Showing content with the highest reputation on 04/21/22 u svim oblastima
  1. DAC ti ne valja
  2. Loudness - moje omiljeno dugme dok sam bijo mali (na Ei HSR risiveru) Samo, nerviralo ne zasto nema isti efekat kad odvrnem glasnocu. Kasnije sam shvatio, u medjuvremenu spalio xx Niskih zvucnika...
  3. Iz tehničke perspektive, ako je dovoljna brzina downlod-a - nema smetnji između servera - ako je sve ostalo je jednako, ne bi trebalo da postoji razlika između CD-a i iste verzije strimovane FLAC ili WAV datoteke. Isti đavo naručio CD sa Bandcamp ili pure WAV Mikorist's collection | Bandcamp BANDCAMP.COM Electronic • 19 collection items Ali ako možete da čujete razliku između 2 CD plejera koji puštaju identičan disk, onda ćete verovatno moći da čujete razliku između CD-a i strimera I DAC iz istih razloga - a razlog je izlazni analogni deo uređaja - ČIP Burr-Brown: Multibit: PCM51, PCM52 – 16-bit predecessors PCM53, a ceramic package PCM53 16-bit, one of the old, but good (1983-86 years), with a parallel input PCM54 16 bit multibitnik normal (slightly older PCM56), parallel input PCM55 16 bits, the same as the PCM54, only in a small SOIC package PCM56 16 bit, normal quality multibitnik PCM58 18-bit, a very good DAC PCM61 18-bit, the quality of a PCM56, but 18-bit PCM63 20-bit, one of the best of the world’s Audio PCM64 18-bit, one of the best, with a parallel input PCM65 – one of the best, most expensive and rare multibitnikov, with parallel input PCM66 16-bit DAC-2 and, huddled in a single housing, the quality – so so PCM67 hybrid (multi + one-bit), 2 DACs and in one case (stereo) PCM69 hybrid (multi + one bit), the same as the PCM67 PCM1700 18-bit, 2-DAC and in one case (stereo), the quality level PCM61 PCM1701 18-bit, one of the best, the successor technology PCM58 PCM1702 20-bit, the quality just below the PCM63 PCM1704 20-bit, the same as the PCM1702, but only able to accept 24-bit stream (converting all the same 20-bit) Burr-Brown Single-bit: PCM1600 / 1601, cheap PCM1607, cheap PCM1710, normal odnobitnik PCM1715, cheap PCM1716, cheap odnobitnik receiving 24bit/96kGts. PCM1723, cheap PCM1728 odnobitnik receiving 24bit/96kGts. PCM1732 is more or less of the one-bit PCM1738 is more or less of the one-bit, slightly better PCM1732 PCM1792 – newer odnobitnik series of 24/192 PCM1794 – best of odnobitnik PCM1792-PCM1798 (from a series of 24/192) PCM1796, PCM1798 – latest odnobitniki, the quality is lower than the PCM1792 ————————————————– Philips: TDA1540 14-bit old multibitnik (1982-1986.), Very musical TDA1541 16-bit is a very good multibitnik, stereo TDA1541A 16 bit – “improved” TDA1541 – good multibitnik TDA1541A R1 16-bit – the version with the worst differential nonlinearity than ordinary TDA1541A TDA1541A S1 16 bit – one of the best filipsovskih multibit TDA1541A S2 16 bit – one of the best filipsovskih multibit TDA1543 16-bit, two channels in one, simple and cheap TDA1545 16-bit, low-cost TDA1547 aka – DAC 7, one of the best single-bit filipsovskih TDA1549 1 bit, the average size odnobitnik BitStream TDA1305 1 bit, the usual odnobitnik, parameters worse than TDA1549 SAA7321 1 bit, the average odnobitnik SAA7323 1 bit, the average odnobitnik SAA7341 1 bit cheap chip “all-in-one” SAA7350 1 bit, the usual Delta-Sigma, could be put together with TDA1547 and is itself ————————————————– Analog Devices: Multibit: AD1851 16-bit, cheap multibitnik AD1856 16-bit, multibitnik average, more coldly detailed analog PCM56 AD1860 18-bit, good multibitnik AD1861 18-bit, multibitnik, analog PCM61, but slightly worse than the AD1860 AD1862 20-bit – one of the best of the world’s Audio AD1864 18-bit, good multibitnik, 2 DACs and in one case (stereo) AD1865 18-bit, very good multibitnik, 2 DACs and in one case (stereo) Analog Devices Single-bit: AD1852 1 bit, the average odnobitnik without current output (voltage only) AD1853 1 bit odnobitnik good, one of the best one-bit from Analog Devices AD1854 1 bit cheaper AD1855 1 bit AD1955 1 bit odnobitnik good, one of the best one-bit from Analog Devices ————————————————– Kad bi svugde bili standardizovano isti izlazi - i na strimerima i na CD plejerima i na DAC - razlika bi bila 0 Pošto NIKADA neće kod svih biti isto - uvek če sve razlićito da svira. Ovo isto važi i za gramofone. Svi se čuju raličito u zavisnosti od prateće opreme. Nikada nigde nisam čuo isti zvuk. Čak i na istim uređajima jer su ambijenti drugačiji.... Slilčno nije isto.
