Aleks Napisano Septembar 5, 2018 #1 Napisano Septembar 5, 2018 The Basics of Sound Before discussing the specific components of audio-related circuits and electronics, let's first take a crash course on the basic concepts of sound. Sound is simply a type of energy vibrating through a medium (such as air or water); this energy, within a specific range of frequencies, is interpreted by the human ear as sound. Sound is made up of three basic elements: Frequency: how fast the vibrations are occurring Intensity: how loud the sound is Timbre: the sound's quality The human ear can detect sound frequencies ranging from 20 to 20,000 Hz. However, the human ear is more sensitive to (i.e. able to discern at lowest intensity) frequencies ranging between 2,000 and 5,000 Hz (see Hearing Range - Wikipedia). Recall that Hertz (Hz) is a unit defined as cycles per second. A sound's intensity corresponds to the amount of energy associated with that sound. The decibel (dB) is used for measuring the sound's energy in a way that is relevant to how humans perceive loudness. In the context of audio, the decibel is defined as follows: dB = 10 log10 (I/I0) where I = the measured intensity (W/m2) I0 = 10-12 W/m2, which represents the lowest sound intensity detectable by the human ear The figure below shows a variety of sounds and their dB intensity measurement. Examples of sounds and their intensity (in dB). Image courtesy of ODYO Hearing Care. Timbre is the complex wave pattern that occurs when overtones (also referred to as harmonics) are present along with the fundamental frequency. For instance, a tuning fork is designed to produce exactly one specific frequency, called the fundamental frequency. Let's say we have a tuning fork that produces a middle C note (261.62 Hz)—click here to hear middle C tuning fork. Since a tuning fork generates only one frequency, no other frequencies (overtones) exist. However, if you were to hear a middle C played on a violin—click here to hear middle C on violin, you would hear both the fundamental frequency (261.62 Hz) and a variety of other, albeit less intense, frequencies (overtones). The specific intensity of each overtone is largely credited for giving an instrument (or a person's voice) its unique timbre (also called tonal quality). Microphones: Dynamic, Condenser, and Electret The microphone is responsible for converting changes in sound pressure to changes in electric current. The intensity of the changes in sound pressure corresponds to the AC voltage amplitude generated by the microphone. Likewise, the frequency of the changes in sound pressure corresponds to the frequency of the AC voltage. Obviously, if any overtones are present, they too are present in the electrical signal generated by the microphone. Three common types of microphones are the following: dynamic condenser electret The Dynamic Microphone The dynamic microphone consists of a plastic diaphragm, a voice coil, and a permanent magnet. See figure below. A dynamic microphone cross-section. Image adapted from MediaCollege.com When varying sound pressure is applied to the diaphragm, the voice coil moves back and forth through the magnet's magnetic field, resulting in a voltage across the leads of the voice coil. Hence, the sound pressure is converted to a voltage signal. Dynamic microphones are known for being very rugged, for being able to operate over a wide temperature range, for providing smooth and extended frequency response, and for not needing an external power source. They are widely used in applications such as public address and high-quality recording. The Condenser Microphone The condenser microphone (see figure below) uses a pair of charged plates that can be brought closer together or forced farther apart by changes in air pressure (i.e., sound). In doing so, the charged plates act like a sound-sensitive capacitor. This type of microphone works in conjunction with a low-noise, high-impedance amplifier. Condenser microphones are known for providing crisp, low-noise sound and are used for producing high-quality sound recordings. A condenser microphone's basic components. Image adapted from ProSoundWeb The Electret Microphone An electret microphone is actually a microphone and a JFET in a single package. The gate of the JFET provides a very high impedance and thus ensures that the charge on the electret element remains fixed. The charge must remain fixed to ensure that changes in capacitance (caused by sound waves) result in voltage changes. The JFET also converts the varying (gate) voltage into varying (drain-source) current. While the electret element itself does not require power (because its permanently charged) the overall electret microphone device requires a power supply because the integrated JFET needs bias current. Older electret microphones were known to deliver poor performance, but modern devices can compete with condenser microphones. An electret microphone, Image adapted from Northwestern University. Types of Speakers Microphones convert sound signals into electrical signals. Speakers do the exact opposite: they convert electrical signals into audible (sound) signals. The dynamic speaker, which uses the same operating principles as the dynamic microphone, is the most popular speaker used today. When a varying electrical signal (current) is channeled through a moveable coil (voice coil) surrounded by a magnet, the coil moves back and forth. Cones (often made of paper) attached to the moving coil then produce variations in air pressure (i.e., sound waves) that correspond to the electrical signal driven through the speaker coil. Parts of a dynamic speaker. Image courtesy of the Virtual Institute of Applied Science Every speaker has a nominal resistance—or, more accurately, an impedance—that represents the average resistance between the speaker leads. Thus, speakers behave similarly to resistors when placed in series and in parallel. See the figure below. Speakers in parallel behave the same as resistors in parallel. Frequency