zbotic Napisano Decembar 6, 2014 Share #5325 Napisano Decembar 6, 2014 24 položaja. Opcionalno, do +6dB. Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano Decembar 6, 2014 Share #5326 Napisano Decembar 6, 2014 Tenx! Link to comment Podeli na ovim sajtovima More sharing options...
Zen Mod Napisano Decembar 6, 2014 Share #5327 Napisano Decembar 6, 2014 keka zelenih opa bato ......... drago mi je Link to comment Podeli na ovim sajtovima More sharing options...
Stradi Napisano Decembar 6, 2014 Share #5328 Napisano Decembar 6, 2014 Uz one drivere iz druge teme danas stiglo i ovo Saba Chelo ili Reso kako ko vise voli Ovo su inace kabineti koje je anubis opisivao da je slusao a Avangard stajao sa strane kod Cvetka tj mog prijatelja Bore Q.(ovo sam napisao zbog njega jer ga vezu lepe uspomene). Posle 2 godine garaze stigli kod mene. Zflazar je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
Okibokis Napisano Decembar 12, 2014 Share #5329 Napisano Decembar 12, 2014 Ovo planiram da koristim kao predpojacalo,ima i lampu i ekvilajzer i gain,i dva kanala.Spojicu ga sa snagasem kojem nisam znao nista pametnije da napravim kao preamp. Evo specifikacije,pa nije lose da cujem vase misljenje... The unit also offers a high-pass filter, with a sweepable range from 15 to 320 Hz, useful for removing rumble and low frequency handling noise, and a parametric EQ with adjustable center frequency, bandwidth and amplitude. Frequency switching allows the user to sweep the entire frequency range from 10 Hz to 20 kHz. The ULTRAGAIN PRO MIC2200 can also function as DI box, converting unbalanced instrument signals into clean, balanced signals. In addition to providing a soft mute function for the +48V phantom power, the ULTRAGAIN PRO MIC2200 provides excellent service when a need occurs to convert home-recording levels, -10 dBV, to +4 dBu level, for interfacing into professional environments. Extremely low-noise, dual microphone/line preamp Integrated high-quality 12AX7 vacuum tube Extreme bandwidth from 10 Hz to 200 kHz for open, transparent sound Two additional high-end parametric EQ's Fully sweepable, switchable high-pass filter (12 dB/octave) Soft mute function for +48 V phantom power suppresses switching noise Extremely flexible "Direct Inject Box" function Independent level conversion from home to professional level (-10 dBV / +4 dBu) Link to comment Podeli na ovim sajtovima More sharing options...
zika Napisano Decembar 12, 2014 Share #5330 Napisano Decembar 12, 2014 Sad ste me podsetili na ono to se meni (izgledom, nisam slušao) dopada od tog proizvođača: http://www.behringer.com/assets/T1953_P0040_S_EN.pdf http://www.behringer.com/assets/T1953_P0040_M_EN.pdf Okibokis je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
Okibokis Napisano Decembar 12, 2014 Share #5331 Napisano Decembar 12, 2014 Sad ste me podsetili na ono to se meni (izgledom, nisam slušao) dopada od tog proizvođača: http://www.behringer.com/assets/T1953_P0040_S_EN.pdf http://www.behringer.com/assets/T1953_P0040_M_EN.pdf Ovo je stvarno lepo,ne znam kog je kvaliteta zvuk,ali prednji panel je lep. Link to comment Podeli na ovim sajtovima More sharing options...
prophet Napisano Decembar 12, 2014 Share #5332 Napisano Decembar 12, 2014 Zar mikrofonski nemaju preveliko pojačanje? Link to comment Podeli na ovim sajtovima More sharing options...
Okibokis Napisano Decembar 12, 2014 Share #5333 Napisano Decembar 12, 2014 Zar mikrofonski nemaju preveliko pojačanje? Pa ima potenciometar za podesavanje osetljivosti Link to comment Podeli na ovim sajtovima More sharing options...
...sam se banovo Napisano Decembar 14, 2014 Share #5334 Napisano Decembar 14, 2014 U novu 2015 godinu sa 3 ulaznice (tata i sinovi) Link to comment Podeli na ovim sajtovima More sharing options...
