9335 -
25
Postovi objavljeno od zika
2 hours ago, Mikorist said:
diya@diya:~$ cat /proc/sys/net/core/default_qdisc fq_codel diya@diya:~$
fq_codel ≠ fq that's the point...
55 minutes ago, Mikorist said:
/etc/init.d/shaper:
#!/bin/sh # init script written by insane clown # this script only creates the qdiscs and classes required for shaping, it # does NOT create the necessary filters INTERFACE='eth0' rc_done=" done" rc_failed=" failed" return=$rc_done TC='/sbin/tc' tc_reset () { # Reset everything to a known state (cleared) $TC qdisc del dev $INTERFACE root 2> /dev/null > /dev/null } tc_status () { echo "[qdisc - $INTERFACE]" $TC -s qdisc show dev $INTERFACE echo "------------------------" echo echo "[class - $INTERFACE]" $TC -s class show dev $INTERFACE } tc_showfilter () { echo "[filter - $INTERFACE]" $TC -s filter show dev $INTERFACE } case "$1" in start) echo -n "Starting traffic shaping" tc_reset U320="$TC filter add dev $INTERFACE protocol ip parent 1:0 prio 0 u32" # # dev eth0 - creating qdiscs & classes # $TC qdisc add dev $INTERFACE root handle 1: htb default 60 $TC class add dev $INTERFACE parent 1: classid 1:1 htb rate 116kbit $TC class add dev $INTERFACE parent 1:1 classid 1:10 htb rate 32kbit ceil 116kbit prio 0 $TC class add dev $INTERFACE parent 1:1 classid 1:20 htb rate 22kbit ceil 116kbit prio 1 $TC class add dev $INTERFACE parent 1:1 classid 1:30 htb rate 22kbit ceil 116kbit prio 2 $TC class add dev $INTERFACE parent 1:1 classid 1:40 htb rate 20kbit ceil 116kbit prio 3 $TC class add dev $INTERFACE parent 1:1 classid 1:50 htb rate 18kbit ceil 116kbit prio 4 $TC class add dev $INTERFACE parent 1:1 classid 1:60 htb rate 2kbit ceil 116kbit prio 5 $TC qdisc add dev $INTERFACE parent 1:10 handle 10: sfq perturb 10 $TC qdisc add dev $INTERFACE parent 1:20 handle 20: sfq perturb 10 $TC qdisc add dev $INTERFACE parent 1:30 handle 30: sfq perturb 10 $TC qdisc add dev $INTERFACE parent 1:40 handle 40: sfq perturb 10 $TC qdisc add dev $INTERFACE parent 1:50 handle 50: sfq perturb 10 $TC qdisc add dev $INTERFACE parent 1:60 handle 60: sfq perturb 10 tc_status ;; stop) echo -n "Stopping traffic shaper" tc_reset || return=$rc_failed echo -e "$return" ;; restart|reload) $0 stop && $0 start || return=$rc_failed ;; stats|status) tc_status ;; filter) tc_showfilter ;; *) echo "Usage: $0 {start|stop|restart|stats|filter}" exit 1 esac test "$return" = "$rc_done" || exit 1
Zato ne volem EGR, automatic menjač, i tako dalje...
I rest my case, have fun.
- LightMatic, Mikorist and Srecko je reagovao/la na ovo
- 3
14 minutes ago, Mikorist said:
Mogu da siključe NIC u BIOS zajedno sa grafikom i svim USB. Tako i narihtavaju NUC. Bolje nego da se pate sa ovim komandama u beskraj .
Nema tatstature...miša , mreže i displeja. Problema 0
Whatever, 'teo sam da pomognem, sorry...
Bump.
1 hour ago, Zen Mod said:
sta cu ja, koji nemam NUC?
Nemam ga i ja.
