NIXIE Napisano Decembar 28, 2017 #45 Napisano Decembar 28, 2017 6 hours ago, zek said: Imaš jeftinije, a možda i bolje, Alientek D8 sa Xmos usb-om (Siroma ima jedan takav). https://de.aliexpress.com/item/ALIENTEK-D8-SMSL-Pro-Pure-Digital-HiFi-Amplifier-USB-Fiber-Coaxial-Optical-Audio-Power-XMOS/32583670076.html?traffic_analysisId=recommend_3035_21_83087_iswiall&scm=1007.13338.83087.0&pvid=3e960669-d090-4a0c-b0b1-eb157f7bb8f8&tpp=1 Taj valja.
skrstic Napisano Decembar 28, 2017 #46 Napisano Decembar 28, 2017 https://www.aliexpress.com/item/New-arrival-Feixiang-FX-AUDIO-FX502SPRO-HIFI-Audio-Digital-High-Power-Amplifier-TPA3250-NE5532-24V-4A/32840778541.html?spm=2114.search0104.3.8.3N2XLo&ws_ab_test=searchweb0_0,searchweb201602_1_5130011_10152_10151_10065_10344_10068_10342_10343_51102_10340_10341_5000011_10084_10083_10307_5080011_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10605_10594_5060011_10107_10142,searchweb201603_32,ppcSwitch_5&algo_expid=e5d1942c-de73-4157-bc0d-a536adcb61fe-1&algo_pvid=e5d1942c-de73-4157-bc0d-a536adcb61fe&rmStoreLevelAB=5 Pchelac je reagovao/la na ovo 1
Pchelac Napisano Decembar 28, 2017 #47 Napisano Decembar 28, 2017 Opa, skutijan za 60ezdesetak dolara, best buy samo tako. Za te pare, naravno.
sir Oliver Napisano Decembar 28, 2017 #48 Napisano Decembar 28, 2017 Evo nešto a da nije kosooko https://www.hifikulma.fi/epages/hifikulma.mobile/fi_FI/?ObjectPath=/Shops/FOHI/Products/ArgonDA2&Locale=fi_FI
misa Napisano Decembar 28, 2017 #49 Napisano Decembar 28, 2017 I tako covek trazio A klasu a dosli smo do D klase. Ne smem ni da mislim koliko ceda izadje krajnja cifra ako prelazi 50Eur. Spedicija 60-70Eur + carina + PDV Pozdrav Misa crni. and Beli_Ninja je reagovao/la na ovo 2
NIXIE Napisano Decembar 28, 2017 #50 Napisano Decembar 28, 2017 6 minutes ago, misa said: I tako covek trazio A klasu a dosli smo do D klase. Ne smem ni da mislim koliko ceda izadje krajnja cifra ako prelazi 50Eur. Spedicija 60-70Eur + carina + PDV Pozdrav Misa Pa kad oće A klasu za 200E. Po meni za te pare samo gainclone prolazi. Kinezi pišu na paketu 10-15 dolara vrednost, ako je mali paket (a jeste) nećeš naj verovatnije ništa da platiš ili će ofrlje da ti rebnu neku siću. E ako ti se posreći da proveravaju onda moraš da im dostaviš confirmatiom email da vide koliko si stvarno platio, onda ide 10% na ceo iznos pa na sve to zajedno još 20% i neki njihovi troškovi. Meni se to samo jednom desilo od par desetina paketa, tako da i dalje naručujem bez straha sa svesnim rizikom da ću ponekad da naj...
grau. Napisano Decembar 28, 2017 #51 Napisano Decembar 28, 2017 4 hours ago, skrstic said: https://www.aliexpress.com/item/New-arrival-Feixiang-FX-AUDIO-FX502SPRO-HIFI-Audio-Digital-High-Power-Amplifier-TPA3250-NE5532-24V-4A/32840778541.html?spm=2114.search0104.3.8.3N2XLo&ws_ab_test=searchweb0_0,searchweb201602_1_5130011_10152_10151_10065_10344_10068_10342_10343_51102_10340_10341_5000011_10084_10083_10307_5080011_10312_10059_10313_10314_10534_5790011_100031_10604_10103_10605_10594_5060011_10107_10142,searchweb201603_32,ppcSwitch_5&algo_expid=e5d1942c-de73-4157-bc0d-a536adcb61fe-1&algo_pvid=e5d1942c-de73-4157-bc0d-a536adcb61fe&rmStoreLevelAB=5 a dje mu daaac?
