NIXIE
Sve objavljeno od NIXIE
  1. Nisam Zene ništa izmislio, veza glavne membrane i voice coil-a kod mnogih konstrukcija izvedena je mekanim spojem koji ne prenosi visoke frekvencije na tu veliku membranu nego samo whizzer (ili kalota kod nekih) može da radi iznad neke frekvencije jer je on čvrsto vezan za voice coil za razliku od velike mebrane. Na to sam mislio, to postoji i zove se mehanička skretnica. This crossover type is mechanical and uses the properties of the materials in a driver diaphragm to achieve the necessary filtering. Such crossovers are commonly found in full-range speakers which are designed to cover as much of the audio band as possible. One such is constructed by coupling the cone of the speaker to the voice coil bobbin through a compliant section and directly attaching a small lightweight whizzer cone to the bobbin. This compliant section serves as a compliant filter, so the main cone is not vibrated at higher frequencies. The whizzer cone responds to all frequencies, but due to its smaller size only gives a useful output at higher frequencies, thereby implementing a mechanical crossover function. Careful selection of materials used for the cone, whizzer and suspension elements determines the crossover frequency and the effectiveness of the crossover. Such mechanical crossovers are complex to design, especially if high fidelity is desired. Computer aided design has largely replaced the laborious trial and error approach that was historically used. Over several years, the compliance of the materials may change, negatively affecting the frequency response of the speaker.
  2. A šta da radim kad ne volem ni tu koncepciju ni taj zvuk, to je nekako jače od mene. To me uvek podseća na neku razglasnu tehniku iz prošlih vremena. Valjda sad neće da se naljute vlasnici FR zvučnika sa lončetom.
  3. Ti sa Whizerr-om i nisu pravi FR nego praktično dvosistemski jer iznad neke frekvencije radi samo Whizzer. Zato na delu gde rade obe membrane imaš krš od faze i frekventne karakteristike, i čuveni midrange shout.
  4. Znam da je neko radio. Pošalji čoveku detalje i ja mislim da je taj DAC extra kad se lampizira. Možda je malo tiši nego stock varijanta, ali to je po meni čak i bolje jer većina (pa i ja) ima pretpojačala sa nepotrebno velikim pojačanjem. Moj DAC je duplo manjeg napona izlaza od Marantz CD63, leglo ko pedu na nošu.
  5. Ok pogledaj, ali umesto lampe može i neki drugi buffer recimo fet, samo da nije sa OP. Traži pomoć na forumu, znaće šta treba možda je neko već radio nešto slično.
  6. To je zbog OP, taj DAC je mnogo dobar al ga ubiju jer urade izlaz prema uputstvu proizvođača, i onda je gotovo. Da ne pominjem elektrolite kroz koje prolazi signal, to je i gore od OP. Vidi ovde kako je urađeno, mislim da je samo cathode follower stavio. http://www.lampizator.eu/lampizator/REFERENCES/Cambridge Azur/Cambridge Audio Azur 640C ALmpizator.html Sad sam pogledao taj DAC ti je Vout znači ne treba nikakva konverzija, samo buffer sa lampom i dobrim kondenzatorom na izlazu.
  7. Odmah pređi na lampe, ako je sa 3OP kako vidim sad na slikama onda ti nisi ni čuo taj DAC kako treba. Vidi šta je Fikus radio sa Wolfsonima pa konsultuj ovde znalce na sajtu da li je to dobro kako je uradio ili može bolje.
  8. Kako bre nemaš Paypal? Moja preporuka je Banca Intesa kartica i udri.
  9. Kakav je izlaz (I/U konverzija), jel sa OP? Ako je sa OP, ili ne daj bože više, njih izbaci sve OP i stavi jednu lampu i eto ti rezolucije i dinamike.
  10. NIXIE
    NIXIE NOS DAC
    Šta reći, fenomenalno! Imam još jednu sitnicu da sredim, ne radi mi dobro muting ako ne rešim kako da dobijem odgovarajući signal sa WM8804 ima da ga izbacim. Evo pitanja za poznavaoce problematike, na WM8804 postoje četiri digitalna izlaza za razna stanja, od njih bi trebalo nožica 2 (GP00/SWIFFMODE) da bude ta koja daje izlaz (0 ili 1 sve jedno, lako ću prilagoditi) kada je SPDIF signal korektan, ali od ta četiri izlaza ni jedan ne menja stanje kada svira muzika, a ne bi trebalo tako da bude. Imam prekidač na pločici pa sam isključio muting za sada da mogu da slušam, ali ako i to rešim biće savršeno, ako ne ostaće po nekad da se čuje neki cvrrrrk, ali nije toliko bitno jer se retko dešava. Kad ga uključujem i isključujem ne čuje se apsolutno ništa, tako da muting nije mnogo bitan, ali eto kad sam sve ostalo uradio voleo bih i to da imam. wm8804_schematic.pdf wm8804_2.0_manual.pdf
  11. NIXIE
    NIXIE NOS DAC
    Možda bi i eloksirao prednju ploču, ali taj aluminijum koji sam imao mislim da nije bio baš za eloksažu, sečen je hidrauličkim makazama pa nisu bile lepe ivice, imalo je malo deformacije od sečenja, to se posle šmirglanja i plastifikacije ne vidi a sa eloksažom bi se videlo. Za eloksažu treba uzeti veću ploču nego što treba da može iz nje da se opsecanjem dobije lepa ivica. I treba da bude malo trvđi aluminijum, a ovaj je bio mekan kao puter.
