shonne Napisano Septembar 29, 2019 #1871 Napisano Septembar 29, 2019 Zute su najbolje [emoji3] Srecko je reagovao/la na ovo 1
Woland Napisano Septembar 29, 2019 #1872 Napisano Septembar 29, 2019 ^ ma žute su dunje, LED treba da je asketski beo [emoji3] Srecko je reagovao/la na ovo 1
shonne Napisano Septembar 29, 2019 #1873 Napisano Septembar 29, 2019 ^ ma žute su dunje, LED treba da je asketski beo [emoji3]Belo, oko mene sve je belo [emoji23]https://youtu.be/SRGkKTNSM0g
Woland Napisano Septembar 29, 2019 #1874 Napisano Septembar 29, 2019 ^ asketski [mention=103]shonne[/mention] ne Aca Lukas belo [emoji3] vladd, Srecko and shonne je reagovao/la na ovo 2 1
Zen Mod Napisano Septembar 29, 2019 Autor #1875 Napisano Septembar 29, 2019 A clamp meter every Greedy Boy can and need to have just want to give you a tip or two had idea to ease some things , so did some searching for DC A clamp meter , with low enough range for my needs........ and found Uni T UT210e already ordered (around 44E in my neck of wood) , even less abroad! while I was at Vendor site , I ordered also UT890D; that will be third I have - and it is absolute bargain (25E in my neck of wood)!! so , no more connecting mini clips to R in CRC , or inserting 0R1 in rail , if there is no CRC finish biasing of your amp with clamp on rail, close it , move clamp to mains cord and write down what's current draw , check on same place whenever you want if you have doubt , in 2 secs I'm so happy when I get new toytool
neskor Napisano Septembar 29, 2019 #1876 Napisano Septembar 29, 2019 evo ako hoces da ga malo modujes https://github.com/bdlow/UT210E
Zen Mod Napisano Septembar 29, 2019 Autor #1877 Napisano Septembar 29, 2019 tnx no sumnje nema da ce to ipak raditi mladji i vise entuzijasti od mene
Zen Mod Napisano Septembar 30, 2019 Autor #1878 Napisano Septembar 30, 2019 shonne, dejanco32, Vix and 1 član je reagovao/la na ovo 3 1
Srecko Napisano Septembar 30, 2019 #1880 Napisano Septembar 30, 2019 Sisy je pogrešno okrenut[emoji16]!Blago ovom Aleksandru, ima vezu kod Zena pa upao preko reda[emoji16].
Zen Mod Napisano Oktobar 1, 2019 Autor #1883 Napisano Oktobar 1, 2019 On 9/29/2019 at 5:23 PM, Zen Mod said: A clamp meter every Greedy Boy can and need to have......... samo da vas obavestim - stigla mi amper kljestanca , probao DC range 2A , uporedno mereci ampermetrom standardno u red odvozao od 0-2A i perfektno mere vredi svaku paru , pod uslovom da se ne pokvare brzo shonne je reagovao/la na ovo 1
Zen Mod Napisano Oktobar 4, 2019 Autor #1884 Napisano Oktobar 4, 2019 dejanco32, Doktor, Vix and 1 član je reagovao/la na ovo 2 1 1
Doktor Napisano Oktobar 5, 2019 #1885 Napisano Oktobar 5, 2019 20 hours ago, Zen Mod said: Apropo spike od malocas : https://www.vinylengine.com/turntable_forum/viewtopic.php?t=57550 " Thanks for the feedback; Steve Williams of One Thing Audio has advised me to leave the 57s plugged in and switched on for 24 hours before attempting to play music through them seriously - I will take his advice and start serious listening and appreciation on Saturday. " 'naci, ostavi ih pripaljene, 'leba ne jedu. Sutra vece check up.
vladd Napisano Oktobar 6, 2019 #1888 Napisano Oktobar 6, 2019 Posle ugradnje znacajno boljih komponenti(nego pre pola veka), pride lakiranih i lakiranih stampi, pa sve to dva puta i spakovano u vosak, tu ne sme nista da se primetno promeni sledecih godinu dana, a ne nakon sacice sati...a i posle godinu dana moze visok napon da spadne za par volti... Bice da je u pitanju misticni ritualcic da se kao zaseceri slusanje muzike...
Doktor Napisano Oktobar 6, 2019 #1889 Napisano Oktobar 6, 2019 ^ Nikakav "misticni ritualcic" nije u pitanju. Cista fizika i priroda ESL-a ( procitati/ponoviti poglavlje o kondenzatorima ). ESL kada se ukljuci prvi put u struju posle kupovine ili posle godisnjeg odmora kada se ESL-i iskljucuju iz napona, zvuci prvih sati mutavo, stegnuto, bez visokih, mutnih niskih . . . generalno zvuk kao iz starih mono radio aparata. Dodatno, bitno je i stanje same folije na panelima. Ukoliko je nova, zategnuta, bez perforacija, malformacija, to je vreme da prosviraju i zaista nekih par dana, tj. min. nakon 24 h.
vladd Napisano Oktobar 6, 2019 #1890 Napisano Oktobar 6, 2019 Visok napon se staticki rasporedjuje po visokoomskoj povrsini membrane. I to traje u minutima, retko dobaci do sata, u tom slucaju nesto nije u redu ili sa visokim naponom ili sa raspodelom otpornosti. Tj povrsinskim potencijalom. Nakon duze pauze ima nizi remanentni potencijal, na membrani, ali se sve to rekuperira za kratko vreme.
Zen Mod Napisano Oktobar 6, 2019 Autor #1891 Napisano Oktobar 6, 2019 to se svodi na - servisiraj celu napojnu stranu,ukljuci , pusti ,bljak ostavi ukljuceno , vece je svejedno , dodji sutra u radionicu i pusti da cujes kako sviri cinjenica je da PW nije stavio power prekidac na njih , sto se mene tice to treba da bude remanentno ukljuceno - svejedno je napojni trafo peanut size ..... trosi ko LED sijalica Doktor je reagovao/la na ovo 1
vladd Napisano Oktobar 6, 2019 #1892 Napisano Oktobar 6, 2019 Ne treba ometati(preciznije zaustavljati) formiranje potencijala membrane modulacijom ili nekim drugim potencijalom, izvorom, to je cinjenica... A moze da ostane ukljucen i danima, svejedno mu, sila je konstantna, razlike ce biti zavisno od okoline i statickog potencijala u prostoru i koliko brzo VN trafo i kaskada to mogu da nadoknade. Svakako bi i biojonizator imao udela...pa ako je nekome lepsi zvuk nakon bilo cega, neka uziva.. A ako naelektrisan prostor, okolina, imaju toliki uticaj u formiranju zvucne slike, mozda bi trebalo uvesti neki VN razdelnik sa trimerom(nalik na fokus ili G2 napon), pa varirati napon membrane, po ukusu.
