Zen Mod Napisano Maj 28, 2011 #1 Napisano Maj 28, 2011 http://www.bcae1.com/http://www.sengpielaudio.com/Calculations03.htmhttp://www.lenardaudio.com/education/14_valve_amps.htmlhttp://www.allaboutcircuits.com/
Sipi Napisano Maj 28, 2011 #4 Napisano Maj 28, 2011 Daudio je u svojim blogovima zaista dobro i jasno napisao skoro celu pricu o el. cevima u audio tehnici. Ko zeli da bude u stanju da sam iskonstruise/optimizuje amp/preamp koristeci el. cevi ovo mu je vise nego dovoljno. Pokriveni su kako fundamentalni teorijski aspekti, tako i konkretna realizacija. - i sve to na cirilici...
Ја sam sam Napisano Maj 28, 2011 #5 Napisano Maj 28, 2011 За ћирилицу свака част а и за одлично штиво
Mikorist Napisano Januar 7, 2012 #6 Napisano Januar 7, 2012 http://www.tnt-audio.com/clinica/diycables.html
zika Napisano Februar 23, 2013 #7 Napisano Februar 23, 2013 Why You Hear What You Hear, An Experimental Approach to Sound, Music, and Psychoacoustics, Eric J. Heller, Princeton University Press http://www.whyyouhearwhatyouhear.com/
Mikorist Napisano Februar 23, 2013 #8 Napisano Februar 23, 2013 Make your own non-inductive graphite resistors http://www.troelsgravesen.dk/graphite.htm
HomeMadeAudioProject Napisano Februar 23, 2013 #9 Napisano Februar 23, 2013 oko ovoga je već bilo rasprave,zaključak je bio "neopravdano".
Mikorist Napisano Mart 9, 2013 #11 Napisano Mart 9, 2013 I've found this thing useful in the past, when building non-critical boxes for drivers where the T-S parameters are not known. It basically tunes the port to the box. Provided you have chosen a sensible size for the box you can get reasonable results. No substitute for a proper program like BassBox Pro and well documented drivers though.
DYNABLASTER Napisano Jul 16, 2013 #12 Napisano Jul 16, 2013 Ko nece da se njaka sa previse fibersmole ili cega vec, evo prost nacin da se prave razni oblici 3D fotokopir
ManicP Napisano Februar 2, 2015 #13 Napisano Februar 2, 2015 Zvučnici 4 dummies http://animagraffs.com/loudspeaker/ A članovi iz Munze mogu vide i kako radi utoka
acivoJ Napisano Februar 2, 2015 #14 Napisano Februar 2, 2015 Ajd zvučnjaci i utoka, al tarantula kako radi...savršeno. Moram ženi kupiti jednu za svoj rođendan.
ManicP Napisano Oktobar 20, 2015 #15 Napisano Oktobar 20, 2015 Atres sa srodnog voruma, pa nek ostane uteftereno i ovde https://archive.org/details/folkscanomy_electronics&tab=collection
sir Oliver Napisano Februar 17, 2016 #16 Napisano Februar 17, 2016 http://img-9gag-fun.9cache.com/photo/axjodW2_460sv.mp4
sir Oliver Napisano Februar 14, 2017 #17 Napisano Februar 14, 2017 Hoćete da pravite lampaško pojačalo a nemate lampe. Nema problema. http://www.instructables.com/id/VFD-Amplifier-a-Tube-Amp-From-VCR-Screens/?ALLSTEPS
NIXIE Napisano Oktobar 26, 2020 #20 Napisano Oktobar 26, 2020 Ako sami motate induktivitete na vazduhu za zvučnike, ovaj kalkulator je prilično tačan. Namotao sam po dva kom. 0,6mH i 0,1mH za vikend sa dva različita prečnika žice (1,5 i 1mm) na dva različita tela. Merenje Kineskim instrumentom (samo takve imam) kaže da je vrlo tačno (0,61mH i 0,10mH), a približno tačan je i omski otpor kalema. A ne znam ni koliko je Kinez tačan, primetio sam da pokazuje manje šta god se meri kad mu je prazna baterija, a prilično tačno kad je puna. http://tesla-institute.com/!app/sim/acic.php djmilicic and dejanco32 je reagovao/la na ovo 1 1
NIXIE Napisano Oktobar 26, 2020 #21 Napisano Oktobar 26, 2020 A što imam motaljicu, ravne joj nema. Semi automatic, dve brzine i mehanički brojač bez reseta (mora da se vrati unazad motanjem). vladd, krca44, BANAT and 2 ostalih je reagovao/la na ovo 5
Leonardo Napisano Oktobar 26, 2020 #22 Napisano Oktobar 26, 2020 ^ Ruska, Poljska ili DDR Ima i dve brzine!
