Showing content with the highest reputation on 07/21/17 u svim oblastima
  1. NIXIE
    AIKIDO LINE PREAMP
    AIKIDO preamplifier sa 6N3P/5670 lampama. Kupjeno na Aliexpress-u prerađeno na napajanje od 220VDC i skutijano. Kompletan projekat sa šemama. Najbolji zvuk je trenutno sa 6N3P-EV lampama NOS iz 1983, gold grid, Viniza fabrika iz Ukrajine. Može da radi i sa 6N23P (E88CC) uz upotrebu adaptera (to je baš na slikama). Prvo je bilo u plastičnim kutijama za probu i doterivanje. Sa Aliexpress-a je ovo https://www.aliexpress.com/item/YJ-Hi-end-6N3-X4pcs-Tube-preamplifer-completed-board/32379040972.html?spm=2114.13010608.0.0.MLkI0F i ovo https://www.aliexpress.com/item/5pcs-universal-Stripboard-Veroboard-8x11cm-pcb-3-5er-joint-hole-Prototype-Paper-FR4-Fiberglass-tin-circuit/32392731307.html?spm=2114.13010608.0.0.9yTpQe Lampe su s ebay-a ostalo je kupljeno u RS Components Srbija, Kelco i Mikroprinc, dugmići su iz Kanibala a trafo je Trafco. Kutija je Al plastificirana, prednja i zadnja ploča urađena na UV printeru u Copy centar KUP. Original.pdf Aikido.pdf Napajanje.pdf Tajmeri.pdf Uzemljenje.pdf
    10 poena
  2. Zen Mod
    ZM
    nije moto udomili dva siroceta na Divcibarama
  3. Zflazar
    AIKIDO LINE PREAMP
    ima članak Morgan Jones-a o kuvanju cevi: http://www.vacuumstate.com/fileupload/Baking_valves pix.pdf e sad, ispada da su cevi poput vitamina, neke termostabilne a neke termolabilne. da ne trujem više Nixievu temu ali me podsetilo i na još jedno pomodarstvo o kom je bilo pre nekoliko godina dosta reči, o kriotretmanu cevi, o kome citiram autora članka: The vacuum tube industry today certainly does seem to suffer from more than its fair share of marketing hype. Like the washing-up powder market, the tube market is ‘awash’ (sorry I couldn’t resist that one) with all kinds of nonsense such as cryo-treatment, tube dampers, tube coolers and even rebranding modern manufacture tubes under the names of once great manufacturers – cheap gimmicks that are no subsitute for real engineering. All this nonsense makes purchasing good quality tubes more complicated and difficult than it should be. My advice when buying tubes: invest in tubes from a reputable vendor that checks and matches them on a tube tester and guarantees them or better still, seek out vintage N.O.S. vacuum tubes made by the likes of Mullard, Philips, Sylvania or the other tube manufacturing giants from the golden age of tube manufacture – we’re fortunate that they are still supplies of N.O.S. tubes available and there are deals to be had. ...i... The reality is that cryogenic treatment is not a remedy for inferior materials or defects in tube construction. It simply doesn’t work. ceo članak: http://www.effectrode.com/cryogenic-treatment-tubes-engineers-perspective/ ...bože, počinjem da zvučim samom sebi kao @vladd
  4. Zflazar
    Gramofonska tema
    ožičenje je provereno, bilo je nekih voodoo-sr*nj* sa njim unutar ručke koja su otklonjena
  5. NIXIE
    AIKIDO LINE PREAMP
    Zahvaljujem, stavio sam ovo drugima na raspolaganje jer za oko 200-250 evra može da se uz nešto truda dobije mnogo dobro pretpojačalo, a ne mora da se gubi vreme na dizajn i pravljenje pločica. Celo pretpojačalo na Aliexpress-u košta manje nego da se kod nas uradi dvostrana pločica sa metalizacijom rupa i maskom.
  6. Zflazar
    Gramofonska tema
    ...da se vratim i ja na gramofonske teme... Iz nekog meni nepoznatog razloga kombinacija Braun PS500/Ortofon SPU-NE je daleko osetljivija na elektromahnetna polja transformatora/prigušnica nego Kuzma Stabi MkI/Ortofon SL15MkII tako da mi je dosta pojeo živaca brum koji se čuo nakon stavljanja novog gramofona na policu. Prvo sam naravno sumnjao na ground loop pa je krenulo sistematično pretresanje raznih shema uzemljenja, lov na dupliranje mase uređaja prema uzemljenju na šukou, da bi pri pomeranju silnih kutijetina napajanja, phono preampa odjednom brum promenio intenzitet i tu me je prvi put ogrejalo sunce. Vratio sam uzemljenja na staru poziciju, pretumbao napajački deo izlaznog pojačala u najudaljeniji deo od gramofona i phono preampa, tako da sada imam pozadinsku grobnu tišinu na sistemu i mogu konačno da se posvetim slušanju muzike. Za sad sam možda 10-tak ploča poslušao sa novim gramofonom u bezbrumnom stanju, mogu da kažem da je tonski karakter i zvučna prezentacija slična kao kod Wolanda sa Ortofon SPU Royal glavom po pitanju izvanredne muzikalnosti za razliku od Ortofon SL15MkII koja je u ovom poređenju više na strani forenzike, slično kao kod Wolandovog Benz Micro LP S. Sada mi još sledi slatka muka da napravim neku prekidačku skalameriju koja će imati izbor dva ulaza za gramofone i jednim izlazom prema step-up transformatoru (na sreću obe zvučnice su sa niskom impedansom pa mogu na isti SUT) da oba gramofona mogu da budu u funkciji bez prebadanja konektora na transformatorskom ulazu.
  7. stein
    AIKIDO LINE PREAMP
    Pozdrav novom članu, pre svega, a odmah potom i čestitke za predivno odrađen projekat Dobrodošao na forum, slobodno nastavi ovako Kada nađeš vremena i volje, slobodno u profil dodaj lokaciju tj mesto/grad gde živiš (zarad lakše komunikacije sa drugim članovima) a ako hoćeš, možeš i reč dve o sebi, ostatku opreme koju imaš/koristiš, neke slušne impresije o uređaju koji si ovde predstavio...
  8. Ko i ja , razumijem ( njihov) al nakon 3 pive prigovorim ?
  9. crni.
    Gramofonska tema
    gramofon? msm, tema je o gramofonima
  10. stare konobare nisam video, sve mlade devojke...i preslatko pričaju engleski
  11. @black coffe znam (za jadac) to - i ima logige, ne arčiš im konobara, stolicu
  12. a ima i ovo...stara španska poslastica...ušećereni orašasti plodovi, badem, lešnik, brazilski orah itd...7,5e 100g mix i uvek je red
  13. ima.. npr čak i u Veneciji espreso za 0,8€ + čaša vina iz bureta 0,9€, a ima i espreso na Trgu Svetog Marka za 16€
  14. ujbt, najebo sam kad ovi moji počnu da se razmnožavaju
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 1483 Gosta (Pogledaj celu listu)
