dunavko
Sve objavljeno od dunavko
  1. dunavko
    ZA OPTO PRIMENU
    MOZE I ZA 199 EURA.VALJDA IMA OVO NEKU PRIMENU U AUDIO...
  2. samo da ne bude druga strofa pesme.
  3. dunavko
    ZA OPTO PRIMENU
    more , jedan ker uvatio kraj kabla i razmoto ga jer se u medjuvremenu pojavila macka u njegovom vidokrugu i on za njom sa sve kabla....
  4. dunavko
    ZA OPTO PRIMENU
    Megger OLS610 Fiber Optic Light Source Top quality piece of industry standard test equipment, the OLS610 Light Source is a small and compact instrument for launching light into an optical fibre cable, particularly for when an optical link is being tested. The OLS610 is a tough, robust instrument, powered either by internal rechargeable cells or from the mains supply. The OLS610 launches light at 1300 nm wavelength, the slide switch on the front of the instrument selects one of three light emission forms, the / off position or the internal battery charge facility. Light output can be either low power continuous, low power pulsed equivalent to a 10 kHz square wave, or high power continuous. Item has come to us from a now closed Marconi laboratory, it has been well looked after and is sold in perfect working and cosmetic condition, comes with original soft storage pouch and original operating instruction book. OTP610 FIBRE OPTIC POWER METER Megger OLS610 Fiber Optic Light Source Used ,working condition, The OLS610 is a tough, robust instrument, powered either by internal rechargeable cells or from the mains supply. The OLS610 launches light at 850,1300 and 1550 nm wavelength, the slide switch on the front of the instrument selects one of three light emission forms, the / off position or the internal battery charge facility. SVE ZAJEDNO,_OBA INSTRUMENTA I SVE STO JE NA FOTO ZA 200 EURA.detalji na pp
  5. imo dva,bacio.sa njima sam radio pcb stampu peglom.al su imali tonera na pausu.zao mi je.
  6. ima neki rus dao recept kako od citosana napraviti propitku al bolje da nadjem nekog iz moskve da kupi i donese.600 rubalja. to je ispod 10 dolara,valjda za 50 ml.ja bi mazo one 12 rft ,idealne za propitku.nisu skupe ako nesto ode u aut.
  7. radisa,upravo si spasio najmanje 100 rakova.Hvala.
  8. bilo bi interesantno da cujemo da li si spremio neke testove za te kutije,neki plan,strategiju gde bi se videli rezultati.imam i ja negde par tih kutija pa da vidim...nego da li ima neki hemicar sa foruma da mi pomogne oko ekstrahovanja hitina iz ljuski rakova-sa sircetnom kiselinom.ima neki rus iz kisinjeva,moldavija,Vorobjev koji vec dugo premazuje zvucnike sa svojim "premazom" u kom je osnova hitin.i onda se objasnjava kako to interaguje sa celulozom,sasvim nova struktura,itd,itd....mogu da postavim linkove i tekst ne tu temu,to su u rusiji apsolvirali i svi se slazu da postoje vrlo pozitivne promene,izmerene,testirane.mozda bi bilo dobro da to bude nova tema da ne bi kvarili ovu.
  9. dunavko
    EL34 ili 6CA7
    po zvucnosti i kvalitetu-cena- el34 - metal baza el34 philips,siemens,philips brown baza.,tesla...interesantno je da se tu relefunken nije proslavio.ako je za PP konfiguraciju pozeljno je da budu "ostarene" bar 72 sata pa uparene.to znaci veliki broj lampi pri testiranju.veci balon veca povrsina hladjenja.ne treba da se o tome razmislja,jer su konstruktori odradili svoje i kada kazu da je 6ca7 rugerizovana.pogledaj ako te bas interesuje kolika je disipacija na anodi za te . svi zaboravljaju zvucnost.ja sam ranije mislio da je to malo preuvelicano ali izvezbano uvo razlikuje philips braon bazu od bilo koje 6ca7,itd...znci neoberger tester rpm370 za ua=250v,ug2=265v,ug1=-12.5v meri ia=100ma=100%.iza 6ca7 i za kinesku el34.to ne znaci da ce lose da radi sa ia=80mA.vazno je da uPP spoju budu uparene sto vise moze.dobro podeseni bias,radna tacka,svi parametri.dobra topografija,izmedju ostalog zbog hladjenja.sam odluci sta ces da akcentujes:zvuk ili vreme trajanja lampi.doduse pare su najvaznije....
