shonne Napisano Novembar 22, 2022 #4885 Napisano Novembar 22, 2022 3 minutes ago, Zen Mod said: ma kome jos to treba onda moram da napravim XS ampove Mogo bi napokon da se prosvetlis 😁😛🙏
Zen Mod Napisano Novembar 22, 2022 #4886 Napisano Novembar 22, 2022 ma qur cu napravim sebi lanpas od 10W i batalim sve Brijac, Pchelac, Vix and 4 ostalih je reagovao/la na ovo 1 1 3 2
Aleks Napisano Novembar 22, 2022 #4887 Napisano Novembar 22, 2022 Ja se zaglavio Ampić VSSA sa lateralcima, a XA i ne palim jer nemam adekvatan preamp za njega (imam delove mrzi me da sastavim), a ovamo stavio samo pot na dac i pevay bayo. Kutije sa custom FR by Alex, da me sad pitaš oli mož peMzija sa ovime - može
Zen Mod Napisano Novembar 22, 2022 #4888 Napisano Novembar 22, 2022 ma napravicu ja sebi cevas sa 1W, dosta Aleks je reagovao/la na ovo 1
Koja Napisano Novembar 22, 2022 #4890 Napisano Novembar 22, 2022 Sa Zaphaudio: I've sold my old big, heavy and hot amplifier and I'm now a big fan of digital tripath amps. There was no real reason for me to keep an old fashioned 60 lb monster around when I only really need a couple watts. I should have done that many years ago.
shonne Napisano Novembar 22, 2022 #4891 Napisano Novembar 22, 2022 Nemate vi pojma 😁 vladd je reagovao/la na ovo 1
krca44 Napisano Novembar 22, 2022 #4892 Napisano Novembar 22, 2022 Mora da ima 3W i svetli shonne je reagovao/la na ovo 1
Brijac Napisano Novembar 22, 2022 #4893 Napisano Novembar 22, 2022 1 hour ago, Koja said: Sa Zaphaudio: I've sold my old big, heavy and hot amplifier and I'm now a big fan of digital tripath amps. There was no real reason for me to keep an old fashioned 60 lb monster around when I only really need a couple watts. I should have done that many years ago. Mi sa 400W, gledamo u pod, cutimo.mp3 😁
djmilicic Napisano Novembar 22, 2022 #4894 Napisano Novembar 22, 2022 pre 2 minuta, krca44 reče Mora da ima 3W i svetli I to 'vako LightMatic, krca44, shonne and 1 član je reagovao/la na ovo 2 2
NIXIE Napisano Novembar 22, 2022 #4895 Napisano Novembar 22, 2022 Evo slušam 2x15 wata TDA7396 već danima, čisto da ga malo usviram. Realno, dosta je za po kući. Ne mogu baš samo1W, neam take zvučnjake.
NIXIE Napisano Decembar 1, 2022 #4896 Napisano Decembar 1, 2022 (izmenjeno) Možda nije ni vreme ni mesto, ali da pitam ipak ovde. Jel koristio neko ovakve prekidače za mrežni napon? Treba mi jedan za trafo 5VA, računam izdržaće ladno. Mora da bude ovako malecki jer je kutija malecka. Ili ako zna neko nešto slično, samo da liči na ovo i da ima obavezno plavo svetlo (LED). https://novi.kupujemprodajem.com/elektronika-i-komponente/moduli-za-samoizgradnju/12mm-vodootporni-antivandal-prekidac-plavi-led/oglas/136905917?filterId=2115971435 Osim toga nije mi jasno jel ovo prekidač ili samo taster? Meni treba prekidač, mali metalni. Izmenjeno Decembar 1, 2022 od NIXIE
bnb Napisano Decembar 1, 2022 #4897 Napisano Decembar 1, 2022 Konektuj se na sah.rs.Imaju ogromnu ponudu i tastera i prekidača.Cene su pooovoljne.Šalju pouzećem jer su se preselili na Meljak ako ti je daleko.
