ZZZ
Sve objavljeno od ZZZ
  1. u tim kabinetima su bile identicne sekcije skretnice za LF WE 2080E i i HF WE2390A i to 8uF paper in oil + 5 - 5.13 mH kalem i neverovatnih oko 1 om Rdc, sto je jako lose... takodje klimav i loseg Q faktora... Kondenzatori stari i na izdisaju mada naoko deluju kao novi... driveri su 15 oma (Rdc 12 oma cca.)
  2. Evo malo istorijata iz prve ruke . About Westrex speakers by Dave Fenner . "...First in reply to others about origin, I should have said, it is fact that all the 2080 and 2090 drivers had transfer label 'Made in England'. I dont know where or by whom, maybe Vitavox or BTH or even Goodmans? . "...The point is that this is not a bare diaphragm. Be that as it may, fact is Westrex's unit rating was 30 watts continuous and it is clean all the way. I suspect it would bust without the 'book' but wouldn't want to risk trying it (around £50 for new one, still available from Lansing!). I can assure you acoustic output is plenty high enough in a small hall (but probably wouldn't survive for todays pub gig levels)." . "Westrex Book Radiator I was a field engineer at Westrex, my patch was NW London. I left to set up my own company and Westrex were my main Distributor, so I was often in and out of the Works at Coles Green Road. The following paragraph is not for the squeemish. . Most UK cinemas using Westrex sound and projection equipment were on a lease plus service contract, the gear was owned by Westrex. During late 60's cinemas were fast being converted to multiples, bingo halls or bowling etc, so masses of equipment was being removed. Having no storage space they put large skips behind the works. These were daily filled with 2040 40 watt tube amps (best ever), 2080 bass drivers and 2090 drivers and horns, and sold as scrap. Bass bins were broken up on site. Crying is allowed. . One day when visiting I saw lying by the skip a 2090C driver complete with Book Radiator. I grabbed it and remarked to the warehouse manager (Mr Bill Diamond) 'pity there is not a pair'. 'Wait',we are having a clear-out' he said and went inside and returned with another, which was obviously a prototype, having a rough looking makeshift bracket for mounting but otherwise identical. . I beleive these speakers as shown here were intended to superceed the original Acoustilens model, I cannot be certain but few if any were sold, in which case they are extremely rare. The only ones I knew of were owned by a very few of my fellow engineers. The guys that had them were the cream of the West End sound men, like Gorden Isaacs and Billy Bell. I heard them on a system consisting of a pair of 2040's, a Decca FFSS cartridge and tone arm. I never heard before or since such gorgeous quality from vinyl. But I must say the best systems I ever heard were the circa 1954 4 track mag Cinemascope movies with 3 Westrex bins with cellular horns. Its all gone backwards since. It is no surprise to me that efficient speakers sound far better, its the tight control by the huge magnets and small accurate gap, and stiff ouput of the transfomer coupling, damps overshoot and flapping around. . Back to the Book Radiator; I do still own the original prototype. At one time I pondered copying the perforated sheild and the Book 'pages' and offering them as conversion kit for 2090A. Too old to bother now. I am not familiar with the type number 2390, my memory is fading but as I recall the original horn driver was 2090A (24 ohms) and 2090C (15 ohms and no phase plug) but I could be wrong. . As you may know, if you put LF power to an unmounted bass driver, no loading to control it, it will likely bust the spider and surround. An HF pressure driver with no horn will do the same, fly to bits. Thats why they are tightly bolted up with a gasket. Failure of these drivers is often result of blown seal. If HF diaphragm was left bare with no horn load it would only be able to work at low level without damage. The name Book Radiator is the clue; you cannot slam shut a book however hard you push, you are working to push out the air. Thats what the leaves are for, to load the thing so it has some work to do. The perfotated shield holds the leaves in place and restricts overshoot. . This may be likely reason crossover frequency of these units was raised to 1000hz (Acoustilens was 675 i think, cinema horns were 500)."
  3. ma nisu zvucnici sami po sebi sigurno nego nesto drugo velike su povrsine drivera tu je mereno mislim driver gore i dole ali su oba u isto vreme radila verovatno su bili i veci signali pa soba i mikrofon otisli u zasicenje ali mislim da je zbog velike povrsine drivera to je mereno pre svega da se vidi gde aktivna skretnica reze i kako reze... A sto se tice ovih WE 2390A ima ovde na forumu u temama http://www.diyaudio.rs/topic/1272-iskra-ez1606/page-2 http://www.diyaudio.rs/topic/1617-merenja-nekih-horni-i-drivera/?hl=lenses#entry31843 a mislim da ima fotki i jos u nekoj temi ali ne mogu da nađem.
