Mikorist Napisano Avgust 6, 2015 Share #353 Napisano Avgust 6, 2015 licenca će ostati Koliko sam shvatio zbog odsustva nadogradnji nećeš moći ni da budes licenciran sem ako nije Windows 10 Enterprise. MDL se zahuhtava u paranoju. Glavni admin im se vratio na Linux Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano Avgust 7, 2015 Share #354 Napisano Avgust 7, 2015 malo bezveze... dakle osnovi preduslov je da moraš imati net, a sigurno gomila ljudi ga još uvek nema. morali bi da se snalaze oko nadogradnji. ili njih neće dirati jer ne mogu da ih telemetrišu ma naći će se rešenje za sve. ja prezadovoljan kako mi ovo radi. koliko sam hvalio win8.1 pro, ovaj je isti, ako ne i bolji. oseća se da softver bolje diše u ovom okruženju. Link to comment Podeli na ovim sajtovima More sharing options...
mrcelavi Napisano Avgust 7, 2015 Share #355 Napisano Avgust 7, 2015 Linux je zakon ali problemi nastaju kada vam banke i ostali važne institucije sa kojima morate da radite online odbijaju pristup ako nije win. Cak u nekim bankama Opera nema ukljucene sve opcije jer primat ima Chrome u Expl. Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano Avgust 7, 2015 Share #356 Napisano Avgust 7, 2015 oni na MDL u frci, ko da rade za... ko zna koga Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano Avgust 7, 2015 Share #357 Napisano Avgust 7, 2015 As long as a computer is connected to the Internet, by what connection ever, there's going traffic in and out and some of those traffic are the data of the user who is running that computer! It's simply impossible to avoid data fluctuation! Even the best Security software has it's loopholes and will let you data going out without to be really able to know to where they will go! I 'played' with expensive Security Hardware like Cisco, Netscreen, and others for my own Company as for the companies of my customers too! Has that solved the problems? NO!! It didn't, maybe minimize a bit and that was just all! The cost of an Cisco ASA and ASAv or an Netscreen 25 etc. starts by several thousand's of US Dollars (Netscreen 25 US$ 3500 and more, Cisco ASA/ASAv 6-10K US$) and that's just for basic Hardware Firewall Systems! To that cost, you've to add the Update and Maintenance Fee's which are expensive as well and that at least every single year! Since a few years, I now using Smoothwall Express Firewall and Security system which is just Freeware. What need to be invested is an not powerful computer at least 2 or more good NIC's and also a WiFi NIC if WiFi is used and needed. For my own Office I use and Intel i5 with 6 NIC's, 32GB Memory and 2HDD each 1TB and that's just much more than really is needed! Monitor, Keyboard, and Mouse is just needed for the installation of Smoothwall because any further config etc. goes via a Web Browser from any computer authorized in the LAN. That Smoothwall machine is connected after the modem and the computers of the LAN via a Switch to one of the NIC's of the Smoothwall. Depend on the config you need for your LAN, you have to plan in advance of the setup, best on paper, like this one: In this case the Smoothwall will have at least 4 NIC's: first for the connection to Modem second for Switch third for WiFi Access Point fourth for Server It's also possible for to configure and use Load Balancing. The final configuration for any of the connected computers is what'll need the most time and have to be done very carefully! In my own office, I'd need around 2 weeks for the whole setup and config with 4 different Servers, one on DMZ running. That was including the config of Data Backup's from our Machines at customers Place and something else. Unlike a Cisco, Netscreen or what ever Hardware Firewall is used, the setup and config of a Smoothwall are much more easy and didn't need some extensive knowledge about some special Programming Language! Smoothwall comes with it's own OS (Linux) and the basic installation is quite straight forward. Since we are using the Smoothwall at our own Company and by our customers, we didn't had any serious security breach, which we still had with Cisco and Netscreen Firewalls. And as we also ned to keep track for at least 3 months of all our commercial Internet connection and Data flow according to the Royal Thai Law, Smoothwall is even better that any other Hardware Forewall solution. That's also the reason we use that huge HDD's in the Smoothwall computer. Smoothwall, as already mentioned above, use a Linux OS for to run and didn't need any Windows setup, install or whatsoever and