- 1
Srećom te sam dovoljno zakasnio da mi kupe ovu igračku...
https://gajitz.com/1950s-radioactive-science-kit-most-dangerous-toy-ever/
- Srecko and LightMatic je reagovao/la na ovo
- 2
1 hour ago, Srecko said:
Potpuno sam saglasan sa tekstom koji ste napisali u postu iznad.
Moja "rezerva" u vezi sa prioritetima koje kernel treba da zadovolji, prvenstveno u vezi sa bezbednošću, uzrokovana je time da su nažalost hakiranja sistema-mreža postala DRŽAVNI POSAO veoma tehnološki naprednih država: USA, Rusija, Kina, Izrael .....
Takođe ova moja "rezerva" o bezbednosti Linux mašina sa RT kernelom je generalna i za mene je potpuno nebitna jer oba moja NUC ne služe ničemu osim kao muzički serveri (cak je i muzika na disku u njima).
Ono sto mislim (do sada ne pročitah ni jedno mišljenje da bih promenio svoje razmišljanje) je da je zvuk ipak jednostavna fizička pojava (u odnosu na druge fizičke pojave) te da stvarno ne trebaju tako značajni računarski resursi biti upotrebljeni da bi se postigao high gidelity. Da simplifikujem, ponekad u HiFi stičem utisak da firme (i pojedinci) gađaju topom muvu, za čim (po meni) nema potrebe.
1. bezbednost je vrlo tečan pojam. No, recimo, uživao sam trebeći jednu od većih teka koje postavi Mika, našlo se dosta toga što je, već, iščilelo sa mog bliskog horizonta i otišlo na onaj daleki. rado sam se podsetio i ojačao neke ograde kako kod sebe tako i na nekim drugim mestima. Jednom kada se pomirite sa tim da nema full-proof zaštite i naučite da proveravate sva vrata prilikom izlaska i ulaska i... sve bude lakše i pouzdanije... Drago mi je da sam se naterao da pogledam taj file, prošlo je vreme od poslednjeg ojačavanja, kao paranje džempera, sve je prečešljano, obućar često ide bos, i po cenu vrlo malog umanjenja brzine, posebno mrežnog protoka, ojačanje je povećano, bez, da ja primećujem, promene u zvuku. Hvala na podsticaju. Hardening nije samo u jezgru, naprotiv...
2. zvuk, nas, ovde, ne bi trebalo da progoni već da u njemu uživamo. Rekao bih da je, kod većine, tako. Nje cilj već prevozno sredstvo na putu ka miru.
3. Do topova se stiže ne zbog mete nego zbog zarade, kako bi se zaradilo kada bi se uvidelo, ne ovde, ovde je to jasno, da i čačkalica radi pos'o.
4. sve postaje značajno jednostavnije kad se shvati da bezbednost, na obe strane novčića, čine ljudi a ne uređaji. Ali... Što bi moja baba, solunka, kraljeva telefoniskinja, prva žena upravnica pošte, rekla, što čovek sklopi, čovek može i da rasklopi.
- Srecko, Lemić and LightMatic je reagovao/la na ovo
- 1
- 2
- 1
1. nisam ja iko značajan, da se ne varamo. Daleko od toga, posebno u oblasti zvuka. Just an ordinary user with some debatable mileage...
2. i čačkalica je jednostavan alat ali može biti, u pogodnom trenutku, ubojita. Pa, opet, retko čujemo da je neko od nje stradao...
3. ne verujem u competency samo i baš samo, u razgovor i činjenice... Najređe verujem samom sebi...
4. kao glavno pravilo našeg uživanja u zvucima uzimam lični ustisak i ono što slušanje probudi u nama pa bio to i onaj, nekadašnji, „tranzistor“...
5. i turbo je u SUS motorima opasna alatka pa je, opet, rado i uporno koristimo, a ume da „preuzme“ vozilo...
6. o RT je počela, ovde, priča, zvuka što se tiče, kao načina da se postigne bolji, ali, nije to jedini put i tako dalje... Svaki „lek“ ima i svoje neželjene pojave.