Pchelac Napisano Decembar 28, 2017 #52 Napisano Decembar 28, 2017 Mnooogo je , kume,... za ove pare...
skrstic Napisano Decembar 28, 2017 #53 Napisano Decembar 28, 2017 3 hours ago, grau said: a dje mu daaac? Čovek tražio pojačalo u A klasi. Predlagano sve i svašta i ja predložio jedno.
aaa zmaju! Napisano Decembar 28, 2017 #54 Napisano Decembar 28, 2017 Upito na prvoj stranici i više se nije javio, pobego kad je vido predloge skrstic and sir Oliver je reagovao/la na ovo 2
mrspis Napisano Decembar 28, 2017 Autor #55 Napisano Decembar 28, 2017 Resio sam sa covekom oko daca. https://www.kupujemprodajem.com/nelson-pass-frst-wat-54733013-oglas.htm ovo mi je trenutno najprimamljivije i najverovatnije uzimam. Imaju slike otvorenog. Da li je kvalitetno uradjen i koja je snaga ne znam jos uvek ali cu otici da cujem prvo svakako. Hvala za link
крокодил Napisano Decembar 28, 2017 #56 Napisano Decembar 28, 2017 Ovo je sa cevnim pretpojacalom za 120 evra ? Cini mi se da je to dobro napravljeno, iako poprilicno neuredno.
vladd Napisano Decembar 28, 2017 #57 Napisano Decembar 28, 2017 Jeste neuredno, ali je cena niska, pa ima prostora da naknadno, na ratice, ulepsava sprave. A odmah ce da radi, bez da nesto svajsuje.
Dacho Napisano Decembar 28, 2017 #58 Napisano Decembar 28, 2017 Nisam bas siguran da se za 120€ uopce mogu kupiti dijelovi... Jeste primjetili da ima manje hladnjake na tranđama pa onda dodane još jednom veće...zanimljivo.
NIXIE Napisano Decembar 28, 2017 #59 Napisano Decembar 28, 2017 38 minutes ago, Dacho said: Nisam bas siguran da se za 120€ uopce mogu kupiti dijelovi... Jeste primjetili da ima manje hladnjake na tranđama pa onda dodane još jednom veće...zanimljivo. Meni sve deluje onako sklepano. Možda je bilo na izdisaju zbog pregrevanja pa je dodavao hladnjake. Beli hladnjaci su bar 30% manje efikasni od crnih.
ninja Napisano Decembar 28, 2017 #60 Napisano Decembar 28, 2017 5 minutes ago, NIXIE said: Beli hladnjaci su bar 30% manje efikasni od crnih. !!!!!!!????????? Glupost.
zeljkor Napisano Decembar 28, 2017 #61 Napisano Decembar 28, 2017 Stefan-Boltzman law describes radiative heat transfer: Prad = 5.7 * 10^-8 * E * A * [(Ts)^4 - (Ta)^4] in watts where: E = emissivity black anodized aluminum E = 0.9 polished aluminum E = 0.05 A = surface area (m2) through which heat radiation emerges Ts = surface temperature (K) of component Ta = ambient temperature (K)" NIXIE je reagovao/la na ovo 1
ninja Napisano Decembar 28, 2017 #62 Napisano Decembar 28, 2017 Znam ja vrlo dobro sta je radijacija.
sir Oliver Napisano Decembar 28, 2017 #63 Napisano Decembar 28, 2017 Znači 18 puta Što je čak i više od 30% Ko ovdena lupa gluposti? NIXIE je reagovao/la na ovo 1
NIXIE Napisano Decembar 28, 2017 #64 Napisano Decembar 28, 2017 8 minutes ago, ninja said: Znam ja vrlo dobro sta je radijacija. Nemaš ti pojma Heat sink data.pdf Beli je reagovao/la na ovo 1
NIXIE Napisano Decembar 28, 2017 #65 Napisano Decembar 28, 2017 Kod pasivnog hladnjaka postoji odnos odvođenja toplote konvekcijom i zračenjem, što je manji i topliji hladnjak sve više se diže efikasnost odvođenja toplote zračenjem primenom eloksaže (zeljkor je lepo prikazao razliku natural-black anodised koja se odnosi na odvod toplote zračenjem) tako da može razlika u ukupnom koeficijentu da bude i do 45%. To je naročito bitno od A klase, gde i 10% veća efikasnost znači par kila manje aluminijuma. Naravno ne sme se farbati (to je izolacija), mora eloksaža da se radi koja je ekstremno tanka. Kod prinudne ventilacije smanjuje se % radijacije, a povećava % konvekcije pa je razlika mala, ispod 10% zato su kuleri sa ventilatorom uglavnom beli (natural) i nema mnogo vajde od eloksaže.
ninja Napisano Decembar 28, 2017 #66 Napisano Decembar 28, 2017 Super, sad imas recept kako kod kuce da ustedis 30% na grijanju a sir jos vise. Pogledaj totalni balans pa vidi koliki je uticaj radijacije u hladjenju. Beli, vladd and vinko je reagovao/la na ovo 3