response, an important speaker characteristic, represents the frequency range over which a speaker can successfully propagate sound waves. Speakers can be categorized according to the frequency range that they are designed for: Woofers: speakers designed specifically for low frequencies (less than 200 Hz) Midrange: speakers designed to accommodate frequencies ranging from 500 Hz to 3000 Hz Tweeter: a dedicated speaker type specifically designed to handle frequencies above those of midrange speakers Full-range speakers: capable of handling frequencies ranging from 100 Hz to 15,000 Hz Full-range speakers have inferior sound qualities when compared to a sound system consisting of woofers, midrange speakers, and tweeters. Such a three-way speaker system is illustrated below. A typical three-way speaker system consisting of a tweeter, a midrange speaker, and a woofer. Image adapted from Georgia State University Amplifiers 101 Audio amplifier have three types of classification: Preamplifier Low-power amplifier Power amplifier An audio preamplifier (often shortened to "pre-amp") is an electronic device that amplifies a very weak signal from a microphone, as an example, into signals strong enough to manipulate. Pre-amps are often simple, fixed-gain amplifiers designed specifically for low-noise performance. A low-power amplifier is often used to manipulate signals including such aspects as volume and frequency equalization. This type of amplifier generally focuses on changing the character of the signal in desired ways while introducing as little unwanted distortion as possible and may provide little to no actual power amplification. An audio power amplifier ("power amp") is used to increase the signal power so as to drive a load, such as output speakers. Similar to pre-amps, power amps are often fixed gain (in terms of signal amplitude) so that designers can focus on high-power gain and the power handling challenges that typically result. In simple audio systems where high power and high fidelity are not critical factors, a single-amplifier circuit may perform all of these functions, and, in fact, specially designed operational amplifiers, such as the LM-386 Low Voltage Audio Power Amplifier, are often used this way. A Class D audio amplifier is a switching or PWM amplifier where the switches are either fully ON or fully OFF, which significantly reduces the power losses. Class D amplifiers take on many different forms, including some that have digital inputs while others have analog inputs. Conclusion Audio electronics can be summarized as converting sound to electrical signals, processing the electrical signals, and turning these processed signals back into sound. This is a straightforward objective; nevertheless, this particular discipline of electrical engineering covers many areas of the EE world. In fact, many practicing engineers spend their entire careers researching, developing, and designing audio electronics and related equipment. Spachek and 2a3 je reagovao/la na ovo 2
Mikorist Napisano Septembar 5, 2018 #2 Napisano Septembar 5, 2018 9 minutes ago, Aleks said: The Basics of Sound Before discussing the specific components of audio-related circuits and electronics, let's first take a crash course on the basic concepts of sound. Sound is simply a type of energy vibrating through a medium (such as air or water); this energy, within a specific range of frequencies, is interpreted by the human ear as sound. Sound is made up of three basic elements: Frequency: how fast the vibrations are occurring Intensity: how loud the sound is Timbre: the sound's quality The human ear can detect sound frequencies ranging from 20 to 20,000 Hz. However, the human ear is more sensitive to (i.e. able to discern at lowest intensity) frequencies ranging between 2,000 and 5,000 Hz (see Hearing Range - Wikipedia). Recall that Hertz (Hz) is a unit defined as cycles per second. A sound's intensity corresponds to the amount of energy associated with that sound. The decibel (dB) is used for measuring the sound's energy in a way that is relevant to how humans perceive loudness. In the context of audio, the decibel is defined as follows: dB = 10 log10 (I/I0) where I = the measured intensity (W/m2) I0 = 10-12 W/m2, which represents the lowest sound intensity detectable by the human ear The figure below shows a variety of sounds and their dB intensity measurement. Examples of sounds and their intensity (in dB). Image courtesy of ODYO Hearing Care. Timbre is the complex wave pattern that occurs when overtones (also referred to as harmonics) are present along with the fundamental frequency. For instance, a tuning fork is designed to produce exactly one specific frequency, called the fundamental frequency. Let's say we have a tuning fork that produces a middle C note (261.62 Hz)—click here to hear middle C tuning fork. Since a tuning fork generates only one frequency, no other frequencies (overtones) exist. However, if you were to hear a middle C played on a violin—click here to hear middle C on violin, you would hear both the fundamental frequency (261.62 Hz) and a variety of other, albeit less intense, frequencies (overtones). The specific intensity of each overtone is largely credited for giving an instrument (or a person's voice) its unique timbre (also called tonal quality). Microphones: Dynamic, Condenser, and Electret The microphone is responsible for converting changes in sound pressure to changes in electric current. The intensity of the changes in sound pressure corresponds to the AC voltage amplitude generated by the microphone. Likewise, the frequency of the changes in sound pressure corresponds to the frequency of the AC voltage. Obviously, if any overtones are present, they too are present in the electrical signal generated by the microphone. Three common types of microphones are the following: dynamic condenser electret The Dynamic Microphone The dynamic microphone consists of a plastic diaphragm, a voice coil, and a permanent magnet. See figure below. A