7. ponavljam, ne znam, tačno, šta je, baš, u pomenutom izdanju Ubuntu, moguće je da i jeste real'time jezgro, pogledaću, čim stignem, dobijem priliku.
8. nemojte verovati strancima, tako su me učili kad sam bio mlad i to važi i za mene, kao @zika ovde... samo činjenicama...
9. ono malo što, u svemu, znam je posledica moje bandoglavosti; uletim u nešto glavom bez obzira i, vadeći se, moram da učim šta i kako... Realno, pun intended...
10. server-ima i nije potreban rt, brzinu bi trebalo da stiču na, mnoge, druge načine. RT je za druge potrebe, CNC i slično...
Uopštavanje je đubrivo koje smanjuje prinos u lejama.
Nalete mi jedno, sasvim, lepo objašnjenje, za lakše uvođenje u razgovor, pre neki dan:
Blog post series - Shuhao
SHUHAOWU.COMVoleo bih da vidim koji je to kernel u Ubuntu 22.04 LTS Server RT. Moguće je da grešim, ne bežim od toga. Ako ima, samo, čuveni patch to ga, i dalje, ne čini RT. Dao sam, ranije, vezu ka jezgru koje je najbliže RT, uz odgovarajuća podešavanja u primeni.
sudo sysctl net.ipv4.tcp_available_congestion_control net.ipv4.tcp_available_congestion_control = reno bbr bbr2 bic cubic dctcp westwood highspeed hybla htcp vegas veno scalable lp yeah illinois
Da, vidim da je u izbore ali zašto nije odabrano, nema ga kao module-a ili...? Lepo radi...
10 minutes ago, Mikorist said:
Plus za Netflix
Netflix?
8 minutes ago, Mikorist said:
Evo još jedan dobar trik za ubrzanje
Easily Boost Ubuntu Network Performance by Enabling TCP BBR
WWW.LINUXBABE.COM
This tutorial shows you how to enable TCP BBR on Ubuntu. TCP BBR is a TCP congestion control algorithm developed by Google.će da pravimo jopet iso
a bbr2?
- Mikorist, asimze and LightMatic je reagovao/la na ovo
- 3
Mea culpa: ja sam mislio da želite da bude xanmod pa sam savetovao kako da se odabere onaj koji je odgovarajući za HW, automat-ski. Zaboravite na moju upadicu, sve je jasno. Jasno je da glasam, uvek, u tom izboru, za sajdžiju.
1 hour ago, Mikorist said:
Ali bi se zadržao na Debian. Mnogo je stabilnije za remastering kroz GUI
Naravno, svako ima svoj tool i navika na isti je, često, važnija od same alatke...
Ja sam, pa, CLI oriented, kernel nema GUI dok se ne pokaže da je uspešan, tada više i nije u razvoju...
Biće i to...samo ne znam kad.
Polako, ne pišem zbog sebe...
18 minutes ago, Mikorist said:
Pa može i više njih da bude....pa se onda bira. Ali to povećava veličinu ISO.
Najbolje je sam svako sebi da instalira ceo sistem...
Ne, ne bi povećavao ISO. Stavite kernel koji ste odlučili, odradi se ISO, kod prvog, sledećeg, pokretanja odradi install xanmod, on ima ugrađen odabir odgovarajućeg izdanja za processor koji nađe, zbacite početni kernel i to je to. Prvi reboot i xanmod je odgovarajući. Samo 2¢...
7 hours ago, Mikorist said:
6.1.0-5-rt-amd64
kernel - koji zika koristi....$ uname -r
6.3.0-060300rc1daily20230307-genericNe koristim ja rt kernel all the time, pošto je potrebno pratiti najsvežije, testing, debugging, preparing newer versions of _rt_, _rt_ je, skoro uvek, nekoliko pod-izdanja iza....
in Digital
x3
