16307 -
136
Sve objavljeno od NIXIE
http://www.audioreview.com/cat/amplification/integrated-amplifiers/raysonic/sp120/prd_401220_2717crx.aspx Kažu da valja, jedino ako moraš da menjaš odmah cevi, nećeš se usrećiti. Dizajnirano u Kanadi, napravljeno verovatno u Kini.
Treba mu i pretpojačalo?
Odmah pravi i trpaj u SEWA
Ako ide DHL-om tu je za 7 dana, malo je okasnio sa poklonom. Stiže do Srpske NG.
Evo lampaša, 2x7.5W https://www.aliexpress.com/item/HIFI-EXQUIS-manufacturer-6N8P-push-6P3P-tube-amps-single-ended-Class-A-7-5w-vacuum-tube/32221742010.html?spm=2114.10010108.1000014.10.7992898bU8buGf&traffic_analysisId=recommend_3035_null_null_null&scm=1007.13338.80878.000000000000000&pvid=cd2c30ad-66bf-41f3-957c-ccef7cb12347&tpp=1
Evo lampaša, 2x4W https://www.aliexpress.com/item/Finished-6N2-FU32-Single-Ended-Tube-Headphone-Amplifier-Power-amp-4W-4W/32793396096.html?spm=2114.search0204.3.230.CkPxny&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5000015_10151_10065_10344_10068_10342_10343_51102_10340_10341_5130015_10084_10083_10307_5080015_10312_5790015_10059_10313_10314_10534_100031_10604_10103_10605_10594_5060015_10107_10142,searchweb201603_6,ppcSwitch_5_ppcChannel&algo_expid=748c473d-7be0-4bef-b779-ac318773c840-37&algo_pvid=748c473d-7be0-4bef-b779-ac318773c840&transAbTest=ae803_5&rmStoreLevelAB=5
Ovo te izađe sve ukupno manje od 300 evrića i još piše KRELL https://www.aliexpress.com/item/Voice-king-Hood-1969-gold-seal-the-most-perfect-version-of-the-HD1969-class-a-power/32724443293.html?spm=2114.search0204.3.19.9z6BnD&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5000015_10151_10065_10344_10068_10342_10343_51102_10340_10341_5130015_10084_10083_10307_5080015_10312_5790015_10059_10313_10314_10534_100031_10604_10103_10605_10594_5060015_10107_10142-normal#cfs,searchweb201603_6,ppcSwitch_5_ppcChannel&algo_expid=6a181320-eb43-4d0a-b9ce-f376e6b957aa-4&algo_pvid=6a181320-eb43-4d0a-b9ce-f376e6b957aa&transAbTest=ae803_5&rmStoreLevelAB=5
A ovako nešto? https://www.aliexpress.com/item/2017-LM3886TF-Dual-Channel-2-0-Amplifier-HIFI-High-Finished-Power-Amplifier-60W-60W/32794871017.html?spm=2114.search0204.3.21.XKqsr7&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5000015_10151_10065_10344_10068_10342_10343_51102_10340_10341_5130015_10609_10084_10083_10307_5080015_10312_10059_10313_10314_10534_100031_10604_10103_10605_10594_5060015_10107_10142,searchweb201603_1,ppcSwitch_5_ppcChannel&algo_expid=85beff36-be78-4d0e-b136-a43f7dcd5593-3&algo_pvid=85beff36-be78-4d0e-b136-a43f7dcd5593&transAbTest=ae803_5&rmStoreLevelAB=5
Samo što nije A klasa, ali ima barem 2x20W https://www.aliexpress.com/item/NEW-HiFi-Finished-LM3886-mini-Power-amplifier-40W-40W-DIY-AMP/32654252379.html?spm=2114.search0204.3.2.XKqsr7&ws_ab_test=searchweb0_0,searchweb201602_4_10152_5000015_10151_10065_10344_10068_10342_10343_51102_10340_10341_5130015_10609_10084_10083_10307_5080015_10312_10059_10313_10314_10534_100031_10604_10103_10605_10594_5060015_10107_10142,searchweb201603_1,ppcSwitch_5_ppcChannel&algo_expid=85beff36-be78-4d0e-b136-a43f7dcd5593-0&algo_pvid=85beff36-be78-4d0e-b136-a43f7dcd5593&transAbTest=ae803_5&rmStoreLevelAB=5
Znači iskoristio si Tanoja u potpunosti, bez kompromisa. To je dobar prustup, kad se ima mesta, a ovi što pokušavaju da tako nešto strpaju u 5 puta manje kutije, džaba su krečili.