dynamic microphone cross-section. Image adapted from MediaCollege.com When varying sound pressure is applied to the diaphragm, the voice coil moves back and forth through the magnet's magnetic field, resulting in a voltage across the leads of the voice coil. Hence, the sound pressure is converted to a voltage signal. Dynamic microphones are known for being very rugged, for being able to operate over a wide temperature range, for providing smooth and extended frequency response, and for not needing an external power source. They are widely used in applications such as public address and high-quality recording. The Condenser Microphone The condenser microphone (see figure below) uses a pair of charged plates that can be brought closer together or forced farther apart by changes in air pressure (i.e., sound). In doing so, the charged plates act like a sound-sensitive capacitor. This type of microphone works in conjunction with a low-noise, high-impedance amplifier. Condenser microphones are known for providing crisp, low-noise sound and are used for producing high-quality sound recordings. A condenser microphone's basic components. Image adapted from ProSoundWeb The Electret Microphone An electret microphone is actually a microphone and a JFET in a single package. The gate of the JFET provides a very high impedance and thus ensures that the charge on the electret element remains fixed. The charge must remain fixed to ensure that changes in capacitance (caused by sound waves) result in voltage changes. The JFET also converts the varying (gate) voltage into varying (drain-source) current. While the electret element itself does not require power (because its permanently charged) the overall electret microphone device requires a power supply because the integrated JFET needs bias current. Older electret microphones were known to deliver poor performance, but modern devices can compete with condenser microphones. An electret microphone, Image adapted from Northwestern University. Types of Speakers Microphones convert sound signals into electrical signals. Speakers do the exact opposite: they convert electrical signals into audible (sound) signals. The dynamic speaker, which uses the same operating principles as the dynamic microphone, is the most popular speaker used today. When a varying electrical signal (current) is channeled through a moveable coil (voice coil) surrounded by a magnet, the coil moves back and forth. Cones (often made of paper) attached to the moving coil then produce variations in air pressure (i.e., sound waves) that correspond to the electrical signal driven through the speaker coil. Parts of a dynamic speaker. Image courtesy of the Virtual Institute of Applied Science Every speaker has a nominal resistance—or, more accurately, an impedance—that represents the average resistance between the speaker leads. Thus, speakers behave similarly to resistors when placed in series and in parallel. See the figure below. Speakers in parallel behave the same as resistors in parallel. Frequency response, an important speaker characteristic, represents the frequency range over which a speaker can successfully propagate sound waves. Speakers can be categorized according to the frequency range that they are designed for: Woofers: speakers designed specifically for low frequencies (less than 200 Hz) Midrange: speakers designed to accommodate frequencies ranging from 500 Hz to 3000 Hz Tweeter: a dedicated speaker type specifically designed to handle frequencies above those of midrange speakers Full-range speakers: capable of handling frequencies ranging from 100 Hz to 15,000 Hz Full-range speakers have inferior sound qualities when compared to a sound system consisting of woofers, midrange speakers, and tweeters. Such a three-way speaker system is illustrated below. A typical three-way speaker system consisting of a tweeter, a midrange speaker, and a woofer. Image adapted from Georgia State University Amplifiers 101 Audio amplifier have three types of classification: Preamplifier Low-power amplifier Power amplifier An audio preamplifier (often shortened to "pre-amp") is an electronic device that amplifies a very weak signal from a microphone, as an example, into signals strong enough to manipulate. Pre-amps are often simple, fixed-gain amplifiers designed specifically for low-noise performance. A low-power amplifier is often used to manipulate signals including such aspects as volume and frequency equalization. This type of amplifier generally focuses on changing the character of the signal in desired ways while introducing as little unwanted distortion as possible and may provide little to no actual power amplification. An audio power amplifier ("power amp") is used to increase the signal power so as to drive a load, such as output speakers. Similar to pre-amps, power amps are often fixed gain (in terms of signal amplitude) so that designers can focus on high-power gain and the power handling challenges that typically result. In simple audio systems where high power and high fidelity are not critical factors, a single-amplifier circuit may perform all of these functions, and, in fact, specially designed operational amplifiers, such as the LM-386 Low Voltage Audio Power Amplifier, are often used this way. A Class D audio amplifier is a switching or PWM amplifier where the switches are either fully ON or fully OFF, which significantly reduces the power losses. Class D amplifiers take on many different forms, including some that have digital inputs while others have analog inputs. Conclusion Audio electronics can be summarized as converting sound to electrical signals, processing the electrical signals, and turning these processed signals back into sound. This is a straightforward objective; nevertheless, this particular discipline of electrical engineering covers many areas of the EE world. In fact, many practicing engineers spend their entire careers researching, developing, and designing audio electronics and related equipment.
