40979 -
628
Sve objavljeno od Zen Mod
copy/paste sa Big DiyA : looking at graphs in SIT-3 user manual , and comparing them with THD values I got for SissySIT , I'm observing few things : -funny , due to nature of PapaSIT , THD in 4R load is lower than THD in 8R load , while this is not the case with THF -also funny - regarding THD , SissySIT is on par with SIT-3 few things more , to think of : -should I measure THD spectra ( and whatnot) of ZM's DEFiSIT specimen , and what conclusions , dumb as I am , I can get from that ; -should I try THF51-S in SEF amp cradle , so SIT being slightly tamed with some source resistance ...... I'm not scared of work involved , but grumpy of necessary critical listening later , to decide which one is better ......... hate critical listening ......... I like normal -greenaroundmyhead music enjoyment ......
mozda ce dosadasnji kum da se ljuti , mozda i prvonamenjeni gazda ime projekta se menja u SissySIT
Za Neskora , soundcard interface metalna kutija ........ nemoj plasticnu kao ja ako nemas balans kartu , ignorisi sve sto je u - fazi
-10dBFS vidi tamo kod mene u temi na Big Diya (Babelfish M25) , topla voda interface
ako imas pojacanje , bice da ti je load u drainu , pa je to common source probaj ti to na 8Vpp izlaza (1W) , onda je merodavno
par grafova za koje sam morao da dodam autoformer sa 6db gaina in-line , tako da i to dodaje malo THD ...... no zanimao me prvenstveno generalni trend , ne apsolutne vrednosti
simulacija se pokazala manje nego pouzdana -po pitanju nekih vrednosti u bias network , zahvaljujuci tome sto u modelima SIT-ova nedostaje podosta toga , prvenstveno struja gate-a no , izborih se , ipak sam ga ja gazao , pa valjda znam kako funcionise
Imao sam debelu dilemu sinoc - da li da nestujem THF u Babelfish M25 koncept (dakle , nema source otpora ni na mosfetu ni na SIT-u, current sense Hall chips u rail-ovima) , ili da ga nestujem u SEF koncept (gornji element , u ovom slucaju THF , ima source otpore i optocoupler se hrani sa njih) prvi slucaj - cisca koncepcija , potpuna i nepatvorena priroda SIT-a u punoj meri ali nesto veca izoblicenja drugi slucaj - malo prikocen SIT , manja izoblicenja ipak se jutros odlucih na prvu varijantu , makar i po cenu vecih izoblicenja
Common drain , common source ? mereno na 1W , 8R load ?
peva ko ......... nemam reci ali dobro je da je prezivela taj period
a jes valja odgledati i prirepke , tj povezane filmove
9 stranica u temi , sve i jedan komentar pozitivan , dva komentara koji su pohvalni ali sa upitom o dostatnosti kolicine snage za Tannoye. Malo li je pohvala ? A bilo bi i vise , nego se na prvo potpitanje svelo da odjednom nesto ne valja ? Licni animozitet prema nekome , ceo forum je odjednom kriv. Mican je malo stariji i od tebe i od mene , za njega smo nas dvojica balavci...... sumnjam da se on i jednog momenta nasekirao za bilo koje pitanje koje se moglo postaviti o rezultatu njegovog rada . Toliko . Lock.
samo vas gledam
izgleda možno
znam ko je ubica , a nisam citao knjigu garant!
daleko je jos G spot ono , bice na 1A8 do 2A , ali ima tu jos čimbenika
to samo procisceno , sa istim lampama kao original , svira da nemozbilivit gledam poluprazne izlazne trafoe i vrtim glavom , kako se cuje
idi begaj oti BMW je space shuttle tehnologija za HD .....
jes , vidis , u godinama kad se vise ne ujeda no i lajanje postaje sve utisanije , valja znati preduprediti zal za mlados
sve sto si napisao opisuje perfektan motocikl za dede kao sto sam ja
razmisli na V1g i V1k je identicna faza signala sprega sa izlaza dovodi signal u istoj fazi, na V1k ako dovedes 1V na g1 , povratna sprega smanjuje efektivni napon Vgk edit: postovao si u medjuvremenu , skontao
69K bi bilo previse kriticno za 220K u anodi prethodnog stepena
Trenutno na sajtu 7 članova, 2 Skrivenih, 448 Gosta (Pogledaj celu listu)
Ukupan broj tema454.1k