Ima jeftinije, a i ne piše "does not ship to Serbia" https://www.ebay.com/itm/Pair-of-Tannoy-Monitor-Gold-15-Type-LSU-HF-15-8-Speakers-from-original-owner-/152786568443 https://www.ebay.com/itm/Vintage-Tannoy-Monitor-Gold-12-Speakers-Pair-Exct/292361127656?_trkparms=aid%3D888007%26algo%3DDISC.MBE%26ao%3D1%26asc%3D41375%26meid%3D446aa5de3d5d4cabb74410b8eab3ce94%26pid%3D100009%26rk%3D1%26rkt%3D1%26sd%3D152786568443&_trksid=p2047675.c100009.m1982
Ma sve je OK, ja sam mislio da si ti mene pogrešno razumeo, a ti si mislio da sam ja tebe pogrešno razumeo, ma ludnica.
Imaš puno zvučnika koji su slabi u opsegu 100-200Hz, a još i u sobi obično se javi poništavanje baš u tom opsegu zbog refleksije od poda, pa na kraju sve zvuči kilavo.
Mislim da je bolja koncepcija (zbog fizike i polarnog odziva) imati 15"+8"+1", takve uspešne konstrukcije postoje, moraš voditi računa o direktnom i indirektnom zvuku. Ako ideš na horne, to je druga priča tu može direktivnost da se prilagođava pa možeš imati uspešnu konstrukciju sa 15" basom + 2" hornom. Ti efikasni zvučnici koji dodaju detalje koji obično ne postoje u originalu su takođe stvar ukusa, ja volim da čujem šta je snimljeno pa kakvo je da je. Efikasnost je vezana uglavnom za međusobni odnos pokretne mase, snage magneta i površine mebrane, pa kada neki element sistema ode do ekstrema (uglavnom je to izrazito lagana tanka membrana) onda nastaju razni problemi. Ako hoćeš dobar stvarno dubok bas, a da bude usput ekstra efikasan, mala ti je svaka kutija, treba ti horna ispod kuće. https://gizmodo.com/5025867/horn-subwoofer-takes-up-crazy-mans-entire-basement
Evo merenja, ne da mu fali basa, nego ga praktično i nema, što se moglo očekivati. http://www.avsforum.com/forum/155-diy-speakers-subs/1238362-wayne-parham-s-pi-4-build-thread.html
Zar se stavlja EI sa procepom za mrežne (napojne) trafoe, ja sam mislo da to ide samo za izlazne kod lampaša i one male signalne odnosno samo kad na primaru imaš DC komponentu?
Hteo je da bude tvrdo naleganje, sad će da bidne neizvesno naleganje čim je uzeo onu šlajfericu.
Sve ti je neki kompromis. SET male snage ima na raspolaganju samo mirnu struju koja protiče kroz izlaz, odatle nemogućnost kontrole težih mebrana, a to je uvek Bass driver. Push-pull A klase ima na raspolaganju dvostruku mirnu struju, a AB klasa je limitirana tek na mnogo višem nivou struje, odatle i razlike u zvuku, koje su uglavnom izobličenja. E sad što SET svira milozvučnije, to je druga priča, praktično sve druge koncepcije imaju poništavanje parnih harmonika (ne znam za D klasu).
Što bi rekli da dobiješ spoj sa preklopom da se ne vrti. To mora da bude mnogo precizno, ili da uradiš konus 1:50 pa kad nabiješ neće samo da se izvuče.
Pa u principu je onako kako ti je Zen rekao, teške membrane i veliki kalemovi ne idu sa pojačalima manje snage koje ne može dobro da ih kontroliše, za to treba tražiti lagane membrane, male kalemove i jako efikasne zvučnike kako bi izobličenja bila manja. Po meni za neefikasne zvučnike isto ne treba koristiti pojačalo male snage (osim za neko neobavezno slušanje) jer nema dovoljno rezerve za pikove. E sad šta je neko konkretno mislio pod "traže pojačalo veće snage", to je dobijeno slušanjem i upoređivanjem nije tehnički obrazloženo na šta se konkretno misli.
Trenutno na sajtu 3 članova, 2 Skrivenih, 1072 Gosta (Pogledaj celu listu)
