Mikorist
Sve objavljeno od Mikorist
  1. https://youtu.be/agiAXBGLhAc?si=apKHhp3_8SBsSCva
  2. Mikorist
    K: 2N6609 dva komada
    Brate ti ne odustaješ od kineske lutrije . To kao greb-greb kolo sreće . Kupiš uvek jedan više.
  3. Mikorist
    IT razno.
    Epilog https://www.diyaudio.rs/topic/10654-diyaudiors-linux-os/page/27/#comment-449449
  4. Novi Beograd, Novi Sad,‎ Novi Pazar‎, Novi Kneževac‎, Novi Bečej‎, Nova Varoš‎, Nova Crnja‎. Nastranu šalu na stranu, napravio sam skriptu (Demona) koja radi isto što i Pi-hole i ubacio direkt u sistem. /usr/local/bin/update_hosts.sh #!/bin/bash default="https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts" tmp_hosts_file="/tmp/hosts.tmp" system_hosts_file="/etc/hosts" system_hostname=$(hostname) if ! curl -sSf "$default" -o "$tmp_hosts_file"; then echo "Preuzimanje datoteke hosts nije uspelo." exit 1 fi cp "$system_hosts_file" "$system_hosts_file.backup" #cuvanje hostname sistema echo "127.0.0.1 $system_hostname" > "$tmp_hosts_file" grep -E -v "^127\.0\.0\.1[[:space:]]+$system_hostname" "$system_hosts_file" >> "$tmp_hosts_file" # Replace the system's hosts file with the new one if ! sudo cp "$tmp_hosts_file" "$system_hosts_file"; then echo "Azuriranje fajla sistemskih hostova nije uspelo." # Vracam rezervnu kopiju ako azuriranje ne uspe sudo cp "$system_hosts_file.backup" "$system_hosts_file" exit 1 fi echo "Datoteka hosts je uspesno azurirana sa imenom hosta sistema." # Clean up rm -f "$tmp_hosts_file" rm -f "$system_hosts_file.backup" /etc/systemd/system/update-hosts.service [Unit] Description=Update /etc/hosts file Wants=network.target After=network.target [Service] ExecStart=/usr/local/bin/update_hosts.sh [Install] WantedBy=multi-user.target tajmer /etc/systemd/system/update-hosts.timer [Unit] Description=Timer for updating /etc/hosts file Wants=network.target After=network.target [Timer] OnCalendar=daily Persistent=true [Install] WantedBy=timers.target sudo systemctl daemon-reload sudo systemctl enable update-hosts.service sudo systemctl start update-hosts.service sudo systemctl status update-hosts.service sudo systemctl enable update-hosts.timer sudo systemctl start update-hosts.timer Automatski dnevno ubacuje najnoviji https://raw.githubusercontent.com/StevenBlack/hosts/master/hosts čuvajući header i to je to. Nema plaćanja i ostalog, a nema i pogleda preko tarabe. Postoji već decenijama i nema ikoga ko se požalio. Da ja znam. Ovako izgleda sajt N1 posle ovoga. Tu gde su oglasi su rupe Ovo iznad nije dovoljno za Chrome. Treba i ovo dodatno kao ekstenzija: GitHub - mikorist/skip: Chrome extension to auto skip youtube videos seamlessly like AdBlockers GITHUB.COM Chrome extension to auto skip youtube videos seamlessly like AdBlockers - GitHub - mikorist/skip: Chrome extension to auto skip youtube videos seamlessly like AdBlockers I ovo stalno zastareva jer bukvalno svake nedelje menjaju SKIP dugme
  5. Apdejtovan Linux - prvi post
  6. Mikorist
    IT razno.
    Ama ne možeš na DNS nivou da blokiraš reklamu u video zapisu . Fizički ne može. Imaš neki drugi bloker koji ti to radi. Za sad . Tik tak....ne beri brigu javićeš se kad se dogodi p.s. Nek se jave svi kome iskače imate bloker itd
  7. Mikorist
    IT razno.
    Ali reklama je u videu . Mora da blokira ceo video da bi blokirao reklamu. Guglaj malo. Youtube ads getting through Pihole / Any advances in 100% blocking without also blocking Youtube videos? DISCOURSE.PI-HOLE.NET Youtube ads getting through Pihole This is normal and expected. Pi-hole only sees DNS requests for domains (in this case, the Youtube domain). Pi-hole can completely block the domain, or allow the domain. There is no third option. Btw....Ni uBlock Origin više ne radi. a $13.99/month ne dam
  8. Mikorist
    IT razno.
    Probao....Djoku radi na YouTube . Moras ručno da skip reklamu u video zapisu...A ako imaš ekstenziju protivu toga banuje. Kad dođeš na stage 4 više nema da vidiš ništa. Mora nov Gugl nalog da napraviš. Ili da platiš. Plus banuje IP adrese.....Može da se desi da popiješ od komšije IP koja ne vidi ništa.
  9. Ima još jedan oglas sa tim istim modelom. I na njima su glanc nove membrane. Slična cena. Mislim ima ih raspalih na ebay - pa šta ko voli
  10. Mora da su reparirani. Za 40 godina bi se raspali da su samo stajali na vazduhu. Niko ne drži zvučnike vakumirane. Japanci to sređuju da ne možeš očima da provališ. Jbg. kvalitet papira imaju najbolji. Možda bolji i od orginala.
  11. Mikorist
    IT razno.
  12. Zato DTS X and Dolby ATMOS encode discs zvuče da se usereš u odnosu na ostale kompresije. Ali jebiga ko će da drži "Dark Side of the Moon" na hard disku veličine 70GB
  13. Mikorist
    IT razno.
    Gledanje YouTube bez reklama je sve komplikovanije i komplikovanije postalo.
  14. Mikorist
    Prašina
  15. Lepo će da naprave sintetički serum i nema više etičkih-pravnih zavrzlama...... Samo to neće da spreči reset planete.
  16. jeste hoax ali me ne bi čudilo da to urade . nekad kad pojeftini FBS serum . ne verujem da će tada reporter da se kezi ovako providno
  17. Konačno se vraćamo da postajemo ljudožderi. Mislim da je vrieme za neki reset planete tipa ... meteor , kometa , super vulkan
  18. Ja sam odavno odustao da gledam šta Audiophiliac kenja. Boli njega briga za komentare..... Ima dovoljno pratioca da ne mora ništa drugo da radi sem da yutubira.
  19. Što ne javljaš da pišeš tamo komentare po tube ?
  • Trenutno na sajtu   2 članova, 0 Skrivenih, 22 Gosta (Pogledaj celu listu)
    452.7k
