dunavko
Član-
1725 -
5
Sve objavljeno od dunavko
opet ja.na zvanicnom sajtu smo jedan red za stavku 5. evo Optional accessory Current sensor AC/DC 40A
a vinko ,video sam sa zakasnjenjem, za t5 .a tacka 4?
na tri oglasa sam izlistao i tek na cetvrtom pronasao UT139 Series digital multimeters are newly designed to offer users better performance and higher safety rating. Totally over-load protection and unique structural design make it new type of multimeter with high performance/ price ratio and a best choice for electricians used in electrical maintenance and repairing. 1.True RMS for the whole series; 2.Measure signals with varied frequency (VFC); 3.Measure large capacitance up to 100mF; 4.Optional AC/DC 60A current clamps in different models to measure current up to 60A(1mv=1A); 5.NCV designed for the whole series, a necessity for electricians; 6.AA1.5V*2(5#) battery, easy for users to purchase and replace; 7.Soft rubber holster is easy to stand 2m drop; 8.Optional magnetic hanging strap offered to facilitate tests in special location; 9.Fast to replace fuse, just by opening battery cover; 10.Reliable with use of internal 2PCS fuses with high-breaking capacity; 11.Protection against 600V input/1 minute from misconnection; 12.Safety Rating: CAT III 600V. tacka 4 ,znaci li to da je za amper klesta koja imaju za 1A 1 mv .kako moze dc sa tim klestima.da to nije sa nekom sentom -to mu je klamps? tacka5.jel to za redosled faza ?
kakva je ono oznaka za amper klesta i natpis od 60 A i polozaj iznad njega sa NCV?
onaj link sto si dao sa onom cenom ima i obavestenje : Товар не может быть доставлен to Serbia .jesi to video?
sem jezgra najvaznija je debljina zice.trafo mora da bude ko gibanica.sve mora da bude uskladjeno.a preko mirne struje ne mozes da vidis snagu trafoa.za vrednost mirne struje najvise utice nacin pakovanja limova,kako se okrecu,razmak,presek zice i itd..kad je magla a nemas kompas a prelazis dunav,dogadjaju se cudne stvari.sam osecaj da se kreces a nemas pojma gde plovis nekako zbunjujuce deluje na mozak .jadanput sam razgovarao sa covekom koji je 3 sata prelazio dunav iz banata do vince i stalno se vracao nazad i vec kada mu je nestalo i goriva dosao do ritopeka i lupa kod mene na kucicu.kad sam otvorio vidim neki deda sa bradom,izbezumljen koji mi postavlja pitanje:gde sam to ja?naravno toponica je daleko al kovin nije.;i zamislite da mi je postavio pitanje od cega najvise zavise parni armonici u klasi a kod se.ja bi odlepio,pobaco sam alkohol i pravac kovin,naravno camcem.ispostavilo se posle da je to otac od mog poznanika,ribara,i da je to covek sa 40 godina na reci.kad god sam bio u vinci a on tamo u klubu,imao sam besplatno pice od njega...
ceo zivot ucis i opet na kraju umres ko budala .hvala autoru lepe kompaske price. izveo me je na pravi put . om mani padne om -tako nekako . ja s kompasom kad su magle prelazim dunav al nece pouzdano da radi ako nije drveni camac .ne mora da bude analogno naravoucenije da i trafo mora da bude drven ili smederevac isto tako .kud ode ovaj broooddd....
pa zar nema neka bolja hidroizolacija od bitumena i condora.i ja treba nesto da radim pa pitam
nemora da bude selen.mozda su silcijumske ,posebno dizajnirane zbog hladjenja.napon punog olovnog je 14.4 v ,ispod 12 v dolazi do ubrzanog propadanja accu.preporuka je da se puni sa 1/10 nazivne struje .elektrolit ne treba jer je acuu ustvari elektrolit .proces sulfatizacije je neminovan.kristali sulfata rastu nepravilno i kada dovoljno porastu spajaju se sa suprotnom plocom.rusi su imali jedan sistem da kod sulfatizovanih accu ,na kratko dovode vecu energiju,40-50v i 100-nak ampera i na taj nacin spaljivali-topili te iglice sulfata.ko god to da radi neka accu stavi iza kuce koja mora da bude od cvrstog materijala i bez prozora.moze doci do eksplozije..nikad mi nije bilo jasno zasto se doliva samo voda ,pa zar i h2so4 isto ne isparava?
