Mikorist Napisano Januar 18, 2023 #1 Napisano Januar 18, 2023 Maticna ploca GA-H81.AMP-UP (rev. 1.0) Overview | Motherboard - GIGABYTE Global WWW.GIGABYTE.COM Lasting Quality from GIGABYTE.GIGABYTE Ultra Durable™ motherboards bring together a unique blend of features and technologies that offer users the absolute ... Procesor Intel® Core™ i7-4770 Processor (8M Cache, up to 3.90 GHz) - Product Specifications | Intel WWW.INTEL.COM Intel® Core™ i7-4770 Processor (8M Cache, up to 3.90 GHz) quick reference with specifications, features, and technologies. Graficka EX-RX570-O4G|Graphics Cards|ASUS Global WWW.ASUS.COM ASUS Expedition graphics cards are the perfect starting point for a thrilling journey into your favorite game. Engineered for durability and reliability, Expedition cards are tested to their limits, including a 144-hour diskless-system test and extensive compatibility checks to ensure a smooth ride. Memorija Kingston 16 GB 2133 MHz DDR3 HyperX Beast T3 *(radi na max 1600 MHz za ovu maticnu) Kuciste MS ELEMENT M100, USB 3.0, bez napajanja Napajanje Seasonic B12-BC-550, 80PLUS Bronze Bios Settings: XHCI Hand-off: Enabled EHCI Hand-off: Enabled Execute Disable Bit: Enabled XHCI Mode: Auto Legacy USB Support: Enabled SATA Mode: ACHI ( with UEFI Settings ) VT-d feature : Disabled X.M.P. Memory Profile to Profile1 Integrated graphics. Disabled - PCI graphics Enabled Kako se macOS skida i instalira sa Linux-a https://dortania.github.io/OpenCore-Install-Guide/installer-guide/linux-install.html#downloading-macos Kako se macOS skida i instalira sa Windows https://dortania.github.io/OpenCore-Install-Guide/installer-guide/windows-install.html#downloading-macos Opencore boot-loader konfigurisem (apdejtujem) podesavam i proveravam sa OCAT https://github.com/ic005k/OCAuxiliaryTools Svo citanje za Opencore je ovde https://dortania.github.io/OpenCore-Install-Guide/prerequisites.html Neverovatno kako radi ovaj operativni sistem..... EFI sa podesenim OpenCore je u prilogu EFI.zip shonne, dejanco32, LightMatic and 2 ostalih je reagovao/la na ovo 3 1 1
Mikorist Napisano Januar 18, 2023 Autor #2 Napisano Januar 18, 2023 U svakoj sobi imam sad po jedan Hackintosh ukljucujuci kujnu
Mikorist Napisano Januar 18, 2023 Autor #3 Napisano Januar 18, 2023 Zaboravio sam da navedem dva SSD od tera. Nece bez njih da radi Zaboravio sam da napisem sta radi i sta ne radi na ovom build-u. Radi sve sem hibernacija - jos nisam otkrio *(a otkricu) kako iz hibernacije da se Aktivira slika na RX 570. Inace sve ostalo fercera kao fabricki Mac - ukljucujuci quartz extreme i VDA dekoder za Apple TV Zvuk ubija sa ALC889...O DAC da ne pricam.... shonne and LightMatic je reagovao/la na ovo 2
Mikorist Napisano Januar 18, 2023 Autor #4 Napisano Januar 18, 2023 Inace je kod cere jako slicna kombinacija u sobi samo sa jos vise memorije. Ona ima monitor Dell UltraSharp 27 4K U2723QE posto se bavi Blenderom i 3D dizajnom Kod sina je zavrsio mini PC sa GT karticom. A zena ima laptop sa Macos
Mikorist Napisano Januar 18, 2023 Autor #5 Napisano Januar 18, 2023 pre 4 časa, Mikorist reče Radi sve sem hibernacija - jos nisam otkrio *(a otkricu) kako iz hibernacije da se Aktivira slika na RX 570. -v keepsyms=1 debug=0x100 alcid=3 igfxonln=1 darkwake=0 obicno sa darkwake=0 u boot-args je fix -ali nece ovde
Mikorist Napisano Januar 18, 2023 Autor #6 Napisano Januar 18, 2023 Evo ga ovde resenje https://www.tonymacx86.com/threads/black-screen-bigsur-only-get-video-after-sleep-wake.321962/#post-2336792 sudo pmset autopoweroff 0 sudo pmset powernap 0 sudo pmset standby 0 sudo pmset proximitywake 0 sudo pmset tcpkeepalive 0
Koja Napisano Januar 18, 2023 #7 Napisano Januar 18, 2023 Haha odlicno. Ali meni bi bilo logično obrnuto, instalirati win na apple hardver. Best of both worlds Mikorist je reagovao/la na ovo 1
Mikorist Napisano Januar 18, 2023 Autor #8 Napisano Januar 18, 2023 Ama ima sve za macOS . Office full - jedino nema microsoft access. Adobe Photoshop zadnji instalirao ceri , Maya3D, Blender, Adobe Premiere Pro, DaVinci Resolve..... Igrica ima 80% sad. Plus ima Steam. Ja imam cak i DOSBox igram Prince 1
Mikorist Napisano Januar 18, 2023 Autor #9 Napisano Januar 18, 2023 Plus je stabilno kao crna zenlja. Cak i da nestane struja -zadnje sto si radio se pojavi ponovo na Desktopu
Koja Napisano Januar 18, 2023 #10 Napisano Januar 18, 2023 Ma gde ima, to je smešno. Čim je potreban bilo kakav rad sa fajlovima, sve pada u vodu. Na win ima Totalcmd. Na macu nema ništa ni blizu, tražio sam kad sam bio primoran da radim. Plus svi ti unixoliki sistemi imaju užasnu organizaciju fajl sistema.
