Showing content with the highest reputation on 11/11/21 u svim oblastima
  1. Nesic
    Kupuj dok nije otišlo...
    [emoji846]
  2. Nesic
    Zar nije jednostavnije i povoljnije, recimo, malko pojačati visoke na eq no davati 4 cifre za kabl koji će uraditi isti posao [emoji846].
  3. shonne
    Pure DSD
    Aya 1 je isao sa 844, Aya 2 1612 i ostalo se zna... Mene lampe ne interesuju, a verujem da to dobro zvuci.
  4. 40-i km današnje rute, još oko 12 i doma smo...
  5. dobar kanal, izrazito https://www.youtube.com/c/TyrrellsClassicWorkshop/videos
  6. The Road to Escondido turns 15! Today marks the 15th anniversary of the release of JJ Cale and Eric Clapton's collaborative Grammy-winning, Gold record, The Road To Escondido. Eric Clapton noted that he had long been trying to capture the production sound and nature of JJ Cale’s releases on his own recordings, without success. At Crossroads Guitar Festival in 2004 (where Eric performed on JJ Cale's entire set with him), Eric told Cale about his intention to capture Cale's recording sound and told him that perhaps the only way he could get that sound would be if Cale produced his next record. Given Eric's huge audience, Cale was wary about taking on the responsibility for the sound of Eric's next record so he didn't immediately agree to do the project and considered the offer for a while. While Cale ended up accepting Eric's invitation, as the project moved forward, it became more of a co-production between the two artists. Cale also participated on the artist side as well, contributing guitar and vocals throughout the project, in addition to the fact that 11 out of 14 of the songs were Cale's compositions. Many songs by different artists had been suggested at the outset of planning for the record but Eric really wanted to use mainly JJ Cale songs. It was only after the album was "completed" that Eric suggested perhaps if Cale added a few more vocals and guitar on several of the songs, the plan could be revised to be released as more of a collaborative project than the original plan for it to be Eric's new record. In a somewhat surprising twist for Cale, who usually preferred staying in the background, he agreed, made the suggested additions to include more of his guitar and vocals and Eric then generously put Cale’s name first on the record. Listen here to "When This War Is Over" – a JJ Cale song with a straightforward message that touches on the unfortunately never-ending casualties of so many wars.
  7. neskor
    ovo je moja preporuka Rigol DS1054Z https://www.batronix.com/shop/oscilloscopes/Rigol-DS1054Z.html?yoReviewsPage=7&gclid=CjwKCAiAm7OMBhAQEiwArvGi3Ov-H3KNDgFHmTVcThhDnwfG093tk2yJQ1Z9hXNOuNI7lDpuOMaHqhoCsIEQAvD_BwE posle se SW otkljuca za 100Mhz
  8. Čuvaj si pare! S'g su pare skupe, s'g je oskudacija!
  9. Mikorist
    Slušalice na telefon
  10. Nesic
    Pure DSD
    AD844 je vrhunski za I/V, gotovo stvoren za taj posao. Diamond I/V je takođe ozbiljno rešenje, u par bitnih stvari čak ima i prednost.
  11. NIXIE
    Prihvata se, ako smatraš da to ništa ne valja.
  12. vladd
    Poenta je da svi na neki nacin tezimo nekom kvalitetu, sa igrackama kojima se igramo, i nebitno je sta kome godi, ali bas da je poslednji soder neka prilika za kupovinu merne opreme, tu ulazem prigovor, i tu treba ici na neki nivo, ili ne meriti, nema potrebe sebe natrpavati ni krsom opreme ni krsom pogresnih informacija.
  13. shonne
    Pure DSD
    Ne znam da li ces taj odgovor da dobijes na ovom mestu. Koliko znam samo ja i ti smo radili taj dac, a ja nisam hteo dalje da idem sa dacs jer me to puno ne interesuje. Video sta mi je bolje. Interesovanja su mi u amp i kutije.
  14. shonne
    Pure DSD
    Obrati paznju, cini mi se da u nekim ponudama on ima torusne izlazne trafoe...dal Aya 4... Na kraju se vratio na bjt, ili je dao sve opcije, pa ko kako voli.
  15. neskor
    Pure DSD
    mozda i ovo moze da pomogne discrette-iv-ad844-knockoff.pdf Pedja Rogic DDNF IV Stage.pdf
  16. neskor
    Pure DSD
    pre nekih desetak godina sam se igrao sa Ayom sa TD1541A, probavao na izlazu svasta, razne opampove, stekovani ad844 i na kraju najbolje mi je zvucao sa Sowter DAC trafoima i lampaskim stepenom
  17. NIXIE
    Nije.
  18. vladd
    https://www.aliexpress.com/item/32965859737.html?spm=a2g0o.productlist.0.0.1be4d976V6frSG&algo_pvid=7693ca06-f747-4d61-ab4b-f56a643e891b&aem_p4p_detail=2021111102383911674126641887820051934990&algo_exp_id=7693ca06-f747-4d61-ab4b-f56a643e891b-34&pdp_ext_f={"sku_id"%3A"66597728828"} https://www.aliexpress.com/item/4000222526874.html?spm=a2g0o.productlist.0.0.1be4d976V6frSG&algo_pvid=7693ca06-f747-4d61-ab4b-f56a643e891b&aem_p4p_detail=2021111102383911674126641887820051934990&algo_exp_id=7693ca06-f747-4d61-ab4b-f56a643e891b-32&pdp_ext_f={"sku_id"%3A"10000006192330661"} Bolje da se kupi ovo, više zabave za manje para. Ali tu funkcionišu neki uhodani kriterijumi kvaliteta, kod merne opreme samo "jeftino" Sa tim ultrajeftinim kineskim skopićima, ne mogu se napraviti dva identična merenja nakon nekoliko meseci, a ni slučajno posle godinu dana, pride, velika je sumnja da će da potraju toliki period bez problema. To je rizik i za potrebe da radi kao učilo, bez da se očekuju neka ozbiljna merenja. Značajno su kvalitetniji i pouzdaniji PC scope Imati da bi se imalo...mozda to je već drugi razlog.
  19. ninja
    Bio sajam u Göteborg:u 2010
    Evo tip zakacio proces pravljenja http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=97122
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 1840 Gosta (Pogledaj celu listu)
