Windows 10, Windows 7 i ostala WIN familija
shonne
Najdalje što neko "običan" ode da čvrčka po BIOSu je da overklokuje proc i memoriju...
nikom ni ne pada na pamet da ga dira. moze i na mrtvo da se ubije ploca - ko ne zna sta radi.
a ovi ladno imaju u katalogu  tool koji remote fleshuje BIOS sa malware payloadom .
druga elegantnija varijanta je da ga neko direktno u Kini  flashuje jos na traci sa sve malware-om.   :buehehe:
Čuj, postoji osim www i deepweb ali i darkweb... Korisiš li standardne pretraživače, nikada te neće odvesti ni blizu ova dva potonja. A tamo je mračnije nego u srcu Darth Vadera...
There's a difference between the "Deep Web" and "Dark Web." While the "Clear Web" is the surface area which is indexed by search engines such as Google and Yahoo, the Deep Web is an area search engines can't crawl for or index. Plunging in further, the Dark Web is a small area within the Deep Web which is intentionally hidden from discovery.
You can't use standard access methods to gain entry into the Dark Web. The most common method is through the Tor network, an anonymous network created from nodes which disguise online activity. In order to use Tor, you need the Tor browser, and may also need to be issued an invitation to access certain .onion domains hidden within the Dark Web.
An .onion address is the result of Onion networking -- low-latency communication designed to resist traffic analysis and surveillance. The use of Onion networking is not a perfect solution to maintain anonymity, but it does help disguise who is communicating with whom.
  • 4 nedelje kasnije...
  • 3 nedelje kasnije...
