NIXIE
Sve objavljeno od NIXIE
  1. NIXIE
    Lepota dizajna
    This T1610 tube itself is a thing to behold. It is around 13 inches tall (presumably to accommodate the parallel triode elements mentioned above) and is capable of putting out up to 50 watts of pure, single-ended class-A power. The tubes are beautifully made by hand using thick, artisan-blown glass and shiny brass bases. Each one is a work of industrial art; I had never before seen anything like them! I figured that they must be expensive, so I asked about their typical life span. I was assured by both Drs. Kron and Smith that these tubes last from 8,000 to 12,000 hours, and virtually no amplifiers using the T1610 have had to be re-tubed. Not a bad track record, given that the first amplifiers using this tube were sold in the late 1990s.
  2. Nema slike, samo komentar. I get all my resistors custom made now. They're made of the carbonized finger bones of red-tailed squirrel lemurs, from southeast asia. They cost me $800 each, but the high end is so silky and smooth. Nothing else can compare.
  3. Nemoj menjati pot,samo mu stavi 10k u paralelu i umesto 550 oma stavi 270 ili dva od 550 paralelno
  4. Nije za prodaju.
  5. Pošto sam u međuvremenu pravio sitnije izmene, evo konačnih šema. Više neću ništa da menjam, bolje od ovoga teško može da se izvuče. Prilažem i radne tačke za 6N3P i 6N23P (za konkretne lampe koje sam probao). Izmene su bile sledeće: 1. Potenciometar za balans je nov 50 klin, namenski za balans, nema deliteja na ulazu, radi prigušenje samo od sredine levo i od sredine desno. Kad stoji tačno u sredini nema nikakvog prigušenja. 2. Izlazni kondenzatori su sada Jantzen Silver Z 3,3uF 800VDC. Razlika u odnosu na one obične PP je kao nebo i zemlja. 3. Grid stoperi su sada 1k metal film (sugestija ZZZ), nisam primetio nikakvu razliku u zvuku ili šumu odnosu na 300oma MF, to su igre na MHz. Nemam osciloskop da vidim jel se šta događa. Mogu se stavljati i carbon film ko voli mekši zvuk. 4. Katodni otpornici su sada 180 oma metal film, malo je bolji zvuk nego sa 270 oma metal oksid. Nemojte stavljati MOX za ovu namenu, tu sam pogrešio, sviraju lošije. Mogu se stavljati i carbon film ko voli mekši zvuk. To bi bilo to, iscrpljena je tema. Ko hoće da čuje ovo u svom sistemu, možemo se uvek dogovoriti.
  6. Imam ja malog LEACH-a, V4.5 ali 80W RMS/8oma, mogu da upišem elemente koje sam izmenio u originalnoj šemi ako treba. Napajanje je +-50VDC. Imam negde i film za pločicu ako nije propao od stajanja. Imaš i onih APEX-a te snage i napajanja.
  7. NIXIE
    Iron Pre
    Evo ovako sam mislio. Ograđujem se od kvaliteta zvuka jer nisam probao.
  8. NIXIE
    Iron Pre
    Znam da sam negde video pre par godina. E sad dal to valja, mislim kako ta šema zvuči, nisam probavao. Samo sam dao predlog kako može jeftino da prepravi svoj preamp, ništa više. Ovako mu i onako ničemu ne služi.
  9. NIXIE
    Iron Pre
    Nije tako, nego se umesto anodnog otpornika od 30k u slučaju Shine 7 stave na red recimo 4 kom. 7k5 pa uzme signal za sledeći stepen recimo na spoju prvog i drugog, itd. Kako si bliži anodi tako je signal veći i obratno kad si bliži napajanju signal je manji. Malo raste izlazna impedansa ako nisi uzeo sa anode nego negde sa delitelja ali sledeći stepen ima veliku ulaznu imedansu pa nije bitno. Sad je kasno, nacrtaću sutra na poslu.
  10. NIXIE
    Pioneer DV610 prepravka
    Slažem se. U tom slučaju bi trebalo i neko bolje napajanje za buffer jer tu za OP ima dovedeno samo 12 VDC i to jednostrano. Dobar je taj DVD kao transport, čita apsolutno svaki disk. Kupio sam ga za filmove i nisam ni znao šta imam dok Fikus nije prepravljao onaj DV300 gde se vidi savršeni SPDIF signal. Pošto je ovaj srebrni, a sva ostala oprema je crna, kupio sam skoro na KP jedan DV300 kao nov za 20e, crni naravno, a ovaj čuvam kao rezervu. Za DV300 planiram da izvedem digitalni izlaz po Fikusu.