  4. Mikorist
    Filmovi koje volite
    ako nema Bambula - dovoljno je naći eng subtitl a onda Translate Subtitles TRANSLATESUBTITLES.CO FREE online subtitle translator can instantly translate srt subtitles from one language to the other language. kad nema nikakav titl i ovaj je super
  5. ninja
    Audio fajl server, Izbor računara
    Imaš još jednu opciju
  6. Ova lista je cist marketing - da ne kazem bullshit. Qobuz ima ubedljivo najbolji zvuk, ali i dalje dobrano kaska za streaming-om sa lokalnog servera.
  7. Kvalitet sadržaja je problem.
  8. Dobre pokretne slike, koje volim, mogu da gledam, i gledao sam, i gledam, skoro svakodnevno, sa uživanjem i u crno-belom. Poruka se prenosi i bez poštapala. Jeste, boja je poslednji doprinos koji je, zaista, uticao na poruku. Kao i kod knjiga...
  9. Nešto se ne bih vratio sa HEVC/H.265 Dolby TrueHD 7.1 with Atmos - na VHS Ili sa laserskog 4K filmskog projektora sa HDMI ulazima na projektor sa žaruljom i analognom filmskom trakom.
  10. Ista stvar je i sa video zapisima. Sa naglaskom da e bolje razvijaju video kodeci od audio. Filmska industrija ih gura. Recimo HEVC/H.265 kompresija. Ista stvar pustio ga preko striminga ili direkt sa SSD HEVC/H.265 sa nagalskom na 10bit x265 - Wikipedia EN.WIKIPEDIA.ORG
  11. vladd
    Pa to ti pricam, kvalitet je bazicno nizak, pa je sve ostalo kako god. Nikakav sistem ne moze iz ofrlje i na marginu bacenih pa odradjenih protokola da izvuce vise kvaliteta nego sto mu se servira... Moze Hamilton da vozi ficu, ali do plafona mogucnosti, takodje moze i neki dziber da vozi F1 pa da puzi.
  12. Pa Niški zvučnici i služe za spaljivanje.
  13. nznm dal' je kod W. to na default na fifi danas kad udjoh kod njega, ko da je sviro tranzistor, Sanyo, "27 transistor", sa sve 1.5" speaker 'bo streaming
  14. Eh, osim sto sam naucio da postoji USB grill, danas sam naucio i da postoji dugme na Tidal-u, koje nije bilo pravilno podeseno... Bilo na "normal" pa sam odma prebacio na "HiFi" . Zvuk se znatno popravio, sa "shit" na "ovo i nije tako lose"...
  15. shonne
    Filmovi koje volite
    The Batman, ko je propustio u bioskop, za 7 dana HBO...bice i torenta 😁
  16. zerowaf
    Ima tamo još dva izdanja. Jedan je Pablo rip. Probaj to. Mislim da je kad uđeš, na polici desno odmah prvi.
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 2158 Gosta (Pogledaj celu listu)