otkacis r1,tr da visi,moras da imas na izlazu 7815 15 v pod uslovom da stavis neki el.kon i neko opterecenje 150 oma.mnogo ce da bude disipacija ako je ul.napon 30 v!!!
mislio sam,posmatrano sa filozofske strane.broj elektrona u pn spoju MORA biti konacan.samim tim pn spoj je istrosiv,jednog trenutka u beskonacnosti trebalo bi da vise nema elektrona.samo treba biti strpljiv i cekati.svako od nas audiostilstaizohista ima u svom zivotu KONACAN broj tranzistora koji spali.samo se neko trudi da to uradi pre a neko kasnije...to vazi isto i za bure rakije..
i ja sam tako nekako mislio i onda cuo neke od tih vrsta,probo i promenio misljenje.ne kazem da su bolji ovi ili oni ali ovi sstate laksi za izradu i ekonomicniji.jedino ako se ovi izlazni mosfetovi ne istrose ko lampe.jos nisam cuo da se to dogodilo ali sve je moguce.i tih elektrona u njima ima konacan broj.logika je prosta.samo treba izdrzati slusajuci...
gde mogu da se nadju taki neki pa i manji hladnjaci?
bem ti lebac...
Parna mašina iz 1872 i još u funkciji!
dunavko je odgovorio/la mrcelavi's temus u Muzika , Film i Fotografija
koliko se secam,u ivanovu treba da bude jedna parna masina koja terala pumpu za vodu iz kanala koji opsuju ivanovo.ivanovo je vecim delom godine na nizem nivou od dunava. na staroj prevodnici na tisi kod beceja bila jedna p. masina koja je ,cini mi ,se otvarala kapije prevodnice... -
g.ziko,fali neki deo od toga sis-a izgleda.meni to izgleda kao auspuh od t34.Bilo je vise varijanti i modela sisa ,s kao sesir.jedan model sa stavljao na smederevac sa koga se skinu odgovarajuce ringle da taj sis upadne u rupu.pa taj vec vidjen koji je umanjena verzija onih profesionalnih.taj valjak je imao spoljno kuciste u kome se lozila vatra.a ona sipka je ustvari rucica za obrtanje da ne bi kafa zagorela.interesantno je da je sirova kafa vrlo higroskopna i za noc dzak od 60 kila popije i vise od 1 litre vode .tako je i sa jakim mirisima .posle przenja kafa se prilikom hladjenja "kalila" sa kaplicama vode da bi bila hrskava i lakse se mlela.kod opekotina ukoliko nemate mogucnost da odete kod doktora opekotina se posipala mlevenom kafom i rana je uspesno zarastala bez da ostanu oziljci. jos cuvam dva rucna mlina koji su nekad bili nezaobilazna alatka u kuhinji.sjajni mesingani.imam neke informacije da su se pravili u turskoj.zamislite varijantu ,da pre jedno 50 godina, energija koja se trosila na mlevenje hiljada mlinova odlazila u neke druge svrhe.mozda bi tako i za audiofile,generator na pedale i ako oces da slusas,pedalaj.al bi svi presli na d klasu...
moj drugar se svojevremeno bavio przenjem kafe.imao dve "masine" za przenje,od 16 kg i cini mi se vecu od 30 kila.ja sam cesto isao sa njim u nabavku i raznosenje przene kafe po raznim krajevima bgd.to su bila ona teska i sasava vremena raspada drzave .ali sirove kafe je bilo na trzistu.imali smo prilike da kupujemo razne vrste sirovih kafa i da eksperimetisemo sa mesavinama.interesantno je da je nas narod najvise voleo robustu,vrsta jeftine kafe pomesane sa 10-15 posto minas koja je bila puno skuplja.mi smo isprobavali razne varijante,od ciste minas ,robuste iz etiopije i brazila i jos jedne vrste koje se i ne secam kako se zove.sve je stvar navike.kao i ostalo u nasim zivotima.uglavnom.sada ima na trzistu mnogo vrsta,bogatstvo ukusa za sve pa i za probrane nepce ,slicno kao i kod audiofila.evo,da li neko zna sta je sis,s kao sisarka?
