Showing content with the highest reputation on 06/08/25 u svim oblastima
  1. Vix
    Nije za ovo temu...ali svaki put kad cujem muziku uzivo, (unplugged) izbedacim se. Ma kakvi DAC ovi, pojacala, zvucnici...kao da jurimo bledu kopiju kopije zvuka, koji nam je neko ukrao...
  2. Ovo je baš baš brzo. Naleteo na PCie SSD 1 TB kartnicu OCZ RevoDrive3X2 . Nikad korišćena sa celofanom na pakovanju. Legla ko budali šamar u Antec Fusion HTPC kućište. Dosadilo mi da svaki put palim externi HDD sa audio fajlovima ( ne volim kad se nepotrebno diskovi vrte dok je PC uključen zato koristio eksterne diskove). Naravno back up na dva nezavisna 2 TB HDD-a za nedaj bože na ormanu iza prošlogodišnjih dunja. Operativni sistem na Samsung SSD a flacovi na OCZ. Foobar leti, učitavanje novog albuma istog trenutka po kliku. Preporuka ako se naleti. INTRODUCTION The OCZ Revo 3 x2 PCIe SSD enters the consumer market as the fastest consumer available storage solution by a land slide. OCZ specifications list high sequential performance as 1.5GB/s read, 1.25GB/s write and capable of 200, 000 IOPS at 4k random write disk access. Coincidentally, this is also the first consumer targeted product that brings us out of megabyte per second speeds and into the realm of gigabytes per second.The Revo 3 x2 will be available in capacities of 240GB, 480GB and 960GB and at $1699.99 and $3199.99 for the latter two, we can see these being looked at closely by enterprise, the likes of which are going to be pleasantly surprised at our IOPS testing
  3. SMSL ili RME ima i u BG. Ne mora da vuče ništa sem kreditnu karticu RME ADI-2 DAC FS - Player Plus doo WWW.PLAYER.RS The ADI-2 DAC includes an improved SteadyClock, a fine-tuned to perfection analog circuitry, new MRC remote control, Extreme Power headphone output and a very special IEM output. It has all
  4. Pa oće čovek najbolji....Ima tu raznih Rockna modela. Plus je jeftinije kad se ode kod lika u Rumuniju za kešovinu... Drugo rešenje je da se pravi DIY - da ima balansirane izlaze - LCD - daljinski - bluetooth. Pravio @NIXIE Mirov DAC takav P.S. Najeftiniji Rockna Wavelight DAC sam slušao. Bolest. Sve kutije su ručni rad - aluminijum 4-5mm debljine - slično kao što radi Leo. Znači tenk.
  5. zerowaf
    Iron cobra za klaviriste?
  6. BANAT
    Kvalitet cevi EL-519
    Ja tebi nisam predlagao da redizajniras samo obrtac faze nego ceo ulazno-obrtacki deo , tako da od Melos dela ostane samo drajversko-izlazni stepen koji sadrzi dve 12BH7 lampe i 4x519 lampe , za ulazno naponsko pojacalo mozes da iskoristis jednu 12AX7 lampu dok za obrtac faze mozes da iskoristis jednu 12BH7 lampu , B+ linija napajanja tog stepena da bude recimo oko 450V , ovo navedeno se odnosi na spoj (Mullard 5-20) kao iz prethodno prilozenih shema 1 i 2 .
  7. Zen Mod
    ZM, random zanimacije
    sve ono sto Nelson radi zadnjih par godina na Big DIyA i jeste na tu temu - prvenstveno za popularizaciju hobija i ukljucenje mozga recimo, moj Babelfish F8, moze da se aranzira da bude daleko hladniji i sa manje snage, a sve to onda ispadne tepsija ribe ili eto, Egocentric ACA fixxxer pokusava da napravi jedan, al smeta mu vrucina
  8. 1 poen
  9. blaidd
    pozdrav! ...bio na buvljaku/sajmu ploca, izmedju ostalog, slijedecih cca. pola sata: VIDEOSEX, 84, CD reizdanje iz 2009
  • Trenutno na sajtu   0 članova, 1 Skrivenih, 1578 Gosta (Pogledaj celu listu)
