jororaitchev Napisano Jun 19, 2017 Autor #67 Napisano Jun 19, 2017 15 minutes ago, jororaitchev said: 16 minutes ago, jororaitchev said: 16 minutes ago, jororaitchev said: 17 minutes ago, jororaitchev said: 19 minutes ago, jororaitchev said: Without the shells, the basics, and the end caps, everything else has to be restarted.
Trotter Napisano Jun 19, 2017 #68 Napisano Jun 19, 2017 Ovaj pije vise od nas trojice u Peckhamu... Sent from my SM-G361F using Tapatalk
jororaitchev Napisano Jun 19, 2017 Autor #69 Napisano Jun 19, 2017 10 minutes ago, Trotter said: Ovaj pije vise od nas trojice u Peckhamu... Sent from my SM-G361F using Tapatalk I'm sorry, some total trickery with my the server and the internet! My brandy is 50 degrees, but it's not the problem.
Aleks Napisano Jun 19, 2017 #71 Napisano Jun 19, 2017 Finish the speakers until September the 30th and bring 'em over here to diyaudio fest. There'll be some nice brandy - for sure - and fried trout, barbeque, and a lot of good sound
jororaitchev Napisano Jun 19, 2017 Autor #72 Napisano Jun 19, 2017 16 minutes ago, Alex said: Finish the speakers until September the 30th and bring 'em over here to diyaudio fest. There'll be some nice brandy - for sure - and fried trout, barbeque, and a lot of good sound I will certainly do so on this date, but I have not specified which year will be .
jororaitchev Napisano Jul 15, 2017 Autor #73 Napisano Jul 15, 2017 Preprocessing of the internal ribbing; I can now start collecting the cabinet; 2a3 and Aleks je reagovao/la na ovo 2
jororaitchev Napisano Avgust 4, 2017 Autor #74 Napisano Avgust 4, 2017 I have an idea to make a new project to in the base there should be two 10" loudspeakers - just an idea. They look like animals, maybe dinosaurs, but important are 20Hz. Beli_Ninja, 2a3, Dacho and 1 član je reagovao/la na ovo 4
jororaitchev Napisano Avgust 20, 2017 Autor #75 Napisano Avgust 20, 2017 On 4.08.2017 г. at 9:05 PM, jororaitchev said: I have an idea to make a new project to in the base there should be two 10" loudspeakers - just an idea. They look like animals, maybe dinosaurs, but important are 20Hz. And the original model will look like this; 2a3, Beli_Ninja and Dacho je reagovao/la na ovo 3
jororaitchev Napisano Avgust 21, 2017 Autor #76 Napisano Avgust 21, 2017 I continue with the collection of the cabinet; Now I can make the exact measurement of the volume. And that's 31.5l, just as much as I need!Oh, l forget to show you what I did to get that volume!I maked a filter compartment (for the MW and TW), the W section will be in the box; I previously make the last layer-10 mm MDF / to get a sandwich construction / on the front panel and the bottom; Last constructive action ; After 10 hours I will install the last layers of 2 x 4 mm bent MDF; Dual, 2a3, ab and 3 ostalih je reagovao/la na ovo 6
jororaitchev Napisano Avgust 29, 2017 Autor #77 Napisano Avgust 29, 2017 A small structural change for the side panels, last layer is 1 x 4 mm plywood and everything is re ady for the measurements. 2a3, Dacho, Dual and 1 član je reagovao/la na ovo 4
jororaitchev Napisano Avgust 31, 2017 Autor #78 Napisano Avgust 31, 2017 And a risky picture (everything is supported by gravity), how look for compared to the front speakers, are not on one line, but I rely on your imagination. black coffe and 2a3 je reagovao/la na ovo 2
black coffe Napisano Septembar 1, 2017 #79 Napisano Septembar 1, 2017 23 hours ago, jororaitchev said: And a risky picture (everything is supported by gravity), how look for compared to the front speakers, are not on one line, but I rely on your imagination. Nhf , stalak je kvalitetan , al meni estetski nije nešto lijepo .
Dacho Napisano Septembar 1, 2017 #80 Napisano Septembar 1, 2017 Mozda ovako da je deblja noga kao slovenci sto rade... black coffe je reagovao/la na ovo 1
jororaitchev Napisano Septembar 1, 2017 Autor #81 Napisano Septembar 1, 2017 2 hours ago, black coffe said: Nhf , stalak je kvalitetan , al meni estetski nije nešto lijepo . Relax , there is a lot of work still on the stand! Similar was the situation with the bases of the central pillars; vladd je reagovao/la na ovo 1
jororaitchev Napisano Septembar 1, 2017 Autor #82 Napisano Septembar 1, 2017 Quote: Početnik "Mozda ovako da je deblja noga kao slovenci sto rade..." Such a design- never!They look like cut trees in the park. Massive wood for speakers - a very bad idea!
black coffe Napisano Septembar 2, 2017 #83 Napisano Septembar 2, 2017 On 01.09.2017. at 8:53 AM, Dacho said: Mozda ovako da je deblja noga kao slovenci sto rade... Je ! onaj je mal ko roda il čaplja . Ne velim za kvalitetu ?
black coffe Napisano Septembar 2, 2017 #84 Napisano Septembar 2, 2017 On 01.09.2017. at 8:53 AM, Dacho said: Mozda ovako da je deblja noga kao slovenci sto rade... E stari moj ! sad celo "selo" mudrijaša tipa rezonancije sim pa tam ne more imat prigovora :
ZZZ Napisano Septembar 2, 2017 #85 Napisano Septembar 2, 2017 21 hours ago, jororaitchev said: Quote: Početnik "Mozda ovako da je deblja noga kao slovenci sto rade..." Such a design- never!They look like cut trees in the park. Massive wood for speakers - a very bad idea! And how Your design look a like? Is there any sense, relationships, or it is totaly arbitary without any design at all? At least they, slovenans, dont hide natural, true wood. Tremendous amount of handy work does not guaranties the well soud. The goal is to impress the potential buyer at the first second and sell as soon as possible. Your "design" is wrong, your measurements with a water is wrong, that is not the real volume drivers deserves. with these numerous chambers you divide total volumes into milion small chambers. every one have own center of mass. these center of masses are farr from each other and form much smaller volume driver can see than measure simple volume. But You are unable to understand this. That is all try to find on this forum measurements and resuls that one member did with and without chambers. He cut out "bracing" and report.... cheers Dacho je reagovao/la na ovo 1
jororaitchev Napisano Septembar 2, 2017 Autor #86 Napisano Septembar 2, 2017 ^ Very impressive speech! It is filled with deep knowledge - from mathematics to marketing. Thank you very much, I even realized that myself I is made in the wrong way! ab je reagovao/la na ovo 1
Dacho Napisano Septembar 2, 2017 #87 Napisano Septembar 2, 2017 23 hours ago, jororaitchev said: Massive wood for speakers - a very bad idea! Nebih se bas slozio sa ovim. Dokazano je mnogo puta da se do kvalitetnog zvuka ne dolazi samo metodom upotrebe mrtvog materijala za izradu zvucnih kutija. Nekada to zna biti kontraproduktivno pogotovo sa upotrebom medijapana. On zna nekada unistiti svu zivost glazbe.
Dacho Napisano Septembar 2, 2017 #88 Napisano Septembar 2, 2017 2 hours ago, black coffe said: E stari moj ! sad celo "selo" mudrijaša tipa rezonancije sim pa tam ne more imat prigovora : Kud ćeš boljeg stalka od panja poštenog bagrema ili hrasta.. black coffe je reagovao/la na ovo 1
