1 minute ago, vladd said:
Posaljete mail onim cikama iz Metalike, tetkama Britni i Maraji, pa im otvorite oci, jos im pride ispricajte basnu o pevajucem USB kablu... ne znaju ljudi, zene i deca, prosvetlite ih...:sarcastic:
Britni mož da peva u Panasonic kapsulu od 1eur, sa istim rezultatom. Metalika i Maraja, to je već nešto drugo, naročito tetka Maraja.
  • Odgovora 6.5k
Digitalne kablove? Po standardu?
A da se sve prebaci u jedinice i nule? U digitallni domen. Pa ako su sve jedinice i nule tu onda je bez izobličenja. Idealno. Po standardu.
I mikrofon digitalan da se napravi.
Napravljeno:
https://en-us.sennheiser.com/usb-studio-condenser-microphone-recording-mk-4-digital
Large Diaphragm Digital Mic (Neumann Solution D)
The Neumann Solution D is the most expensive microphone used for digital recording. It combines the clarity of digital microphone with the dynamic range and signal fidelity of an analog microphone. Its specially-developed synchronization system answers the highest requirements of professional audio recording. The initial investment is high but even a small recording studio can achieve the highest quality of audio recording using only the microphone and recording equipment. It comes with a user-friendly remote control to make changes in microphone settings so much easier. The retail price of this high-end digital microphone as of April 2011 is $17,988.
Ima i daljinski!
33 minutes ago, Gosha said:
Quote
Signal to Noise Ratio:86dB (A weighted)
A kada ga svajser umetnik napravi
Quote
Noise level at output terminal: at least -112dBm, A-weighed
Nije lako ni jeftino aplicirati znanje i talenat, kada se selektuje, kreira i pravi nesto vrhunsko.
Svašta će čovjek čuti (pročitati) pre nego što uši odpadnu.
A pajzi ovo, ovi USBovci se ubiše od pisanja i jedrenja internetom, kupe znanje kao kacketom vodu sa broda :o
Odnos cena je više od 50:1 u korist umetnika.
5 hours ago, vladd said:
Necu se upustati u pojasjenja, posto se ovakve stvari ne mogu kvantifikovati do prostih cinioca svima razumljivim ili praviti analogije sa budalastinama..itd..
A primetno je se da covek ne bavi nikakvim prenamganjima oko kablova...posto ima oko cega da se bavi i ne leci dosadu bez znanja.
Velika je razlika izmedju snoba i kraljevske krvi... :D
P.S.
Poenta je u umetnickoj noti u tehnici i suptilnom odnosu prema komponentama. Sigurno je da se stosta moze izmeriti i izmereno je, ali je izuzetno dobro i ostavljeno na stranu, kao nebitna referenca kvaliteta, pa je dominantna umetnicka nota u tom domenu zanata.
Čovjek koristi te uređaje,  mono,  i pri ocjenjivanju kvaliteta njegovih mikrofona u procesu izrade i poboljšanja. Očito da ih mnogi cijene i prave više problem oko dužine čekanja nego oko cijene.
Očito da ima mu sluh radi a i ti njegovi "jednostavni" uređaji. Sta bi bilo da je još i na forumima?
A i ocito je da poklonike Alibaba sekte bode cijena direktno u oči, samo mi nije jasno kakav im je kratak spoj bio sa kablovima? :blink:
8 minutes ago, Woland said:
kako te ne udavih tamo u bazenu, pod rukom si mi bio :Demoji14.png
Pa najveći mrsomudi ili prave sladoled ili kupus sa junetinom:clapping:
7a1ff3812d0b78530fda8bc88f2567b9.jpg&key
A teško da bi me udavio. Previše sam tapaciran sa slaninu pa ne tonem