  11. NIXIE
    Iron Pre
    To sam video negde na ovom forumu, mislio sam da može tako.
  12. NIXIE
    Babelfish F7
    Ko bi izdržao. Pojačalo samo uključim kad treba, a može i da se isključi.
  13. NIXIE
    Koji cassette deck?
    Tehniks mi dobro izgleda, cena 140e, spustiće on još malo sigurno.
  14. NIXIE
    Babelfish F7
    Ja imam jednu ženu i nekoliko pojačala. Jel to opasno?
  15. NIXIE
    Iron Pre
    Vidi nije taj Shine 7 nešto posebno, čist klasika, ali nije ni tako loš. Šta te košta, već imaš pločicu, kutiju, lampe, napajanje, mala prepravka za vikend. A izlazna impedansa mu je mala, upravo to ti i treba. Ako ti treba manje pojačanje, možeš anodni otpornik u prvom stepenu da podeliš na više delova (recimo na tri-četiri vezana na red umesto jednog anodnog otpornika), pa da uzimaš signal sa onog izvoda koji ti odgovara.
  16. Vikend uradak, imao sam viška vremena. Ovaj DVD koristim samo povremeno kao DAC transport. Sad ga slušam jer je DIY DAC na upgrade-u i sprema mu se kutija za ugradnju, pa reko da malo unapredim zvuk. Pripremiti uzemljenu metalnu ploču na radnom stolu i uzemljiti majstora. Otkačiti pažljivo sve kablove, krajeve ribona ne pipati, najbolje ih je zamotati Alu folijom tokom izvođenje radova. Demontirati pločicu, pažljivo ukloniti C8040, C8058, C8041 i C8069 sa gornje strane (grejati i malo po malo izvlačiti nožice naizmenično, rupe su male i metalizirane). Usisati kalaj iz otvora. Pločica je kilava, treba raditi vrlo pažljivo da se ne odvoje vodovi. Ovako vezano ostaje očuvana funkcija mute na izlazu. Ukloniti obavezno i C8005 i C8006 koji su SMD i nalaze se sa donje strane. Ko želi može da odlemi i SMD OP, ja to nisam radio, mislim da nema potrebe. Može i sve da se premosti do samog izlaza (u tom slučaju odlemiti R8096 i 8099) ali onda nema više mute funkcije pa će se verovatno čuti malo jače cvrčanje DAC-a kada se ubacuje/izbacuje disk i verovatno povremeno slabiji cvrkut onako bez pravila kad se preskaču numere (primećeno na SPDIF izlazu s eksternim DAC-om). Ubaciti pinove (može savijena žičica, kao omča) u otvore na pločici gde su bili -polovi C8040, C8058, C8041 i C8069. Premostiti (od - do - pola) C8040-C8058 i C8041-C8069 PP kondenzatorom 3,3uF. Ja sam koristio BENNIC od 160V koji su fizički najmanji PP koje sam našao. Tu puno mesta nema, a i preko njih kasnije ide onaj beli ribbon tako da može da se desi da ne može on kasnije da se ubode. Sve fiksirati termo lepkom da se zbog težine kondenzatora ne odvoji vod na pločici. Zvuk je neuporedivo bolji od postojeće varijante, umesto muljavog zvuka u jednoj ravni, dobije se čist zvuk sa puno detalja koji dolazi iz prostora između zvučnika. Ovaj DAC (PCM1742KE) ima naponski izlaz, tako da mu ništa više i ne treba. Zvuk je malo tiši nego u originalu. Čak i ako se koristi kao DVD opet znači puno bolji zvuk na prednjem paru zvučnika. Ostale izlaze od 5.1 nisam dirao, i onako više mesta nema. Može se primeniti na sve slične DVD plejere iz Pioneer serija DV300,400 i 600, a verovatno i na druge modele koji imaju DAC sa naponskim izlazom. DV serije 300/400 su stereo, DV600 je 5+1.
