517 -
6
Postovi objavljeno od Zbora
Mora da uspe , suvise dugo se ne osustaje
Poslao mi je to u poruci, posto sam trazio .
New message from: tijedi (2,057)
Thank you for your purchase.
HERE IS THE FEEDBACK FROM PREVIOUS SALE.
Very pleased. Excellent packaging, quickly shipped, item as described. Thank You!
2x Burr-Brown / TI PCM1702P TO PCM63P adapter. Converts PCM63P to PCM1702, New (#195535299928)
I am the original Burr-Brown engineer that closed the applications lab. The parts have been in my possession since that time and have been handled with appropriate antistatic care.
I don't typically offer refunds on international orders as I have been frequently scammed on those orders. Since these are known new parts there should be no problems with the parts. The adapter board was purchased from another vendor and should be no problem as well. I have other bare boards using surface mount parts that have yet to be assembled so a replacement might be possible, but it is highly unlikely that it would ever be necessary.
I carefully package all of my international shipments to make sure that they arrive safely. Since you are using a freight forwarder, I can only provide tracking to that location. The US post office provides insurance but only to that final location.
Please let me know if you need additional information.
Regards,
Dan -
38 minutes ago, Mikorist said:
Ima i poštenih kineza. Ovi što su bliže Hong Kong-u su druga sorta....Msm jlcpcb je hongkoška firma.
Nikako ne mogu da ih provalim koje su društveno uređenje. Neki delovi kine su full kapitalizam a drugi su i dalje robovlasničko društvo.
Velika zemlja. Nema tu ni K od komunizam u nekim delovima. Pa čak im serije igrane lobiraju da se vrati Kineski Car....Da ne pričam koliko su budističkih hramova podigli u zadnjih 20 godina.
Može Si Đinping da prdi koliko hoče o bratstvu i jedinstvu kad se 800 milona kineza vraća korenima i tradiciji.
Cuvaj glavu sinko, mani se politike
Nego gledaj 'vamo od cega se 'leba jede
Okrunjeno, nemoŽ odoleti,
Cim stigne na raspolanju su za probu pa sta bude... ćeraćemo se
Evo nisam skolovala, go*** ne go*** u nesto se udarati mora
WWW.EBAY.COM
Find many great new & used options and get the best deals for 2x Burr-Brown / TI PCM1702P TO PCM63P adapter. Converts PCM63P to PCM1702, New at the best online prices at eBay! Free shipping for many products!Cini se legit, i cipovi su NOS.
Ovo je kao Miurikanac Located in: Laguna Hills, California, United States
2x PCM1702P TO PCM63P adapter. Converts PCM63P to PCM1702, NEW
Adapter converts PCM1702 footprint to PCM63P's.These adapters were created from 4 pieces of new PCM1702P's that were acquired from a closed Burr-Brown analog applications lab. New parts but untested as I no longer have a PCM63P demo to work with. Great DIY upgrade or repair unit. Soled in pairs for stereo channel applications. Each pair has matching date/lot codes. -
- 1
7 minutes ago, Mikorist said:
Ovde svako tera svoje. A nema Zena sa njegovim rules chipom
Samo ja ne znam di teram i na koju stranu izbivam
meni je prva tura sa hifi colectiva stigla za cas, a samo par dana kasnije sam porucio nesto bas sitno , srecom greskom i to mi do dana danasnjeg nije stiglo bese to pocetkom januara... Nikako da se osokolim da porucim jos nesto... Sacekacu Majstora za ove 6800
1 hour ago, Mikorist said:
Izgleda kao da je od majstora stiglo sa KP
Jašta su i sve su Ničikonci nista , sa Elnom špricer da se pravi
- Brijac and LightMatic je reagovao/la na ovo
- 2
10 hours ago, BANAT said:
ono sto je isto bitno je da potrosaci koji nemaju ugradjenu zastitnu Fideovu sklopku ne bi smeli da koriste uzemljenje kao povratni vod potrosaca zbog pojave tkzv. `lutajucih struja` kroz zemljiste , kola tih lutajucih struja znaju da se protezu ponekad kilometrima , a mogu vremenom da ostete razne metalne predmete i objekte u zemlji , na primer metalne vodovodne cevi , podzemne kablove , ...