vladd Napisano Septembar 5, 2018 #3 Napisano Septembar 5, 2018 Au koliko netacnosti u jednom postu, i to moderatora. Zvuk se ne MERI nego osluskuje, kakvi crni vati, u pitanju je timbre & prat. I pride, koji crni inzenjeri, audio elektronikom se najvise bave random zanimanja... Vreste zvucnika, Tannoy, pa svi ostali, zatim se dele na fensi i obicne, velike i male.... Pojacala se dele na lampionska i pescana, preampovi na pasivne i aktivne.... Sto godina je u ovome i jos veruje internetu a ne ljubiteljima.
Woland Napisano Septembar 5, 2018 #4 Napisano Septembar 5, 2018 @Aleks i šta - ti već počeo nastavu i prozivaćeš sutra?!
NIXIE Napisano Septembar 5, 2018 #5 Napisano Septembar 5, 2018 47 minutes ago, Mikorist said: Full-range speakers: capable of handling frequencies ranging from 100 Hz to 15,000 Hz Samo to, ništa ispod 100Hz, a preko 15k što ne može nema veze to i onako ne čuje 80% foruma.
NIXIE Napisano Septembar 5, 2018 #6 Napisano Septembar 5, 2018 45 minutes ago, vladd said: Au koliko netacnosti u jednom postu, i to moderatora. Zvuk se ne MERI nego osluskuje, kakvi crni vati, u pitanju je timbre & prat. I pride, koji crni inzenjeri, audio elektronikom se najvise bave random zanimanja... Vreste zvucnika, Tannoy, pa svi ostali, zatim se dele na fensi i obicne, velike i male.... Pojacala se dele na lampionska i pescana, preampovi na pasivne i aktivne.... Sto godina je u ovome i jos veruje internetu a ne ljubiteljima. Osnove si savladao, sve znaš, idemo dalje. vladd je reagovao/la na ovo 1
Mikorist Napisano Septembar 5, 2018 #7 Napisano Septembar 5, 2018 13 minutes ago, NIXIE said: to i onako ne čuje 80% foruma. sa trubicom se čuje sve Leonardo je reagovao/la na ovo 1
NIXIE Napisano Septembar 5, 2018 #8 Napisano Septembar 5, 2018 8 minutes ago, Mikorist said: a trubicom se čuje sve Nije dotle još došlo.
Aleks Napisano Septembar 5, 2018 Autor #9 Napisano Septembar 5, 2018 Ma post napisan u skladu sa google zahtevom - da bude elektronika a ne ono drugo sto ce nas google kazni Tacnost nisam proveravao, evo vladd ce
skrstic Napisano Septembar 5, 2018 #10 Napisano Septembar 5, 2018 3 hours ago, Aleks said: Full-range speakers: capable of handling frequencies ranging from 100 Hz to 15,000 Hz Full-range speakers have inferior sound qualities when compared to a sound system consisting of woofers, midrange speakers, and tweeters. Ovo samo pivo može da spere. U velikim količinama. djmilicic and NIXIE je reagovao/la na ovo 2
vladd Napisano Septembar 5, 2018 #11 Napisano Septembar 5, 2018 50 minutes ago, Aleks said: Ma post napisan u skladu sa google zahtevom - da bude elektronika a ne ono drugo sto ce nas google kazni Tacnost nisam proveravao, evo vladd ce Ih, kada je na engleskom, pa ko te pita da li je tacno, to je biblija
Zen Mod Napisano Septembar 5, 2018 #12 Napisano Septembar 5, 2018 nemo neko Miku da mi dira! Mikorist je reagovao/la na ovo 1
NIXIE Napisano Septembar 5, 2018 #13 Napisano Septembar 5, 2018 9 minutes ago, vladd said: Ih, kada je na engleskom https://habr.com/post/142012/ https://tannoyaudio.jimdo.com/конструкция-динамика/
vladd Napisano Septembar 5, 2018 #14 Napisano Septembar 5, 2018 Raytracing acoustic. http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.112.9833&rep=rep1&type=pdf
Pchelac Napisano Septembar 5, 2018 #15 Napisano Septembar 5, 2018 Bravo Alex, odlično za početnike... Neki dan sam objašnjavao komšiji, koji je 8mi razred , kako da veže dva ista basa u nekoj sklepanoj kutiji...Ima omladine koja hoće da pravi...