therefore it's quite easy to block all those Service (Spy) Calls etc. the user of Windows 10 are highly concern about! Every outgoing and incoming traffic could be deeply configured without to get interfered in any means by Windows OS! For me, Smoothwall is the only one system I know which will give the user the best security! http://www.smoothwall.org/download/ ovo je zaista jedini nacin. da se ima poseban server pre ostalih racunara koji ce da filtrira sav saobracaj. naravno da je komplikovan i nije za posecnog korisnika. naravno uz ovo iznad treba i TEMPEST room for sensitive work. see here: http://www.comtest.eu/products/rf-sh...ded-rooms.html da bude sigurica koju ima Džejms Bond, poznat i kao 007 Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Avgust 7, 2015 Share #358 Napisano Avgust 7, 2015 I ja ugradih 10ku. Clean. Dosta brzo ga uradi. Prvi utisak: Ružno bre ovo. Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano Avgust 7, 2015 Share #359 Napisano Avgust 7, 2015 kod mene Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Avgust 7, 2015 Share #360 Napisano Avgust 7, 2015 Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano Avgust 7, 2015 Share #361 Napisano Avgust 7, 2015 ma ovo je jos super. za jedno godinu kad evoulira bice ko Android. Bice par podesavanja i Upgrade. Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Avgust 7, 2015 Share #362 Napisano Avgust 7, 2015 Miko vidim imas Total commander. Ja bez njega numem da radim. Da li radi Ultima Prime na 10ki? Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano Avgust 7, 2015 Share #363 Napisano Avgust 7, 2015 Da li radi Ultima Prime na 10ki? radi Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Avgust 7, 2015 Share #364 Napisano Avgust 7, 2015 Vidim i sam. Ima li neki PDF reader u w10 ili da skidam neki? Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano Avgust 7, 2015 Share #365 Napisano Avgust 7, 2015 skidaj Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Avgust 7, 2015 Share #366 Napisano Avgust 7, 2015 MAPE me locirao u Kragujevcu Pe ( r ) tak je. Dosta za ovu radnu nedelju. Nastavljam isprobavanje u ponedeljak. Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano Avgust 7, 2015 Share #367 Napisano Avgust 7, 2015 Pe ( r ) tak je. Dosta za ovu radnu nedelju. Nastavljam isprobavanje u ponedeljak. hiljade nadogradnji, hiljade instalacija... Link to comment Podeli na ovim sajtovima More sharing options...
...sam se banovo Napisano Avgust 7, 2015 Share #368 Napisano Avgust 7, 2015 http://www.smoothwall.org/download/ ovo je zaista jedini nacin. da se ima poseban server pre ostalih racunara koji ce da filtrira sav saobracaj. naravno da je komplikovan i nije za posecnog korisnika. naravno uz ovo iznad treba i TEMPEST room for sensitive work. see here: http://www.comtest.eu/products/rf-sh...ded-rooms.html da bude sigurica koju ima Džejms Bond, poznat i kao 007 Demilitarized Zone Link to comment Podeli na ovim sajtovima More sharing options...
sir Oliver Napisano Avgust 7, 2015 Share #369 Napisano Avgust 7, 2015 hiljade nadogradnji, hiljade instalacija... vec mi se ne svidja. U opasnosi je da vrnem stari hdd a ovaj formatiram. Link to comment Podeli na ovim sajtovima More sharing options...
progster Napisano Avgust 7, 2015 Share #370 Napisano Avgust 7, 2015 Stigao mail od ASUS-a, kaže da se oprostim od toga da instaliram Windows 10, i to još na srpskom. Link to comment Podeli na ovim sajtovima More sharing options...
Mikorist Napisano Avgust 7, 2015 Share #371 Napisano Avgust 7, 2015 hiljade nadogradnji, hiljade instalacija... Moj biceps je najmanje od tegova, on je od kliktanja mišem , ne onih više hiljada nadogradnji, hiljada instalacija, sad već pravimo milione i milione , pa ulazimo u te milijarde kada više klikovi ne reaguju na našu muskulaturu!...Skupljanje salveta, poštanskih markica...bežanje u zdrav razum. Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano Avgust 7, 2015 Share #372 Napisano Avgust 7, 2015 evo me ženo, idem, samo da odradim antitelemetry za danas Leonardo je reagovao/la na ovo 1 Link to comment Podeli na ovim sajtovima More sharing options...
Nesic Napisano Avgust 9, 2015 Share #373 Napisano Avgust 9, 2015 Evo lepe vesti za čistunce Link to comment Podeli na ovim sajtovima More sharing options...
...sam se banovo Napisano Avgust 9, 2015 Share #374 Napisano Avgust 9, 2015 Evo lepe vesti za čistunce SC020.png Bilo je samo pitanje vremena kad će se neko uzjebat i to napraviti... Link to comment Podeli na ovim sajtovima More sharing options...