Dodao bih samo da, niko ne treba da koristi zamlju kao zamenu za nulu jer je uzamljenje pre svega bazbaednosni eleamaent ! Obaska potrosnja sondi ...
A Fid sklopka ce sama po sebi tu funkciju "zuto zelene" i onemoguciti, iskocice.
Đe reče lutajuca struja.
Obicno domacinstvo kako god tesko ce napraviti veci karambol sa lutaucim strujama, iz prostog razloga sto u prosecnom domacnistvu nema velikih potrosaca.
Ove nase suske sto u_zemlju sipamo, ne bi rastvorile spenadlu u zemlji za ihaaaj godina.
Dok na primer tramvaj na Ustanickoj na okretnici pored magistralca gasovoda kad sasije sa 100A (mereno na stanici katodne zastite ) ...to je vec problem.... industrija.
zato su veliki cevovodi zasticeni sistemom katodne zasite gde se cevovod duz cele trase odrzava menscini na negativnom potenicajalu.
jes malo off al caskamo, da ne misli covek na prodaju.... J***s zivot bez muzike
5 hours ago, ManicP said:
Idu direktno u zemlju. U posteljicu od peska se polažu podzemni kablovi.
Nevezano za ovo iznad... Temeljni uzemljivač se pravi od pocinkovane trake u temelju postavljene "nasatice" ili uspravno 5cm od spoljne ivice temelja. Privari se malo i na armaturu. Traka ne izlazi iz temelja i to je najtrajnije rešenje. Podrazumeva se da temelj nije hidroizolovan, onda ide malo drugačije rešenje.
Izlazak pocinkovane trake iz betona u zemlju bi trebao da bude prohromskom trakom zbog neke galvanske korozije ali to u Srbiji retko ima da se vidi (npr. objekti Lidl imaju takvo rešenje). Ovde se standardno radi pocinkovanom trakom 25x4mm ili većom.
Bojleri i ostalo su narodska rešenja... ...ko hoće da radi kupi lepo tri sonde za uzemljenje 2 ili 3m dužine i Fe/Zn traku 25x4mm za između. Sonda se pobija u rupu dubine 1m tako da joj vrh završina 80cm ispod površine. Na istoj dubini ide i traka. Sonde su na međusobnom rastojanju bar 3m (trougao, u red ili "pačja šapa" kako može). Sonde imaju na sebi ukrsne spojeve za traku, spojevi se dobro ofarbaju (propis kaže katran al komplikovano) zbog korozije jer se cink ošteti na tom delu i rešen problem. Izvod gde je i stari i vozi. Vojvođani i šumadinci imaju realnu šansu da završe sa manje od 10 Ohm. Za nekoliko decenija se ponovi postupak.
iliiii, bakarno uze 35mm umesto Fe/Zn trake kao u mobilnoj telefiniji ... emisionoj tehnici, pa spoj sa sondom ukrsni komad traka/uze sa tankim olovom izmedu.
Obavezno merenje Metrelom na kraju.
Jesmo audifili majku mu
- ManicP, bnb and LightMatic je reagovao/la na ovo
- 3
- Mission835, LightMatic, Brijac and 1 član je reagovao/la na ovo
- 4
dooobro,
znaci c43,c44 mora da se "narikta" ne moze po "švajserski"
Nego opet ja imam sta mi nije jasno
Vezano za kondenzatore.
Zalemio sam
16kom 100n,
2kom smd 47p paralelno sa Z Fil,
Imam jos dva kom 470p to bi trebli biti C43,C44 izmedju mase i IOUT sa PCM63
Al sta je na kraju sa 33p, u narodu poznati kao (Mika skinuo) , de to zapravo ide i jel ide na kraju , posto ih imam ?
Ne vidim im mesto na plocici evo obnevideh a boga mi slabo ih i na semi nalazim.
JesT, pa posle da nemas jos jednu kutiju u koju ces da gledas ... E, nece moci!...
- Mikorist and LightMatic je reagovao/la na ovo
- 2
Trenutno na sajtu 12 članova, 1 Skrivenih, 62 Gosta (Pogledaj celu listu)
Ukupan broj tema435.9k
in Digital
A nije li pregrada za ukras, osim ako je od mumetala ?