shonne Napisano Septembar 5, 2018 #16 Napisano Septembar 5, 2018 Ovo samo pivo može da spere. U velikim količinama. Pa da... Sve to,... tannoy i ostala boranija za sissys... [emoji39] skrstic je reagovao/la na ovo 1
Aleks Napisano Septembar 5, 2018 Autor #17 Napisano Septembar 5, 2018 1 hour ago, Pchelac said: 8mi razred Bio sam na raspustu izmedju 7. i 8. razreda kada sam rasturio dva vokmena... Gledao u neke sitne raznobojne stvarčice na nekoj pločici... Pitao starog, a on revnosno odgovarao: To je tranzistor, to je kondenzator, to je otpornik... Kod komšije našao garnituru Sam svoj majstor časopisa i tamo rubriku "Elektronika" gde bejahu šeme kako se spajaju te raznobojne stvarčice i pravi nešto treće... Ostalo je istorija A zvučnik... skretnica. Igram se ja, dve žice na izlaz ampa, a u ruci bass drajver. Stavim ispred njega otpornik, zvuk se umanji. Hm. Vežem redno kond, izgubi se bas. Hm hm hm interesantno! Vežem u red kalem, izgube se visoki! Uuuuu jebote, proboj u nauci!
Pchelac Napisano Septembar 5, 2018 #18 Napisano Septembar 5, 2018 Ovaj je bio vezao 2 basa od 4 Ohma u paralelu...
zek Napisano Septembar 5, 2018 #19 Napisano Septembar 5, 2018 1 hour ago, Pchelac said: Ovaj je bio vezao 2 basa od 4 Ohma u paralelu... i još se nije pojavio beli dim...
tubelover Napisano Septembar 5, 2018 #20 Napisano Septembar 5, 2018 13 hours ago, vladd said: Au koliko netacnosti u jednom postu, i to moderatora. Zvuk se ne MERI nego osluskuje, kakvi crni vati, u pitanju je timbre & prat. I pride, koji crni inzenjeri, audio elektronikom se najvise bave random zanimanja... Vreste zvucnika, Tannoy, pa svi ostali, zatim se dele na fensi i obicne, velike i male.... Pojacala se dele na lampionska i pescana, preampovi na pasivne i aktivne.... Sto godina je u ovome i jos veruje internetu a ne ljubiteljima. https://www.youtube.com/watch?v=g5XQ3azRx_w
vladd Napisano Septembar 6, 2018 #22 Napisano Septembar 6, 2018 Prihvatam to, i to je cinjenica. Mada je sustina mog posta sala u kojoj ima i sale. Cinjenica koja je proistekla iz vrlo slozenog elektromehanickog rada, koji je fragmentalno i u delimicnim pojavama relativno jednostavno merljiv, i saznanja koji su sve uticaji i promenljive okolnosti prisutni u tom sistemu, neke izuzetno slozeno merljive, jednostavnije, i moguce je varirati elemente u cilju postizanja zvuka po ukusu, a ukupnu ocenu doneti subjektivno.. Ipak pricamo o rezonantnim frekvencijama rucke, npr, oko 10Hz, , ili 12, razliku konkretnih cifri ne mozemo cuti, ali imamo saznanja, kako to deluje na signal i usaglasenost komponenti, i kakav zvucni efekat proizvodi..i prosto znamo da uporedimo utiske sa izmerenim, i da korigujemo, ili unapred znamo ili predvidimo efekte... Znamo kako zvuci i znamo zasto nesto zvuci kako zvuci, znamo pojave koje se desavaju, one necujne mozemo da merimo... Smanjujemo zonu beskonacnih probanja, ne bi li sve stalo u jedna zivot. P.S. Mada ne volim stav ovog lika koji prica "voleo bi da mu neko objasni", to ne znaci da nema nekoga ko bi mu objasnio, ili da je pojava neobjasnjiva, vec da on ne moze ili ne zeli da mu bude objasnjeno, sto se inace cesto susrece...