Koja Napisano Januar 18, 2023 #11 Napisano Januar 18, 2023 Mac je dobar kad si grafički dizajner pa treba da edituješ 3-4 slike i da ništa ne diraš.
Mikorist Napisano Januar 18, 2023 Autor #12 Napisano Januar 18, 2023 pre 39 minuta, Koja reče Na macu nema ništa ni blizu, Ali mene mrzi i da klikcem na to....Brze kroz terminal radim sa fajlovima Ni na Windows-u kad sam bio nisam koristo TC Koja je reagovao/la na ovo 1
Mikorist Napisano Januar 18, 2023 Autor #13 Napisano Januar 18, 2023 pre 22 minuta, Koja reče Mac je dobar kad si grafički dizajner pa treba da edituješ 3-4 slike i da ništa ne diraš. Ma jok. Da vidis klinci kad od malena naviknu na Linux i macOS sta rade u njima. Meni je trebalo 10 godina da se priviknem. Njima ne treba privikavanje. Rodili su se bez Windows Ja instalirao Windows 10 klincu i posle dva dana kaze skidaj ovo sranje Nego uce u skoli iz informatike Windows pa mora da znaju teoretski i to. Jbg access nema(mo) Doktor, LightMatic and vladd je reagovao/la na ovo 2 1
Mikorist Napisano Januar 18, 2023 Autor #14 Napisano Januar 18, 2023 pre 33 minuta, Mikorist reče Ja instalirao Windows 10 klincu i posle dva dana kaze skidaj ovo sranje Inace kuca 100 wpm.....brze od mene. Mislim da je samo kliktao da nikad ne bi na slepo kucao tom brzinom.
Mikorist Napisano Januar 18, 2023 Autor #15 Napisano Januar 18, 2023 Radi sad i hibernacija. Ko na Windows-u. Izmenjen EFI i ubacen u prvi post.
gluv_i_udaren Napisano Januar 18, 2023 #16 Napisano Januar 18, 2023 Jbg, ja sam od Macintosha odust'o od kad nema native widowsa. Oko 90% programa koji mi trebaju rade samo na win. Tih 10% je Office... Poslednja dilema mi je bila MBP 14 sa M1 Pro (pa da molim boga da mogu da namunjim Win VM i sav sw sto koristim) ili Thinkpad Carbon X1 i beše karbon. Nije da ne volim MacOS, sviđa mi se ali mogu ga koristiti samo za zabavu, a posle celodnevnog rada na kompjuteru mi više nije do zabave na kompjuteru... Nesic and Mikorist je reagovao/la na ovo 2
Mikorist Napisano Januar 18, 2023 Autor #17 Napisano Januar 18, 2023 pre 22 minuta, gluv_i_udaren reče Oko 90% programa koji mi trebaju rade samo na win. Kad mora mora
gluv_i_udaren Napisano Januar 18, 2023 #18 Napisano Januar 18, 2023 Hebem ti moranje ceo život Mikorist and LightMatic je reagovao/la na ovo 1 1
Mikorist Napisano Januar 19, 2023 Autor #19 Napisano Januar 19, 2023 pre 12 časa, gluv_i_udaren reče Hebem ti moranje ceo život Ovo su verovatno neki od poslednjih hakintosha. M1 procesori potisnuce intel i amd....A ARM koji ima da se kupi u slobodnoj prodaji previse je slab za macOS. Negde 2028 moracu i ja da begam sa ovoga jer nece imati apdejtove.
Aleks Napisano Januar 19, 2023 #20 Napisano Januar 19, 2023 Kažu da je najbolja kombinacija Mac Pro sa Windows 10 A ti ideš suprotno Sve sam bliži tome da odjašem sa svega toga i samo Ubuntu brale. Evo kolege svi sa posla pevaju na Linuxima, samo ja gedža frontendovac se zbutavam zbog hebenog Adobe-a i Photoshopa.
Mikorist Napisano Januar 19, 2023 Autor #21 Napisano Januar 19, 2023 pre 3 minuta, Aleks reče Kažu da je najbolja kombinacija Mac Pro sa Windows 10 A ti ideš suprotno Ni to nece da moze vise sa ovim novim hardverom. Samo macOs na na Mac masini....
Aleks Napisano Januar 19, 2023 #22 Napisano Januar 19, 2023 Dok ga ne okače Rusi na net LightMatic je reagovao/la na ovo 1
