Pusticu Goshi poruku, pa cu vidjeti sta i kako. Jel bi mogao probati onu auto antenu na njega. Meni izgleda malo glupo ideja al opet sta znam
pa to ne stavljas tuner vredan 15E ( i to ako radi) na sto da povezes sa instrumentima koji i dan danas vrede 1KE i vise jes da ne trebaju mnogo, ali kad trebaju , ne mozes bez njih na stranu sto majstor mora da zna znanje, i to nesto vredi
The British rock band The Who installed twelve JBL 4350 studio monitors in the control room of their Rampart Studios in Twickenham, England. This massive setup was used for monitoring and final mixdowns of master tapes during recording sessions in the mid-1970s. The JBL 4350s were the highest-output monitors JBL produced at the time, with each speaker capable of a sustained output of over 125 decibels. The Who famously utilized multiple JBL speakers at Ramport Studios in Battersea, South London, to record and mix their landmark 1973 double album, Quadrophenia. The band established Ramport specifically to capture a powerful, "live" sound for the ambitious project, which was originally intended to be mixed in quadraphonic sound. Speaker Configuration at Ramport Studios The Setup: While the initial plan for the studio featured Lockwood speakers, these were replaced before opening with eight JBL 4320s to handle the high-volume requirements of the band. Quadraphonic Layout: Four of these monitors were placed at the front of the control room and four at the back to facilitate the quadraphonic mixing process. Power: These speakers were driven by high-output Crown DC300 amplifiers to achieve the desired "live" intensity. Studio History Location: Ramport Studios was located in a former church hall at 115 Thessaly Road in Battersea (not Twickenham). Ownership: The Who owned the studio through a company called Ramport, with all four band members serving as directors. Legacy: In addition to Quadrophenia, the studio was used to record other classic albums, including Supertramp’s Crime of the Century and Judas Priest’s Sin After Sin. It was later purchased by Virgin Records in 1983 and renamed Townhouse 3
Bogdan08 je počeo da prati člana Tuner Riz T4130
Zeznuto je to na sluh tako cackati, ostale stanice hvata fino, i na am radi kako tako sa sklepanom antenom. Nije puno radio kolko znam, sad ako bih ga popravljao ne znam koliko bi kostalo, ako je skuplja pita od tepsije, dzaba mi onda. Jedino sto je vrv dosta prost za popraviti samo pitanje za pronalazak nekih dijelova btw ni jedan radio mi ne hvata das 2, jedino u kecu kad spojim cajevac antenu i razvucem one krakove, onda uhvati, al to sam davno probao na kratko. Prolazi mi kroz glavu, da li bi se mogla uz izvor napajanja i prepasivanje konektora spojiti ta antena
kupi drugi tuner slaba vajda od kokosarskog vrljanja po filterima i rezonantnim kolima ........... been there, done that a RIZ tuner je neisplativa zivuljka da se salje kod @Gosha na kopcanje na psotene instrumente
Zdravo svima. Imam problemcic sa ovim tunerom, do skora sam mogao uhvatiti das 2 bijeljina, a sad nikako. Otvorim tuner i skinem poklopac glave (ili kako se vec zove) oznake gfe 110 i podesim mu usput hod sa 87.8 na 87.3 pa do 108 mhz. Medjutim prijem ove stanice koji god trimmer mrdnuo po malo nemam. Usput da kazem svi mali elektroliti su novi, ako uopste ima kakvog uticaja na tu putanju Do sad je prijem bio uz krcanje al opet hvatalo je, jedino mi prolazi kroz glavu da snijeg tu pravi kakve smetnje ako nije u tuneru nesto zviznulo
Soulscene -
Rat bušilica! 110.627 Aufrufe · 629 Reaktionen | The Ultimate Drill Battle | John... WWW.FACEBOOK.COM The Ultimate Drill Battle -
Pronađoh i njegov rad Researchers believe chilling new Shroud of Turin discovery proves one major Jesus theory WWW.UNILAD.COM The Shroud of Turin is believed by some to be the cloth in which Jesus was buried, but it has a controversial history
Sada tek vidim koliko je frapantna sličnost sa Jim Caviezel-om. Dobro je to još onomad Mel Gibson sa saradnicima uočio i doveo Jim-a na kasting. The Passion of the Christ (2004) - IMDb
Nisam ja prvi kome je palo na pamet da uzme geometriju sa platna i da je onda provlači kroz digitalne / AI parametre dok ne dobije slikarsku verziju u boji. Taj fazon je već radio Otangelo Grasso, i to baš sa idejom da se zadrže prave proporcije, a ne da AI “izmišlja lice”. Kod mene je fora sledeća (zato kačim i sliku sa prelazima): uzme se postojeća, proverena geometrija AI se koristi više kao render alat, ne kao autor anatomije ide se korak po korak, bez random generisanja (samo se uklanjaju rane i deformacije - polomljen nos je najteže rekonstruisati)
Razumem veoma dobro šta je ključno, kao i tvoje oduševljenje tehnologijom. Isto tako sam ubeđen da si ti prvi koji je na ovaj način i ovom složenom tehnikom "oživeo" Spasitelja Sveta.
Sta je to "magnetni sklop viskotonaca"?
Meni je ovde ključno to što je AI danas prvi put dovoljno snažan da obradi svaki piksel i da celu fizionomiju, proporcije, mikro-senke i reljef prenese u 2D ili 3D bez morfoloških izmena. To ranije nije bilo moguće, ne zbog ideje, već zato što tehnologija jednostavno nije postojala.
Kažu da je Teslina izreka - Nije mi žao što su ukrali moje ideje, već što nisu imali svoje - Miko, svaka čast za entuzijazam i trud. Ovaj tvoj rad je originalan i carski 🤴
Plaštanica je crno-beli negativ, svet bez boje, sloj od par stotina nanometara. Rekonstrukcija kroz AI donosi lice u boji, ali ostaje verno proporcijama i svetlu izvora, bukvalan prelaz iz crno-belog sveta. Tačna boja tena nije poznata, jer su ljudi u Judeji tada imali svetlo do srednje smeđu kožu sa varijacijama. Kod Leonarda je ten još svetliji i ima ‘glow’ efekat
jedino je malo previse beo .......
Radio sam hiperrealnu sliku Salvator Mundi kroz dug proces sa više AI alata, ali ne kao “generaciju slike”, već kao ikonografsku rekonstrukciju. Polazna tačka nije bila mašta, nego: Torinsko platno (proporcije glave, osa pogleda, odnos čelo–nos–brada), skeniranja i analize lica i ogromnim rezolucijama, poređenje sa Leonardovim i kanonskim proporcijama. Ključni problem koji sam morao da presečem: AI stalno pokušava da rekonstruiše lice......čak i 2–3% promene lobanje, vilice ili čela odmah ruši ikonografski osećaj. Zato je ovde: lice pixel-to-pixel zaključano (0% morfologije), GROK AI *(300.000 GPU) korišćen samo za: svetlo, mikro-senke, ivice, temperaturnu i teksturalnu integraciju, ništa nije “ulepšavano”, samo fizički uvezano sa telom. evo rezultat
Trenutno na sajtu 6 članova, 2 Skrivenih, 57 Gosta (Pogledaj celu listu)
Ukupan broj tema448.4k
