nego razlike koje mogu da budu od proizvodjaca do proizvodjaca nije se jedan zaebo i kupio kutiju TFK ,pa posle plakao jer ih 70% povuklo vazduh/izgubilo vakuum i statijaznamjos pa suste
  18. odgledao prve dve peizode Sharp Objects lele boske , sta su tu valja iza brega ........ Amy je looda ko struja ........ a ima jos njih za zapaziti nego , davno vec nisam gledao Northern Exposure , mogao bih ponovo , od pocetka pa polako ......
  19. aha a sto je najbitnije , ima se pokojeceg drugog sem Pass i Tannoy i uziva se u svemu tome ...... jal pravili jal se domundjavali o pravljenju eto, zato je bolji HP od Mac Mini ....... kod Minija nemas sta da radis
  20. sad ce SIT-3 kod lokalnog zastupnika , pa je sve reseno
  21. i rezervni Tannoyi
  22. sve sto treba znati je ovde: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&cad=rja&uact=8&ved=0ahUKEwir-fvS4avcAhUDBywKHbAcA6wQFghFMAY&url=http%3A%2F%2Fwww.thehistoryofrecording.com%2FManuals%2FDynaCo%2FDynakit_ST35.pdf&usg=AOvVaw3yAj1sdA4jz9liC9dXwpPj ima pripadajuci preamp , nesto sa Pass u imenu , ali nema nikakve veze sa N.P. firma bese Davida Haflera , jednog od najznacajnijih ljudi u istoriji zabavne elektronike
  23. nisam nesto stekao utisak da ima sad oko cega da se podrzava grau on samo sto jos nije rekao da ide tetki da odnese lek niti se o necemu konkretno zborilo , niti ima nekog razvoja teme ...... jerbo teme nema sta je bilo pitanje , uopste ? dobro pojacalo je dobro pojacalo ........ nema veze ni ko ga je pravio , ni sa kojim elementima , ni koliko para kosta ....... ako cemo uzeti kvalitet zvuka i neopphodan kvalitet izrade kao kriterijum pun je svet dobrih ampova , a onih koji nisu dobri je ihaj vise a prodaja magle i neznanje postoje jos od rodovske zajednice dobar deo toga sto si naisao je debelo imputiranje ; ili mozda imas dovoljno integriteta , pa da quotujes i dokazes bilo koju tvrdnju ?