  4. FF su oba nije toliko vazno posto mislim da je islo u zasicenje elektricnog signala mislim da je lepio vu metar malo pa zato izgleda ravnije nego sto jeste medjutim ono sto vi ne gledate su izoblicenja a ona su velika
  5. migty jupii nisam ni znao da postoji ploca super
  6. ZZZ
    Nepoznati Zvucnik
  7. ZZZ
    Nepoznati Zvucnik
    Video sam uzivo jedan lesli, ali nisam cuo u akciji to legendarno cudo, bas mi je krivo jel ima mozda nekih snimaka gde se jasnije moze cuti lesli u akciji? . Banat mislim da je taj driver poreklom Isophon ne nagadjam ima tu isophon sivu boju, i izolaciju na zicama zuta i crvena po tvojim fotografijama to je ta boja i nijansa koju je stavljao isophon a kod drugih proizvodjaca to nisam primetio dakle isophon ili TFK ali je isophon radio za TFK.
  8. USB veza je balansirana veza podaci + i - napajanje +5V i masa . I dobra je onoliko koliko je transmotter u racunaru dobar i onoliko koliko je kabl manje kapacitivan naravno da fabricki kablovi nisu najbolje napravljeni bez obzira na to koja im je cena . najjednostavnije je napraviti korektan kabl na sledeci nacin 2 parice twisted pair shirm izolovani kabl zice unutra na + i - pinove podataka shirm samo sa jedne strane na masu recimo sa strane racunara. + isto moze da se posebno izvede recimo obicnim koaksijalnim gde je + napajanje zica unutar shirma a - ili GND kosuljica ova 2 kabla koji ne moraju biti pendrek debeli vec normalni tanji mogu se ubaciti u termo buzir i to je to nema udvajanja masa, sve je izolovano, manji return i sve je bolje. za dugacke kablove ISTO to SAMO se doda dobar i kvalitetan balansirani transmitter- receiver posle racunara to je onaj repeater sto se spominje... . Sada sve zavisi od protokola i softwarea koji to drzi na okupu . USB je jednosmerna pruga po kojoj idu 2 voza koji nose postu da bi je dan prosao drugi mora da stane. vozovi prenose posiljku u paketima i to ne mogu da urade odjednom. kada se paketi isporuce putuju izvestaji da su aketi stigli i to u oba smera. Tada se isto sve zaustavlja. . Firewire je u tom smislu bolji jer ima 2 koloseka
  9. Zocky pardon nisam lepo napisao dodatno rasprezanje PRE shunta jos par CL clanova gde L moze biti i na feritu na primer neki ferrite bead koji podnosi 4-5 X vecu struju nego preamp... A trafo po mogucstvu sa C.T. tackom . aki prvo je ovo oko masa glava - rucica - chasses 3 razlicite tacke
  10. mrzi me stano da prebacujem na razlicite fontove ok u pravu si
  11. prva stvar oko bruma je da odvojis nekako masu rucke cejsis ground-a i mase kanala imas tamo 3 mase na gramofonu bez obzira koliko gramofon kosta uglavnom su spojene sve u jednu tacku na sasiji gramofona to bi trebalo da se odvoji audio mase kanala na rca konektor - odlemiti od sasije a takodje bi trebalo i ako je moguce izolovati metalnu rucku od sasije masa rucke je ustvari pravi audio ground a + i - na glavi su balansirani izalzi... . Moze da radi i u kvazibalansiranom modu - sa galve i masa rucke u jednu tacku ALI ne i na cejsis ground. . bolja filtracija pre shunta, moze i par feritnih prigusnica sa kondenzatorima izmedju ne velike vrednosti C iste kao i na shemi...
  12. kad je vec napon napajanja 24V mozda je trebalo probati sa baterijom?
  13. nije to nego najverovatnije vremenske konstante networka drugo, jednostvno tesko se reaktivno kolo da se drivuje na taj nacin ispred pasivnog neta bi trbalo da bude buffer, kao i na izlazu preampa to jako smanjuje vrenosti spe+reznih kondenzatora na oko 100nF do 220nF uz osgovarajuce Rgrid jfetova . probqj da otpor R4 prema masi 2 jfeta prebacis iza spreznog kondenzatora C1 2 jfet ce imati i dalje biasing... i povecaj na 330K-470K . kond na izlazu neka bude 10uF onda moze da primi vise razlicitih opterecenja a zadrzi propusni opseg na dole . probaj jos vecu totalnu impedancu kola 10x veci otpori 10x manji C vrednosti C su velike i to obara sleeve rate samog kola (mada je slleve rate kantelivera mali...) .