чика-Брка Napisano Decembar 1, 2022 #4898 Napisano Decembar 1, 2022 2 hours ago, NIXIE said: Možda nije ni vreme ni mesto, ali da pitam ipak ovde. Jel koristio neko ovakve prekidače za mrežni napon? Treba mi jedan za trafo 5VA, računam izdržaće ladno. Mora da bude ovako malecki jer je kutija malecka. Ili ako zna neko nešto slično, samo da liči na ovo i da ima obavezno plavo svetlo (LED). https://novi.kupujemprodajem.com/elektronika-i-komponente/moduli-za-samoizgradnju/12mm-vodootporni-antivandal-prekidac-plavi-led/oglas/136905917?filterId=2115971435 Osim toga nije mi jasno jel ovo prekidač ili samo taster? Meni treba prekidač, mali metalni. ja sam takve tastere u raznim bojama kupovao od lika sa KP iz Paracina. nisu tasteri, prekidaci su. vladd je reagovao/la na ovo 1
NIXIE Napisano Decembar 1, 2022 #4899 Napisano Decembar 1, 2022 Sumnjiv mi je onaj najmanji od 12mm. Ima malo dugme koje mora još da se utisne unutra. Deluje nepraktično. Možda se ipak vratim na kipp prekidač +LED iznad njega.
shonne Napisano Decembar 1, 2022 #4900 Napisano Decembar 1, 2022 (izmenjeno) 8 minutes ago, NIXIE said: Sumnjiv mi je onaj najmanji od 12mm. Ima malo dugme koje mora još da se utisne unutra. Deluje nepraktično. Možda se ipak vratim na kipp prekidač +LED iznad njega. Ima tasteri i od 16, 19mm...samo gledaj dal su latching ili momentary... 🤗 Izmenjeno Decembar 1, 2022 od shonne
shonne Napisano Decembar 1, 2022 #4901 Napisano Decembar 1, 2022 On 11/22/2022 at 5:24 PM, shonne said: https://www.diyaudio.com/community/threads/2x-seas-w26fx002-eu.392186/#post-7175145 Ko hoce da pravi Pass- ve kutije. Novi su komad oko 370 eur bez carine i pdv 🙂 Skroz nepraktican drajver. Ponasa se slicno kao moj 22W, stim sto trazi malo vecu litrazu... -3db mu vec na 40hz. A skup do bola. 10 incha SS ide jos bolje, 10hz nize. A ko ce njega da nadje polovno.
NIXIE Napisano Decembar 1, 2022 #4902 Napisano Decembar 1, 2022 pre 7 minuta, shonne reče Ima tasteri i od 16, 19mm Malecka je kutija, biće grdno.
shonne Napisano Decembar 1, 2022 #4903 Napisano Decembar 1, 2022 3 minutes ago, NIXIE said: Malecka je kutija, biće grdno. 16mm moci ces sa srednji prst da stisnes. Onako sa mali prst i 12mm bude problem 😁 A i 4mm nije bog zna koliko grdno... 😛
NIXIE Napisano Decembar 1, 2022 #4904 Napisano Decembar 1, 2022 Mislim da sam već odustao. Zato sam i pitao, sad vidim da i nije tako dobra ideja. shonne je reagovao/la na ovo 1
Gosha Napisano Januar 23, 2023 #4905 Napisano Januar 23, 2023 FNIRSI 1014D oscilloscopio digitale 2 In 1 generatore di segnale di ingresso a doppio canale 100MHz * 2 Ana log larghezza di banda 1GSa/s frequenza di campionamento|Oscilloscopi| - AliExpress IT.ALIEXPRESS.COM Smarter Shopping, Better Living! Aliexpress.com vladd je reagovao/la na ovo 1
NIXIE Napisano Februar 2, 2023 #4906 Napisano Februar 2, 2023 Jel ovo neka prevara? www.come2sales.com WWW.COME2SALES.COM