IZ BOSNE.. Staviti vodu u posebnu posudu da prokuha. Kahvu staviti u džezvu i dodati par zrnaca soli. Kada voda prokuha, džezvu staviti na vruću platu da se kahva malo ugrije i zatim zaliti prokuhanom vodom, promješati i pustiti da se kahva počne dizati. Kada se kahva počne dizati džezvu skloniti sa plate. Sačekati da se kahva malo slegne pa onda doliti vode do pune džezve. Pjena treba da bude gusta. Posluživanje Kahva se pije iz fildžana. Nasipa se tako da se najprije kašićicom malo promješa kajmak (pjena na vrhu) i onda se raspodijeli u svaki fildžan po malo, da bi u svakom fildžanu na vrhu kahve bio kajmak. Onda se kahva razlije u fildžane. Kahva se pije polako, kratkim srkovima, između kojih se prave pauze za uživanje u aromi i razgovor. Kahva se u pravilu služi sa kockama šećera koje se po malo umaču u kahvu i grickaju tako da se šećer zadrži u ustima i na njega se popije srk kahve. U posebnim prilikama se uz kahvu služi rahatlokum.
koliko imas ovih BHC od 1500uF?
mozda paralelno sa el. u katodi staviti i neki blok od par uF.pa jel morala bas ta p.sprega,zar se to toliko culi visoki da smetaju.zar nije to moglo nekako drukcije da se resi?
alo zerowaf,pa ma sta to ime znaciloo,vidi ovo,ponovo https://xn--g1ajus.xn--p1ai/?p=107
kako ce se vlasnik pomiriti sa spoznajom da ako oce kvalitet zvuka mora da promeni rezim rada 6v6 i da svede na 6-7w sinusa.kako ce z.kutije ako su neefikasne da rade?evo jedan primer i foto ovakve zatamnjene cevi.sema je prosta ,ima i ulin.izvod.e sada sta raditi sa onim praznim noval podnozjem? https://xn--g1ajus.xn--p1ai/?p=107
gledaj 6p6s ruske sa zatamnjenim balonom .to je najbolja u toj proizvodnji.
kada kazes sum ,sta mislis? 50hz,100hz brum,onako kao beli sum,pink..ima na netu kako zvuce..iscupaj ecc83 pa slusaj , i tako redom,mozda se nesto cuje.vidim grejanje je umasio minus.ima i ono da se preko razdelnika spoji sa Va.to sto nisu uparene 6v6 ne bi trebalo da bude izvor suma ili staje vec.umotaj al. foliju oko ecc83 i spoji sa zicom na masu.al prvo opisi kakav sum ili brum?
cevni pp, sta god da radio uvek zvuci slicno tranzistorcima.mozes da probas sta oces,radne tacke da menjas,trafoe ali zvuk je takav,bar meni . trioda SE je posebna prica i zato vredi cevno pojacalo.triode u konfiguraciji,nema vise ,to je vrh u tome.ovo tvoje je nesto isforsirano,sigurno je otislo u b klasu-15w sinus?.nisam odavno gledao karakteristike ali se secam da sam radio pp sa 6v6 nesto a - ab klasa i imao 6 w sinusa i plafon.neka neko pogleda karakteristike i vidi gde se taj izlaz nalazi.mnogo je 15w pp 6v6 da bude hifi kvalitet.
Trenutno na sajtu 3 članova, 0 Skrivenih, 24 Gosta (Pogledaj celu listu)
Ukupan broj tema452.7k
