Showing content with the highest reputation on 12/14/22 u svim oblastima
  1. Mislim da je sasvim dovoljan ovaj malisa od hladnjaka 😅 Svirio je burson jos jedno 50ak sati, nije se gasio dac od nedeljnog jutra. Povlacim sta rekoh za bass, kompletno se uoblicio. Svira jako lepo, vrlo ubavo, bas opamp za kada hoces da uzivas u, a ne da analiziras pesme. Pisacu opsirnije kada skockam rivju. Sad ubacujem ncd da i on uhvati koju cukicu mucenik, nisam mu dao ni blizu radnog veka kao bursonu
    5 poena
  2. Caravanserai - Santana. Album kome se cesto vracam. Faza benda gde ima jazz-a, fuzije, ali i dalje sa latino sound-om. U odlasku G. Roli, na vratima Coster za klavijaturama. Druga prica, ali obe volim na svopj nacin. Carlos & Shrieve - loodaci na slobodi. Umal' da zaboravim N. Schon-a na gitari. Obavezna muzicka lektira.
  3. C/P: "Recorded: New York City, NY October 20, 1977 Personnel: Charlie Rouse - Tenor Sax Hugh Lawson - Piano Bob Cranshaw - Bass Ben Riley - Drums Charlie Rouse came to prominence through his long tenure as Thelonious Monk's preferred tenor player during the 1950's & '60's. During that time he also notched up a battery of hard swinging, boppish & bluesy sessions under his own name (check out 'Takin' Care of Business' & 'Yeah!'). As with other elder statesman tenor sax players from the same period who went on to record into the 1970's & '80's (Buddy Tate, Harold Land, Junior Cook) there was never any buttoning off on the sense of urgency and spontaneity their playing had been delivering for decades. For Charlie Rouse, 'Moment's Notice' ranks up there with his best work. The opening track, `The Clucker', is flung out at speed and immediately makes you sit up and relish the tightness of the playing. Hugh Lawson on piano plays with great velocity and precision, constantly raising the bar of excitement. `Joobobie' puts on a kind of Afro-Cuban groove that deserves plenty of volume. The recording is great, exposing nicely Charlie's soft, mellifluous tone as he spirals over the top of some funky rhythm from Ben Riley and Bob Cranshaw. As indicated by the cover, C R had plenty to feel good about after this session, all we have to do is listen and be amazed!"
  4. ARU Goodmans origin decenijama kasnije Dynaudio napravio variovent isti qr, drugo pakovanje (pod uslovom da imas dovoljno variovenata )
  5. Zbora
    K: Subwoofer
    Jes, taj sam, SVS 1000pro je moj. Sto se problema tice vecina je bila do mog virtuozno sklopljenog Citationa, odnosno zicenja mase u njemu, i to je reseno, zahvaljujuci veseloj ekipi odavde, svi znamo koji su Osim toga, imao sam blago "pistanje" iz samog napajanja, ne iz drivera vec pozadi iz "ploče". To nije nista dramaticno ali taj zvuk postoji, ako je tisina u sobi i pridje se blizu vufera moguce je cuti. Posto je nov kupljen u Playeru nosio sam u servis, tamo su mi rekli da je to zvuk zavojnice u napajanju i da je to manje vise normalno narocito kada se ima led rasveta u kuci. Ja sam realno za te pare ocikivao da napajanje bude kao mermerna ploca. Svakako stavili su ceo nov modul, cekao se bar 3 4 nedelje, ali su javili uredno posle dijagnostike i ponudili da uredjaj bude kod mene dok se ceka modul, medjutim ne vidim da je ista drugacije, i posle toga, nije to dramaticno nista a sam uredjaj dobro radi imam jos nekoliko meseci garancije, a manjak vremena usled novogosisnjih carolija na poslu..... pa se nisam bavio time veise. Ako zelis da ga probas, mozemo to da resimo uz malo logistike.
  6. paja959
    zadnji radni dan za ovu godinu,u HO,pa se eto,krece u lagano razgibavanje..Clapton.."Slowhand" u odlicnoj formi,ni snimak nije los (live in studio"
  7. Zaptravo ja imam jedan sekundar vise zbog AK kartice. Kad saberem Nixijevo uputstvo i tvoju prepisku sa Saletom, porudzbina za Trafomatic za mene, treba biti ovako nekako. _______________________________________________________________ Trafo 1: Trafo 30VA na telu 50VA sa smanjenom indukcijom jezgra. static shield, magnetic shield, licnasti izvodi duzine 30cm (ukoliko je moguce OFC), primar naspram sekundara, bez osiguraca u primaru. Primar: 230VAC, slepi navojak. 4 odvojena sekundara : Sek1: 8Vx1,9A=15,2VA Sek2: 8Vx0,8A=6,4VA Sek3: 8Vx0,5A=4VA Sek4: 8Vx0,5A=4VA _______________________________________________________________ Trafo 2: Trafo 30VA na telu 50VA sa smanjenom indukcijom jezgra. static shield, magnetic shield, licnasti izvodi duzine 30cm (ukoliko je moguce OFC), primar naspram sekundara, bez osiguraca u primaru. Primar: 230VAC, slepi navojak. 2 odvojena sekundara : Sek1: 12Vx1,25A=15VA Sek2: 12Vx1,25A=15VA Pronadjite gresku i uperite prstom u nju necu seljutiti
  8. Da ostane ovde info za trafoe. @Zbora narucuje, pa rece da nastavimo u temi. Trafo 1: 50VA, primar 230Vac, odvojeni sekundari 1 x 12Vac, 1 x12Vac, slepi navoj, konstantno opterecenje 30VA, static shield, magnetic shield, licnasti izvodi duzine 30cm (ukoliko je moguce OFC), primar naspram sekundara, motati sa manjim magnecenjem jezgra Trafo 2: 50VA, primar 230Vac, odvojeni sekundari 1 x 8Vac 1.25A, 1x 8Vac 1A, 1x 8Vac, slepi navoj, konstantno opterecenje 30VA, static shield, magnetic shield, licnasti izvodi duzine 30cm (ukoliko je moguce OFC), primar naspram sekundara, motati sa manjim magnecenjem jezgra. Izvinio sam se Sasi ukoliko je to previse detalja, i dobio odgovor da nikad dosta istih, tako da ne smeta ovoliko informacija. (Prvobitna narudzbina je bila drugacija malo, ovo je ispravak). U odnosu na moje, drugi trafo ima 8Vac sto ce smanjiti grejanje LDO za xmos. Ne bih isao ispod 8Vac. Ja se nadam da cu uhvatiti vremena u cugu da sklepam tutorial uskoro, pa ce biti sav info na jednom mestu.
  9. Zen Mod
    Filmovi koje volite
    ću to ne možbude loše
  10. grone
    K: Subwoofer
    Napravi ovo cudo imaces bassa za ceo forum ili kupi najveci SVS, REL. THSPUD | Danley Sound Labs WWW.DANLEYSOUNDLABS.COM The THSPUD subwoofer is ideal for a home theater and is a great way to bring Danley Sound Labs products into your home. Ima DIY na AVS forumu kostace ce ti manje garant i imaces killer sub for lifetime. Ja imam veci model DTS10 ne mogu ti opisati koliko je to mocno! Retko ga pustam samo kad pustam film sa projektora...
  • Trenutno na sajtu   3 članova, 0 Skrivenih, 1619 Gosta (Pogledaj celu listu)