  12. NIXIE
    NIXIE NOS DAC
    Aha, izvini nisam razumeo. I napred i pozadi urađeno je UV printerom, uradio sam fajlove u Auto CAD-u i odneo u Copy centar KUP, majstor to uvuče u Corel, odštampa i zapeče. Može da bude u boji/bojama po izboru, ali ja nešto stalno radim belo. Može biti bilo šta, oni tu spravu koriste da štampaju reklame na raznim proizvodima. I nije skupo, oko 1000din prednja i zadnja ploča.
  13. NIXIE
    NIXIE NOS DAC
    Uradio kum, nisam ja tako vičan tome, ima dve pločice jedna sa NIXIE, led i drajverima za NIXIE, druga sa svim ostalim i konektor između.
  14. NIXIE
    NIXIE NOS DAC
    Proradio i displej. Sad mi se ne dopadaju one zelene led izgledaju više kao da su žute, ima da kupim dve plave da ih zamenim. Slikanje sa blicom neće da može, moram da slikam bez blica sija ko jelka.
  15. Treba da bude pad napona oko 8mV na R24/R25 za mirnu struju 53mA odnosno oko 16mV ako meriš preko oba. Ako pojačalo drži nulu i mirnu struju onda su izobličenja posledica neispravnosti strujne zaštite Q10, Q11 ili nekog elementa oko njih, diode otpornici... Proveri i vrednost RC (Zobel) na izlazu R27 C12. Da li su dobri R24 i R25?
  16. Taman posla da ne rade kad su hand made u Češkoj!
  17. Pošto je svaki zvučnik nelinearan, osetljivost je neka srednja vrednost brda i dolina u propusnom opsegu. Nije tako jednostavno i praktično svi proizvođači navode veće vrednosti nego što je realno. Nekad je u dB/1W/1m nekad u dB/2,84V/1m.
  18. To crno na vu metru je verovatno od pregrevanja onog tranzistora u plastičnom kućištu. Zameni elektrolit i dodaj hladnjak na tranzistor.
  19. Meni liči da su otišli oni na current limitu q10 q11 i diode oko njih 1n4148 oni mogu otići kad crknu izlazni, kao i svi elementi uz njih. Proveri sve tranzistore naročio q8 kao i sve diode.
  20. JLH? To će da radi jedno vreme i sa fake delovima ako ga dobro oladiš. Kad pocrkaju 2N3055 stavi 2N3773 ili MJ15003. Motorola nikad nije imala takva kućišta TO3, možda je bolje da odmah turiš neke domaće izlazne.
  21. Šta će sad da radi kad vlasnik otvori paket i vidi da nema USB ulaz?
  22. Mene ne teraju, idem sam! Više volem da idem na poso, nego leba da jedem.
  23. Samo za ljubitelje TPA3116, dobio na poklon od burezera. Snimak je onako (nema basa), ali ne svira uživo uopšte loše, malo mu fali basa i visokih i čuje se jedva čujan šum iz zvučnika kad prislonim uvo na visokotonac. Za sada sam ga probao samo preko Bluetooth i mobilnog kako svira sa Youtube. Ima i audio ulaz 3,5mm nemam dovoljno dugačak kabal da ga povežem na CD, a da ne premeštam sve na polici. Kupiću neki adapter. Ideja je da bude u dečijoj sobi pa da napravim satelite + sub sa nekim malim driverima ala Boenicke i da se pušta muzika sa mobilnog. Ovo je Breeze audio verzija sa dva kanala + izlaz za sub, ovako nešto (mislim da je bata malo jeftinije našao, ali to je taj model):https://www.aliexpress.com/item/2016-Breeze-Audio-BL20A-TPA3116-Hifi-2-1-Bluetooth-4-0-Digital-Audio-Power-Amplifier-50Wx2/32711055898.html
  24. Biće bolje nego novo!
  25. Ako budeš otvarao za kontrolu, slikaj sve molim te, mene mrzi da otvaram.
  • Trenutno na sajtu   4 članova, 2 Skrivenih, 1131 Gosta (Pogledaj celu listu)
