PC kao izvor zvuka - tema MK II
dj.nik
M-AUDIO Audiophile 192,odlicna zvucna kartica,( odnos zvuk/cena),odavno je koristim za direktno (balansirano) ganjanje Cevnih PP Ampova,zahvaljujuci balansiranim izlazima 3,9Vpp/300 ohma izbegao sam bilo kakav obrtac faze.
Poz Svima :happy64:My link
:buehehe: samo da znate kako je sve ne modifikuju:
We've previously been scathing about soundcards: “Don't buy one, the only place for a DAC is outside a PC, abolish PCI for music, etc”. But for this one, we had to make an exception. If you really can't live with an off-board digital to analog converter, this Burson-modified card, distributed in the UK and Europe uniquely by Item Audio, is the only one to have. The Audiotrak Prodigy HD2 in stock form is one of the best sounding cards available for two channel audiophile playback, but the HD2-SE is seriously hot-rodded for uncompromised performance.
The HD2 incorporates many audiophile grade features: a low jitter oscillator, short signal paths, specialised power caps, and a fully differential output stage. It supports 192 kHz at 24-bit, with a sensational dynamic range of 120dB for playback. No other hardware in this price range provides this high level of output quality. The single most intractable problem for soundcards is noise and interference. Audiotrak caims to have resolved this issue completely with their PNK technology (PCI Noise Killer).
Few external USB DACs in the market can match the Prodigy's attention to detail. However, the Special Edition is an entirely different animal. For starters, the NE5532 op-amps have been replaced with no less than three fully discreet Burson Audio dual opamps – regarded by audiophiles and the recording industry as simply the best alternative to IC opamps. Their performance significantly surpasses the once popular OPA627. This mod alone pushes the design complexity of the HD2 beyond many audiophile DACs or CD players. Naturally the power supply of the HD2 has also been optimized for the Burson Opamps.
Close inspection revealed that the 'gold RCA connectors' of the standard unit were low grade plated aluminium connectors with poor quality soldering. So out they came in favour of top notch CNC RCA sockets which were more widely spaced to accommodate high quality single ended cables.
Compared to the stock version, the supercharged soundcard projects a much wider soundstage. Mids and highs are fuller and more realistically drawn. Fine detail and subtle intonations can now be heard and analysed at a micro level. The bass goes deeper and, more importantly, gains control and definition.
The card comes complete with ASIO 2, GSIF and WDM drivers for Windows versions. Please note that Apple Mac drivers are not presently available. We believe its the finest soundcard a discerning listener can buy, and it's the only one we are likely to offer in the forseeable future. We also think it's a bargain!
“I think it's worth every penny. Absolutely fantastic! What a beautiful sound. Thanks!” – JW
:buehehe:
http://www.itemaudio.co.uk/prodigy_hd2.html
ima i gorih od mene :popcorn:
Nađoh konačno sličice koje su intersantne (jedva, Audio Azylum forum ima neki ludi SW, jedva pregledam). Ne znam drugu karticu koja je više modifikovana od [email protected] a ovo je valjda sam vrh: Buffalo lemljen direktnona I2S izlaz (naravno skroz modovane) Juliške:post-9-049117200 1287271935_thumb.jpg post-9-047468900 1287271961_thumb.jpgKo ume, jel' da:drinks:
  • 1 month later...
gde da kupim picopsu u Serbiji ?mislim - ima kobajagi - proguglah , ali pise -nazovite za cenu- , sto ce reci - nema . poigrao bih se sa Intel® Desktop Board D201GLY http://reviews.cnet.com/motherboards/intel-desktop-board-d201gly/1707-3049_7-32463417.html , mozda da napravim nezahtevnu media masinicu koja bi bila i za torrente a media bi isao stream na verovatno WD ili slican gadget
Odgovara li ti nesto od ovih "power kit"-ova?http://www.procase.co.nz/PSU/powerPack.htm
Mini ITX sistemima se bavi PCX Computers atresa ovde . Trenutno nemaju PicoPSU u slobodnoj prodaji
(uvezeno namenski i isporuceno korisniku) ali ako se javnes mogu da naruce i stici ce za cca. dve nedelje.
Inace tu mozes da uzmes i ITX ploce, ima nesto Intelovih do Jetway sistema. Cene (sa procesorom) od ~70 do 200,
zavisno od snage itd. Takodje mini ITX kucista i ostalo..
A secam se i jednog oglasa bas 'vodje, interesantnog mozda ...
:drinks:
.....A secam se i jednog oglasa bas 'vodje, interesantnog mozda ... :drinks:
mea culpa - zaboravih napomenuti da je cela ideja bazirana na tome da je ploca vec u mojim rukama - stigla kao rezultat nekih kompenzacijaideja mi da napravim jedan nezahtevni silent pc ...... dakle - jos samo picopsu
cijene ?sorry ako gnjavim ...... ako imas info u glavi - "$$ za xx-W" reci , ako ne - ce zovem
Nazalost ne, ja sam jurio 150W (142,5W) plocicu i 'ciglu' odjednom. Sama plocica PicoPSU je $39 npr ovde a na e-bay idu sa napajanjem ~$85Najbolja za dc/dc resenja jeste 'Winmate'-ova, i ona je ~$30 na eBay, do 130W. (PS: kod proizvodjaca je duplo toliko):drinks:
