Showing content with the highest reputation on 02/12/17 u svim oblastima
  1. Dacho
    Gramofonska tema
    Continuum Caliburn ima ugrađenu svu silu danasnje tehnologije i to se skupo placa jer se jos uvijek moze prodavati kao nesto "specijalno" a ustvari je to relativno jeftina tehnologija samo ju treba primjeniti.... Inace je i kod njih zanimljiv sistem lezanja tanjura. Visestruko su se ogradili oko mogucnosti primanja vibracija i lakoce vrtnje: Continuum chose the ball-and-thrust-plate approach over an air-bearing platter because they believe, among other things, that if you don't mechanically ground a platter, vibrations created within it have nowhere to go but back to its surface—and all rotating platters, no matter how carefully machined, wobble and vibrate to some degree (bearing imperfections also play a part in this). To reduce the enormous downward force of the Caliburn platter's mass while maintaining the contact between bearing, ball, and thrust plate, and allowing oil to circulate between ball and plate, the platter is magnetically levitated, leaving only 6 lbs of downward pressure. Continuum and other advocates of traditional bearings claim that speed accuracy actually improves and requires less correctional monitoring when there is some minimal frictional drag—something air bearings lack.
  2. Eci
    Kupuj dok nije otišlo...
    Pre dva dana sam koristio takvu ručicu kod Salaija u Budimpešti - veoma moćna ručica, vredi pare zvučnica je bila odlična SPU nude Black E gramofon Micro Seiki RX1500
  3. sir Oliver
    Lepota dizajna
    Ne nikako. Nego imam neke retro komode pa gledam da li bi mogao da skarabudžim nešto slično. Apropo zvučne slike meni u HiFiju nije toliko vašna ni stereo ni dubinska slika. Najviše mi znači timbar i prirodnost zvuka.
  4. Ras
    Gramofonska tema
    Gramofoni sa mikroprocesorima i tangencijalnim ručicama pravljeni su i pre 40 godina. Mnogi od njih i danas rade, ima ih po oglasima, često i za male novce u odnosu na ono što nude.
  5. Zflazar
    Gramofonska tema
    ...ne bih dalje da medim ovaj EMT (nisam kupac ni prodavac navedenog na KP) ali ako je to model sa ugrađenim phono preampom, plus ručka plus baza, mislim da bi to nekom rešilo (ili napravilo WAF etc...) dosta problema na duge staze...
  6. Kad se profesionalci infiltriraju na ulične klavire
  7. prophet
    Lepota dizajna
    Da se kulturno izrazim, na kurac mi idu Man Cave, WAF i slicne pizdarije. Svaka postena kuca treba da ima biblioteku. Sistem za reprodukciju muzike, fonoteku. Lepo je kad ima i vinoteku. Sve u skladu sa mogucnostima. I poneka umetnicka slika, lep komad namestaja... Koliko sam golih zidova video, na njima eventualno stoji uramljena diploma. A literature zahvaljujuci kojoj se stiglo do diplome nigde. Valjda se danas do diploma dolazi na neki drugi nacin.
  8. Ne znam da li sam to ovako napisao ali se razlika može čuti između različitih strujnih kablova - u usporedbi sa konfekcijski zalivenim gajtanima koji se isporučuju uz razne uređaje koji koriste IEC konekciju (PC monitori, DC ispravljači, PC/laptop napajanja i sl.) - medžutiM... Između ultra-giga-mega kabela koji ima u3lepeskupe konektore i izolaciju od nenađijuma/prepucijuma pa je još pride izveden kao spiralno motana poslaćena limena traka i valjano spojenog (terminisanog) kabela sa kvalitetnim ali ne i skupim konektorima se ta razlika naprosto ne može tako jasno, dobro i nedvosmisleno primetiti - ako je i ima, ja je ne čujem. Meni i toliko dovoljno. Dakle, razlike postoje na relaciji dobro tj kvalitetno sagrađenih i problematično skurcanih gajtana. Sve preko jeftinog ali kvalitetnog spoja je pitanje ćeifa, prestiža, autosugestije, religije...
  • Trenutno na sajtu   4 članova, 0 Skrivenih, 99 Gosta (Pogledaj celu listu)
    450.8k
    Meho
    Meho
