Showing content with the highest reputation on 09/07/17 u svim oblastima
  1. The above statement is not quite correct:- Sorry No, this is wrong, Magnum was formed from my company MIH, which became Pro-Ac Magnum, then Tony Relph joined me as a business guru, then after 3 yrs managed after locking me out after a holiday stole the company and I was force to take legal action for use of some patents. and stealing my company. Meanwhile I started Inca Tech producing no electronics until the legal action was resolved but the world first Gold Plated Power Connectors for the audio world, now be warned never share a company 50/50 if you have started it you partner may not be so trustworthy as you. And for folk out there here is a rough list of other things I have designed. In order:- Pushpull 1 Germanium Amp 1971 V1 Tube amp 1972 12W Single Ended A Class 1974 MIH 100W 1975 MIH 400W ProAc stereo 100w 1980 ProAc 3 Channel 100W Magnum A100, 400W 1982 Magnum A200 Magnum Pre-amps IncaTech Gold Plated Power Plus and Sockets 1982 Inca Tech Sabre iss 1 1983 Inca Tech Prelude Inca Tech Claymore 1 1983 Inca Tech Claymore Gold Inca Tech Claymore S Inca Tech Claymore 2 Inca Tech Quatra Inca Tech FMT Tuner Inca Tech IT50,IT100,IT200 Inca Tech IT1P preamp Inca Tech Sabre iss 2 Inca Tech Dirk Inca Design ID25,ID50,ID75 Inca Tech MSB (a monster) Inca Design Oberon Classic Inca Design Oberon (standard) Lescon Quatra Oxford Acoustic's "Mystic" TOCA SECA 20W,50W,100W,200W,300W single ended class A,s 1995 TOCA I75 TOCA Pre A TOCA 75W Tellurium Q Cables 2009 Tellurium Q, A Class 20W, 100W 2011 Tellurium Q Headphone/Phono Amp Tellurium Q Pre-Amp EWA (Elsdon Wonfor Audio) A complete range of new designs after yet another twit full of greed stole by waiting for me to become very ill yet another company from my original company called Catch 22 then it became Tellurium Q. EWA have cables, Power Amps, Pr-Amps, SECA Amps. Read on:-http://seca.freeforums.net/ https://www.elsdonwonforaudio.com/ Products worked on Naim Nait 5i, other bits also for Naim and Cambridge Audio. 2008- 2010
  2. pa imaju li ti 8TC jedno recimo po 1m duzine barem?..hebate,imas monoblokove,i drzis ih jedno do drugog,ispod pretpojacala ..uzmi sve sto ti zivot pruza,kad ti je vec dato na tacni=monoblokovi sto blize zvucnicima,postavis ih lepo dole,tamo medj nogare od zvucnika,ides sa duzim intekonekt kablom u tom slucaju..msm to je po nekom starinskom receptu,koji mozda vazi jos i danas(?)..manji ti je gubitak na IC kablu,no na zvucnickom....smisli samo na sta ces da ih postavis,ako nista bar privremeno po principu "sve je bolje od uredjaja postavljenog direktno na pod" just my 2 cents...
  3. Nema potrebe za nervozom, zabava je u pitanju. Oslonac u tri tacke je preporucljiviji sto se stabilnosti i vibracija tice, ako ne smeta tezina sprave osloncima.
  4. ZZZ
    RCA LC1 kabineti
    Pa ja to skuplam cetvrt veka... pre bih rekao spora pravda
  5. Radite kako ocete, puca mi lakat. Ako odmah mora da poserete predlog koji se i javljate.
  6. Ja nisam. Sve normalno. OK. Ono oko kovanice REGA i dalje sve stoji, sto znaci da sinergija u tvom slucaju audio sistema nije kompromitovana. . . . . Engleski zvuk - sta je to zapravo ?
  7. Both were based on the MF250 and MP and MC 250 I did at Magnum.
  8. 1 poen
  9. Colin Wonfor
    Magnum mc 250
    Setting bias I have learnt for FET amps is a bit hit or miss. I load the amp with the current set to zero on the pre-set. Then a 10KHz signal is plug in so the the 8 Ohm load RESISTOR has just 2 Volts Pk-Pk You can then clearly see the Cross Over distortion on a scope. Adjust the pre-set with care until the distortion is gone, keep a careful monitor of the heat sink temperature and it is best a a ambient of 25C The Amp will sound amazing and run slightly warm and low levels. I hope this helps? Best Col
  10. Daleko je od zabave ovo pisanje po forumu, ali boze moj, svi smo mi masni.
  11. Ovo su moji predlozi ( naravno sve UK ) : CDP - Cambridge Audio CD 3 od vintage ( imam ga i sam ). 16 x 16 ( 4 komada 1541 Philips sa odlicnim CD transportom CDM1 MK II i dobro uradjenim napajanjem ) http://www.hifi-review.com/140023-cambridge-audio-cd3.html Od novih bih definitivno uzeo MF 1008 CD Pro ( najbolji ikada CD transport u njemu Philips CD Pro 2 , top loader, vrhunska konstrukcija, finish. Sonicno besprekoran. Ima ga moj dobar prijatelj koji je zaista promenio dosta CD playera novih ( Unison, NAIM . . . ) i zadrzao ovaj MF. http://www.hifi-review.com/152046-musical-fidelity-a1008-cd-pro.html DAC - nemam predlog ( ja sam sa DAC-om zavrsio jos pre 10 god. uzevsi od komshije njegov proizvod, ahhh, opet taj Miljakovac, Audial The Model DAC i ne razmisljam vise na tu temu ). Btw, sve cestitke na UK audio sistemu koji sklapas. Ima nesto u . . . Mozemo kasnije i o UK kablovima.
  12. Ne se siki riki ? pametujemo ? . Gospodin ima slatke probleme i sigurno će zbog "audifilisnervozis" probati sve varijacije na temu !. Ne razumijem zašto svi neakve komentare doživljavaju osobno ? , Pa to je sam forum di pojedine osobe pitaju , a druge im odgovaraju na osnovu osobnih ili neakvih drugih iskustava . Osoba kojoj je odgovoreno u miru svog doma radi što hoće ? . Znači , sam će procijeniti ko je što napisal i onda postupiti po vlastitom nahođenju . Bilo kakav antagonizam je bespotreban . NHF .
  13. potpuno nesvesno, za ovo nisam imao pojma ideja mi je da napravim neki engleski sistem...ostaje mi još cdp i dac oduvek sam voleo tkzv engleski zvuk...ne znam, sve i svašta sam probao, čuo, ponešto imao, ali njihova filozofija mi najviše leži...i koliko god razlike bilo među samim engleskim proizvodima uvek mi se nešto njihovo više sviđa od nečega drugog. dok se drugi lože za tehniksa ja za regu, drugi za zlatnog marantza ja za mf a1, drugi za jbl ja za proac...i tako je stalno bilo posle puno audiofilskog lutanja krug se uvek zatvori, vraćam se korenima i starim ljubavima...
  14. Oslonac u tri tacke moze i na ovim stalcima, a najstabilnije bez bojazni od klackanja u 4 tacke. BTW. Cestitke za novopridosle stalke, u uzivanju da se koriste.
  15. http://www.ajforeignauto.com/index.php?option=com_content&view=article&id=155
  • Trenutno na sajtu   4 članova, 1 Skrivenih, 1494 Gosta (Pogledaj celu listu)