  17. NIXIE
    Iron Pre
    Može malo da se popravi, izbaciš povratnu spregu, izbaciš treći stepen, a drugi stepen konfigurišeš kao taj treći (cathode follower). Pojačanje je u tom slučaju oko 16x, ali nemaš povratnu spregu i bolje će da svira sigurno. Recimo ovako, nije idealno ali je bolje od toga. http://www.shine7.com/audio/6922_pre.htm
  18. The Daniel Hertz M1 ($100,000/pair), designed by Mark Levinson (the man), uses a high-frequency horn, a 12” mid-woofer, and an 18” woofer. Read more at https://www.stereophile.com/content/daniel-hertz-m1#PUoUTytMWHeeXYx4.99
  19. NIXIE
    6V6 preamp ali nije Salas
    Po meni tako i treba, prvo grejanje 30-60sek. pa onda visoki napon sa zadrškom preko relea. Ispravljačice sa soft startom imaju to vreme reda 10-15sek., to je po meni prekratko. Recimo za 6N23P piše u datasheet-u da je za grejanje potrebno 30sek, za 6V6 nemam podatak, ali je verovatno nešto duže, staviću 60sek. Dodatni prekidač omogućava da se tej rele isključi čime imam mogućnost da samo grejem lampe, recimo kad su nove da ih ostavim dan dva samo na grejanju bez HV. Kada se gasi pretpojačalo, grejanje brzo nestaje, a visoki napon obično ostaje jedno vreme zavisno od kapaciteta kondenzatora, a to isto tako skraćuje lampama životni vek. Isti onaj rele koji preko tajmera pušta u startu visoki napona sada u trenutku isključivanja prespaja preko otpornika HV na masu i ukida visoki napon brzo. To je po meni optimalno rešenje od koga ne odustajem ni u ovom slučaju. Ništa to nije komplikovano.
  20. NIXIE
    Ove ruske 5c3s (za razliku od 5U4-GB) imaju taj babuška oblik, baš mi se sviđaju. Valjda nije problem što nemaju soft start, to ću lako da rešim otpornicima i relejima. Nadam se da trafo ima 5VAC sa tih 3A za grejanje.
  21. NIXIE
    6V6 Salas Preamp by Alex
    Baš su lepi ti Sonarquest carbon, debeli, ko prasići.
  22. NIXIE
    Ok slažem se ako je tako za uticaj ispravljačice na zvuk, nisam probavao ništa slično. To znači da ima još jedan parametar na koji treba obratiti pažnju, a znam da i oni šaht regulatori što ih je pravio Salas imaju isto dosta uticaja na zvuk. Ja sam mislio da ako je ispravljačica izolovana sa CLCLC ne može da ima neki veliki uticaj ako je struja približno konstantna, što je ovde slučaj. Promena je par mA kroz 6V6 kako se pojačava signal, meni ne treba više od 1,5V RMS na izlazu, to je oko 0,75mA RMS (2,12 mA P-P)na 2k anodnom otporniku. Otpornicima moram svakako doterati napon da bude 340VDC na 6V6. Ako te otpornike treba staviti između sek. trafoa i ispravljačice onda je to povoljno i za nju, moram videti koliki je pad napona na samoj ispravljačici. Struja kroz svaku 6V6 je oko 40mA, ukupno 80mA.
  23. NIXIE
    Ne znam ni ja puno o ispravljačicama, ali mi se dopada ideja da bude pravo lampaško, bez silicijuma (osim za grejanje 6V6, tu ide LM317 CCS kao što je uradio Salas). Takođe mi odgovara ispravljačica da malo smanjim DC napon jer trafo već postoji. Moram da proučim koje su kompatibilne ispravljačice da bih mogao eventualno kasnije da ih menjam. Ne znam sve podatke za trafo, ali znam da je motan za Salas 6V6 osim anodnog napona koji je izveden kao 2x340 umesto 2x310VAC. Mislim da ima dovoljno za grejanje ispravljačice, namotaj je 5VAC. Ne verujem da može puno da utiče na zvuk sama ispravljačica kod pretpojačala i pojačala A klase gde je konstantna struja, ali kod pojačala AB klase sigurno ima puno uticaja zbog promenljive struje. Mora puno toga da se proba, svako iskustvo je korisno. Ako ruska ispravljačica ima tvrđi bas i otvoreniji zvuk, negde će da legne u sistem, negde neće.
