a tipujem da mogu i grejaci za quartzne peci
srecom tih nema stedljivih , inace bi nam se Mika navukao :hihihihi:
Moze da se ubaci u sasiju od duplog rešoa pa da se na prekidacu menja R load 4 / 8 / 16 oma a moze i kafa da se zakuva :)
a mogu i one tvoje prigusnice
meni jos i ponajbolja varijanta
al' onda moras posebno da imas reso :hihihihi:
mene dopisite +1 na SE varijantu
andy james sa big D koji radi DHT sve, SE, PSE i PP izlaze, pretpojacala je pravio shootout kod njega sa 4P1L PSE, 26 SE i SIT-om koji je pravio pete (i should coco) - kaze da mu taj SIT radi toliko dobro da mu ozbiljno rusi koncept sa cevima, a pravi ih ceo zivot.
:hihihihi:
posle Babelfish SIT-2 , bice uskoro varijanta sa 85% zvuka SIT-2 , ali sa mosfetima u izlazu
10W/8R , kao i original
a sta ce nam 85% zvuka SIT-2, zar nije puanta da napredujemo? daj nesto sa 115%...
115% ili 150% se dobija (izgleda) sto skupljim  trafooom .
sa 1W ide  0.005% i to na 100Hz a opseg sviranja je 1.5Hz do 200kHz (-3dB na  500kHz) lampe mogu da sanjaju
da idu i sviraju dotle i sa toliko malim THD-om...
Pazi šta ČIČA (Nelson) kaže:
his quality seems to be dependent on the specifics of the load-line. The
amplitude distribution of the 2nd and 3rd
harmonic and phase of the 2nd harmonic
distortion vary as you adjust the supply voltage and the bias current. You can
simply adjust for lowest distortion, or you can tweak these parameters to vary
the sonic signature. It seems that Hiraga favored a ratio of 2
nd to 3rd harmonic
with the 2nd harmonic being dominant, but I am not aware that he specified the
phase...
i onda prica o pozeljnom kvalitetu transformatrora
Clearly one potential improvement is to seek out
and pay a lot more for
a better
transformer, one with more and perhaps better magnetic material and a wider
high frequency bandwidth.
http://www.firstwatt.com/pdf/art_sit_nemesis.pdf
ko ima pravi trafo (koji kosta Boga Oca) dobro nastelovan bias i shemu (kao onaj Slon Japanac) moze da dogura i do 0.0005% THD-a  :hyper::smesna:
ovo vec postaje ozbiljno :D da podsetim: cilj je igra, druzenje, a prakticna korist to sto cemo isprobati novu "igracku".. gde ces bolje prilike od ovakve da uzmes pojacalo, odneses kod sebe i slusas dovoljno da bi utvrdio da li ti tako nesto treba, ili makar da  bi zadovoljio radoznalost. Vecina nas ima prilicno dobre ampove, tako da nikom ne gori, tim pre je stvar opustenija i zabavnija..
Japanac koristi R-core transformer  Phoenix RA300  x2 i neke tegle kondezatore blagi uzas u napajanju , a jos ne koristi brze diode nego grec :buehehe:
http://translate.google.com/translate?sl=auto&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&eotf=1&u=http%3A%2F%2Fwww.ne.jp%2Fasahi%2Fevo%2Famp%2F2sk183cspp%2F2sk182cspp.htm
ovo je Sci-Fi THD
Postavljena slika:whistle2:
100kHz 8Vpp
THD(RL=8Ω、Po=10W)
f=100Hz:0.00025%
f=1kHz:0.00045%
f=10kHz:0.0040%
THD(RL=4Ω、Po=20W)
f=100Hz:0.00028%
f=1kHz:0.00070%
f=10kHz:0.0072%
:msn-rofl:
sa 1W ide  0.005% i to na 100Hz a opseg sviranja je 1.5Hz do 200kHz (-3dB na  500kHz) lampe mogu da sanjajuda idu i sviraju dotle i sa toliko malim THD-om...Pazi šta ČIČA (Nelson) kaže:his quality seems to be dependent on the specifics of the load-line. Theamplitude distribution of the 2nd and 3rdharmonic and phase of the 2nd harmonicdistortion vary as you adjust the supply voltage and the bias current. You cansimply adjust for lowest distortion, or you can tweak these parameters to varythe sonic signature. It seems that Hiraga favored a ratio of 2nd to 3rd harmonicwith the 2nd harmonic being dominant, but I am not aware that he specified thephase...i onda prica o pozeljnom kvalitetu transformatroraClearly one potential improvement is to seek outand pay a lot more fora bettertransformer, one with more and perhaps better magnetic material and a widerhigh frequency bandwidth.http://www.firstwatt.com/pdf/art_sit_nemesis.pdfko ima pravi trafo (koji kosta Boga Oca) dobro nastelovan bias i shemu (kao onaj Slon Japanac) moze da dogura i do 0.0005% THD-a  :hyper::smesna:
daj se malo opustiti - brkas mrezni trafo kod japanca i Nemesis trafo , te samo unosis zbrku u pucanstvo
prvi je mrezni kod PP ampa , drugi je izlazni kod SE ampa , koji je Nele uradio kao reminiscenciju Hiraginog starog ampa
da rezimiram - sve sto je 0,5-0,8% THD@1W za SE je bogovski , bez feedbacka
silne nule se dobijaju zna se kako - razlikom izmedju OLG i CLG , u narodu poznatom kao povratna sprega
e pa dobro da znam da mi pravis (kad mi budes pravio)  SIT amp sa povratnom spregom i R-core transformatorom.
da rezimiram - cena je nebitna,  odnosno bitne su samo  silne nule :smesna:
ko kaze. meni gori, ja imam Burning amp
:hihihihi:
 Da amp je dosta bio zatvoren, vreme je za novu verziju :hihihihi:
Imam na pameti neku varjantu mos/bjt Shade. Al to kad prodje grip!
Fet Guru :hihihihi:
Ni Zika Obretkovic mu nije ravan.
Može li za nas neuke kratak prikaz toga gde su greške u izlaganju...? Da nešto i mi naučimo...
Ko je rekao da ima gresaka?