Stradi Napisano Decembar 20, 2014 Share #5335 Napisano Decembar 20, 2014 Za lepsi docek 2015 te Stigli mono blokovi 2A3 , Taman za praznike da uporedimo SET vs Push Pull mislim ako se srede zvucnici do tada . Sada ce da ih slusamo malo na Nordmende nekim iz televizora. (izvinjavam se na ocajnim slikama ali sve pare odose na disko) Link to comment Podeli na ovim sajtovima More sharing options...
zerowaf Napisano Decembar 20, 2014 Share #5336 Napisano Decembar 20, 2014 Link to comment Podeli na ovim sajtovima More sharing options...
BANAT Napisano Decembar 20, 2014 Share #5337 Napisano Decembar 20, 2014 Kolegione Stradi Cestitam ti na novopristiglom paru SET pojacala ! --------------------------------------------------------------------------------------- i par pitanja : - Koja je marka uredjaja u pitanju ? - Kakvi su prvi zvucni utisci ? - Koje cevke koriste ti uredjaji osim 2A3 cevi . Pozdrav ! Link to comment Podeli na ovim sajtovima More sharing options...
Stradi Napisano Decembar 20, 2014 Share #5338 Napisano Decembar 20, 2014 Pa hvala Marku nema utisci super jos nemam zvucnike tek treba da se rade 6n7s. 6p9 i 5c4s (mislim da sam sve potrefio) salim se to su lampe na njemu i izlazna vec spomenuta 2A3 nadam se da je to ps jel mogu da ti se javim jednog dana ako mi treba pomoc oko njega jer kolko sam shvatio iz citanja po forumu da si na ti sa lampasima kao i jos neki ovde poznavaci.(ozbiljni). ps odoh da uzivam bar u gledanju, Sta ti je novo kad dodje u kucu . Air Tight se sepuri pored u svom sjaju svoga lica ali mora da prepusti malo novitetu svu paznju bar prvih dana Link to comment Podeli na ovim sajtovima More sharing options...
BANAT Napisano Decembar 20, 2014 Share #5339 Napisano Decembar 20, 2014 Kako je mehanicki dobro uradjen zaista sam pomislio da je u pitanju neki fabricki uredjaj ! , no sve jedno cak i ako je DIY zaista je sklopljen estetski Odlicno . ----------------------------------------------------------------------------------------------------------------------------------- Naravno da mozes da se javis uvek za pomoc oko tih lampasa , ipak Iskreno se nadam da ti nikakva pomoc nece biti potrebna jos dugo, dugo vremena ! Link to comment Podeli na ovim sajtovima More sharing options...
Stradi Napisano Decembar 21, 2014 Share #5340 Napisano Decembar 21, 2014 Evo malo boljih slika (bar na boljem svetlu) Link to comment Podeli na ovim sajtovima More sharing options...
grozni Napisano Decembar 21, 2014 Share #5341 Napisano Decembar 21, 2014 Auuu!!! Jedva cekam da ih cujem. Svaka cast. Ovako sa fotki izgledaju surovo. Srecno ti bilo i dugo ih slusao. Zavrsavaj kutije pod hitno . Za sutra spremi neke ploce, da mi ne kukas na izbor. Pozdrav Link to comment Podeli na ovim sajtovima More sharing options...
ninja Napisano Decembar 21, 2014 Share #5342 Napisano Decembar 21, 2014 Sretno sa njima Stradi! Nego, sta ces sa AT:om sad? Link to comment Podeli na ovim sajtovima More sharing options...
Stradi Napisano Decembar 21, 2014 Share #5343 Napisano Decembar 21, 2014 Nego, sta ces sa AT:om sad? U oglas, moze i zamena za nesto, zvucnici, auto itd... (ako ima interesenata javi ) Link to comment Podeli na ovim sajtovima More sharing options...
Stradi Napisano Decembar 21, 2014 Share #5344 Napisano Decembar 21, 2014 Za sutra spremi neke ploce, da mi ne kukas na izbor. Ajde bre, kada sam ja kukao (osim kad sam kod zubara). Hvala za cestitke Da ne zaboravim, kada dodjes Link to comment Podeli na ovim sajtovima More sharing options...
stein Napisano Decembar 23, 2014 Share #5345 Napisano Decembar 23, 2014 Rega RB250 zerowaf je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
Zen Mod Napisano Decembar 23, 2014 Share #5346 Napisano Decembar 23, 2014 kupio si dve rege ? Link to comment Podeli na ovim sajtovima More sharing options...