  14. ako porucujete trafo uputnije je da budu samo sekundarni namotaji uradjeni primar nije potreban posto se ne koristi. vrednosti ove druge 2 prigusnice su kriticne i trbalo bi da budiu sto manje Rdc ispod 0.2oma . Ne pali to otpor + Rdc prigusnice da daje neku vrednost, nego prigusnica mora biti zsto cistiji L element bez C i R. To vazi i za R i C kako ovde tako i u svim skretnicama... jednostavno mnogo bolje zvuci i isplati se uloziti novac u kvalitetnije prigusnice.
  15. ZZZ
    ClassD TI TPA3110
    laboratorijski benzin moze da se zameni medecinskim. koristi se sa ciscenje mesta oko rane i za skidanje lepka od flastera i platnenih selotejpa. ima ga u onim specijalizovanim radnjama za medecinsku opremu a verovatno i u apotekama? vrlo je cist ne ostavlja tragove, brzo isparava i solidan je ne previse jak rastvarac. Skoro sam video u Palmoticevoj ulici u BG u radji za medecinsku opremu, 30m od skupstine na dole, sa leve strane. pakovanja od 1l cini mi se oko 700din?
  16. : dire stratis neko holandsko izdanje i domace izdanje, potpuno 2 razlicite ploce...cccc...
  17. ++ za london calling sad cu da ga potrazim mislim da ga imam jos uvek
  18. jeste u pravu si 8 oma su
  19. @prophetnije alnico posto sa tim membranama sa koncentricnim krugovima idu oni "pasteta"crveni msgneti. Samo na ravnim membranama su alnicoa i da jesu alnico ne bi mogao da prebacis na one tvoje iskre posto se razlikujemagnetni procep za 8 i za 16 oma verziju. Tvoje je 8 oma verzijaa ti alnico magneti sa tim gapom za 8oma su mnogo redji...A jel ima jos 1 kom 14in iskra 16 oma sa membranom koja nije pocepana?
  20. jao video sam sada kako dobro izgledaju... fenomenalno. . nesto razmisljam danas retko koji zvucnik ima ovakve lepe kleme na zavrtanje i retko koji automobil ima one lepe niklovane lajsne...
  21. imam ja takva 2 neverovatno ali potpuno nova basica 12in 16oma ali Wigo sa "crvenim" magnetom kao na iskra 14in
  22. ZZZ
    DIY LCR Riaa
    nedoumica oko cena pa idite brate na neki online konverter valuta jeste ovaj nemacki skuplji za oko 100EU po komadu od sowterovog. I to ona jeftinija varijanta valjda sa obicnom zicom? ko sto guja rece ova znacajno skupla verzija je sigurno motana nekom svemirskom zicom ili su i druga jezgra i to bez prethodne provere ove jeftinije sigurno nije preporucljivo nabavljati? . ovo su potpuno razlicita kola - sowterr klasicna od 600/600 niskoimpedantna i zahteva dobar driver, a nemacka visoko impedantna reda 10K i daje mnogo vecu mogucnost izbora cevi i opterecenja... nemacka je teza za izraditi jer su vrednosti induktiviteta vece a potrebno je odrzati i sto manji kapacitet u isto vreme otuda i ona podela na vertikalne sekcije kalemskog tela,,, pa i razlika u ceni verovatno... . klasicni LRC network se dobro ponasa na simulacijama ali samo sa predvidjenim vrednostima in/out 600/600 ne mora bas precizno ali vrednosti oko tih... I naravno ima istorijsku vrednost posto je konstrukcija jako poznata i retka u kucnoj upotrebi. ovaj nemacki nisam pokusavao da simuliram u kolu ali najverovstnije isto radi dobro. . Tako da je bas steta Neskore ako to ne zavrsis, kad si vec skoro sve napravio? A radice sigurno vrlo dobro i tako po ovoj shemi koju si dao... Ipak bi mozda trebalo ubaciti katodne otpore barem da podignu abs negativni prednapon na 150-200mV ...
  • Trenutno na sajtu   2 članova, 2 Skrivenih, 1584 Gosta (Pogledaj celu listu)
