Aleks Napisano April 25, 2018 #9637 Napisano April 25, 2018 Kontemplacije na temu high end osigurača prebačene ovde: https://www.diyaudio.rs/topic/8990-osigurači-high-end-i-oko-njih/
Woland Napisano April 26, 2018 #9638 Napisano April 26, 2018 SME M2-12R + još jedan shell - klasika u novom izdanju.. za Lenca ili Garrarda 401 InSides, vladd, Doktor and 2 ostalih je reagovao/la na ovo 5
Doktor Napisano April 26, 2018 #9639 Napisano April 26, 2018 1 hour ago, Woland said: SME M2-12R + još jedan shell - klasika u novom izdanju.. za Lenca ili Garrarda 401 . . . . Uhhhhh, Sunce mu kalajisano kako ova ručica SME dobro izgleda. Trošio je u zdravlju i veselju.
skrstic Napisano April 26, 2018 #9640 Napisano April 26, 2018 1 hour ago, Woland said: SME M2-12R + još jedan shell - klasika u novom izdanju.. za Lenca ili Garrarda 401
InSides Napisano April 26, 2018 #9642 Napisano April 26, 2018 1 hour ago, Woland said: SME M2-12R + još jedan shell - klasika u novom izdanju.. za Lenca ili Garrarda 401 Бре бре бре.
Woland Napisano April 26, 2018 #9643 Napisano April 26, 2018 1 hour ago, Doktor said: Trošio je u zdravlju i veselju. falavi @skrstic to skrečovanje je noćna mora posvećenih korisnika gramofona - probudim se kad se setim da nemam DD gramofon 1 hour ago, ivan_ said: Bruka jesvala 57 minutes ago, InSides said: Бре бре бре. još malo pa će SME da zapleše Teškoto Oro InSides je reagovao/la na ovo 1
aaa zmaju! Napisano April 26, 2018 #9644 Napisano April 26, 2018 Ovako a? https://www.ebay.com/itm/273077555929?rmvSB=true
aaa zmaju! Napisano April 26, 2018 #9645 Napisano April 26, 2018 A jes` gadan...ko da ga je pravila Sloboda Čačak
Woland Napisano April 26, 2018 #9646 Napisano April 26, 2018 ^ pa baš i nije primer lepote, za te pare bi mogli barem da uklope furnir na boku i gornjoj strani, msm - moj će biti lepši vladd je reagovao/la na ovo 1
skrstic Napisano April 26, 2018 #9647 Napisano April 26, 2018 21 minutes ago, ivan_ said: A jes` gadan...ko da ga je pravila Sloboda Čačak Eto koliko se razlikujemo. Meni je lep. Vilim tako drvo (furnir). Još da mu je dodao blago crvenu nijansu... 10 minutes ago, Woland said: za te pare bi mogli barem da uklope furnir na boku i gornjoj strani Vala baš.
aaa zmaju! Napisano April 26, 2018 #9648 Napisano April 26, 2018 37 minutes ago, skrstic said: Eto koliko se razlikujemo. Meni je lep Uvredio si me pripremi se da snošiš posledice!!! Ma vidi sam drajv, ko rešov sa tim dugmićima... a dobro o ukusima ne treba raspravljati. Drugu bi i ja priču pričao da ga imam...