  10. ima ruska 6p1p kao el90 ,6aq5 ili 6v6,sa njom rusi prave pojacavace i puni hvale kako to zvuci.probaj nju jer nije skupa.ona je noval podnozje tako da ti je sve pri ruci.ako je nemas dacu ti ja jednu.
  11. slazem se.samo pokusavam da malo pojasnim stvari.taj prodaje h2000 a karakteristike koje daje su za HA31 1544-422.verovatno su h2000 ova izmenjena verzij ha31a o cemu on prodavac pise,drugo vesanje,magnet itd..sve dok se ne probaju u radu .verovatno su i ove druge karakteristike slicne.za mene je i 1dB gore dole razlog da kupim ili ne.cena je zaista pristojna i ja se nosim mislju da...
  12. na kupujemprodajem videoton h2000 model,par 65e.4oma 93db a 8 oma 91dB koje daje prodavac su za model HA31 1544-422.aj sad budi pametan?
  13. videoton ha31 1544 421,jel to taj bas 12''? par za 65 eura? trazio sam podatke za osetljivost i nikako da utvrdim kolika je -od 90 pa do 93dB?jer neko ima tacan podatak?
  14. po dva 2n3055 u izlazu.al, je to radilo,za sve pare.pre 30 godina otprilike,jednom sam pozvao pet,sest drugara audiofila pa pustio neku dobru lp,gramofonsku glavu sam promenio i neku dual stavio, ,valjda,nije bila original.sve je to bilo iza neke zavese samo kutije izvan.au,da ste samo culi komentare jer su trebali da pogode sta to svira.kad su videli sta je svi se razbezali...
  15. ima neki premaz na bazi hitina,rusi ga koriste.kupe rakove,pojedu ih i ekstrakuju hitin.sad dal' mesaju sa cadju,ko zna...
  16. povecana povrsina membrane ce za istu el.pobudu imati manji hod.sta je kompromis?
  17. potreban laserski interferometriski vibrometar za par merenja,pre i posle mazanja...
  18. treba znati,ima na net-u samo treba znati jezike..svakako da je vazna mikro povrsina,ali se procesi usloznjavaju.tu sada ima svasta...
  19. izmedju ostalog kada bi namazao membranu sa necim zrnastim pomesanim sa nekim lakom i pogledao pod mikroskop video bi velike neravnine.nesto ko crna gora kada bi se ispeglala bila bi ko srbija.za ono govance od kanarinca i to bi moglo samo da kanarinac ima tvrdu 'ranu pred uzimanje materijala.
  20. zvuk je promena vazdusnog pritiska.zvucnik to radi pomeranjem membrane koja gura vazduh i dobijes izmedju ostalog i zvuk . za datu povrsinu membrane i hod dobije se jedna vrednost.sta se dogadja kada se na neki nacin poveca povrsina membrane a da precnik membrane zvucnika ostane isti?da li ce biti promena u zvuku za istu pobudu?
  21. a sta ako sa damarom pomesa finu cadj iz cunka smederevca koji je lozen sa sljivom dok se gore na ploci grejao drugi proizvod sljive?
  22. dunavko
    EF86 RIAA
    al' sijaju lampioni, ko svetionik u burnoj noci, putokaz graditelju daju, pravi zvuk ce doci...
  23. guglam za ovaj show u crowne plaza i nigde nista,spisak ucesnika i ostalo...nije mi jasno.
  24. onaj prefiksE V treba da kaze da ta lampa radi vise od 5000 sati minimalno.obzirom da zivotni vek u srbiji realno pada tamo negde u starackom domu ces mozda menjati te tvoje garniture 6n23p-ev i to slusajuci izvodjenje grupe sedmorice mladih.iako neki spravocnici daju i za ovu obicnu 6n23p saratovsku 5000 sati. Некоторые справочники конца 60-х годов утверждают, что долговечность 6Н23П составляет не менее 1000 часов. Видимо, этого оказалось мало для такой хорошей и востребованной лампы, поэтому для придания изделию особых эксплуатационных свойств внутренности лампы усовершенствовали, и появилась модификация 6Н23П-Е повышенной долговечности (5000 часов и более), а потом и 6Н23П-ЕВ – двойной триод повышенной надежности, механической прочности и долговечности.
  • Trenutno na sajtu   2 članova, 1 Skrivenih, 1671 Gosta (Pogledaj celu listu)
    454.9k
    DusanJovanovic
    DusanJovanovic