ninja Napisano April 26, 2018 #9649 Napisano April 26, 2018 Preko brda i dolina konačno prihajao. Doktor, Woland and Aleks je reagovao/la na ovo 3
Doktor Napisano April 26, 2018 #9650 Napisano April 26, 2018 2 hours ago, ninja said: Preko brda i dolina konačno prihajao. . . . Iskrene cestitke na legendardnom CD 960. Sve one price kako je CD 304 MK II "Mama" za sve Philips modele padaju u vodu kada stane ovaj tvoj novopridosli CD Player rame uz rame sa 304. Da se razumemo, Philips CD 960 je bio njihov flagship model. Mozda je onaj model CD 880 interesantniji pojedincima zbog samog izgleda, mada smo se vec ti i ja u onoj nasoj prepisci slozili da 960 i nije bas toliko ruzan. Moj predlog/savet - ako ostaje u sistemu, ostavi ga bez ikakvih intervencija i raznoraznih mrsomoodjenja koja se mogu naci po net-u. Samo usisavanje, pregled, osnovna merenja ako je potrebno i - play. Uzivaj. Fly carpenter and ninja je reagovao/la na ovo 2
John Coltrane Napisano April 26, 2018 #9651 Napisano April 26, 2018 Za 500 din. nisam mogao da odolim. Dobra karta pogotovu odnos cena kvalitet deo spec. kaže: Type: balanced, AC-coupled, 2-pole low-pass differential filter D/A converter: CS4392 Max Level: 6.6 dBV (unbalanced) Frequency Response (20Hz - 20kHz): 0.00/-0.08dB Dynamic Range (1kHz, A-weighted): 112dB Signal-to-Noise Ratio (A-weighted): 112dB THD+N (1kHz at -1dBFS): -99dB (.0011%) Stereo Crosstalk (1kHz at -1dBFS): <-111dB vladd je reagovao/la na ovo 1
papa d.j. Napisano April 26, 2018 #9652 Napisano April 26, 2018 Nisam baš siguran da je izgled od 880tke jača strana, pogotovo displej. A da ide negde od kuće, jokja... :-) Fly carpenter and Doktor je reagovao/la na ovo 2
Doktor Napisano April 26, 2018 #9653 Napisano April 26, 2018 8 minutes ago, papa d.j. said: Nisam baš siguran da je izgled od 880tke jača strana, pogotovo displej. A da ide negde od kuće, jokja... :-) . . . Kako nije ? Lep k'o lutka. Za 960-icu sa onom dole otvorenom fijokom je maneken. Odlican CD plejer.
Zen Mod Napisano April 26, 2018 #9654 Napisano April 26, 2018 35 minutes ago, John Coltrane said: Za 500 din. nisam mogao da odolim. Dobra karta pogotovu odnos cena kvalitet deo spec. kaže: Type: balanced, AC-coupled, 2-pole low-pass differential filter D/A converter: CS4392 Max Level: 6.6 dBV (unbalanced) Frequency Response (20Hz - 20kHz): 0.00/-0.08dB Dynamic Range (1kHz, A-weighted): 112dB Signal-to-Noise Ratio (A-weighted): 112dB THD+N (1kHz at -1dBFS): -99dB (.0011%) Stereo Crosstalk (1kHz at -1dBFS): <-111dB evo dam ti ja EMU1212 internu za to ........
papa d.j. Napisano April 26, 2018 #9655 Napisano April 26, 2018 7 minutes ago, Doktor said: Kako nije ? Lep k'o lutka. Za 960-icu sa onom dole otvorenom fijokom je maneken. Odlican CD plejer. I jedan i drugi su izvrsni, jedino su laseri malo hebeni...
John Coltrane Napisano April 26, 2018 #9656 Napisano April 26, 2018 21 minutes ago, Zen Mod said: evo dam ti ja EMU1212 internu za to ........ Već imam m-audio 1010LT, ovo će na macbook ako bude mesta za drugi sistemaja u kujnu .... ako bude za đor - javljam. edit: sad vide da mi interna nije e-mu
Doktor Napisano April 26, 2018 #9657 Napisano April 26, 2018 8 minutes ago, papa d.j. said: I jedan i drugi su izvrsni, jedino su laseri malo hebeni... I ovaj moj ne ide nigde od kuce . . . isto tako "Baba Roga" na svoj nacin. 4 x TDA 1541 iliti 16 x 16
Doktor Napisano April 26, 2018 #9658 Napisano April 26, 2018 6 minutes ago, John Coltrane said: Već imam EMU 1010LT, ovo će na macbook ako bude mesta za drugi sistemaja u kujnu .... ako bude za đor - javljam. Javljaj ako bude jos koji par Chartwell-a ( gde li se samo snabdevas ? ).
