955 -
4
Postovi objavljeno od Kuja
Just now, Mikorist said:
I neće da radi bez sudo make install
To sam uradio, kucao sam sve što si mi prethodno napisao.
2 minutes ago, Mikorist said:Probaj da skineš verziju iz apt instaliranu.Verovatno imaš obe a vidi samo staru.
Kako to da uradim, šta da kucam?
Kada ukucam apt list --installed
Dobijam između ostalog:
libio-html-perl/xenial,xenial,now 1.001-1 all [installed,automatic]
libio-socket-inet6-perl/xenial,xenial,now 2.72-2 all [installed,automatic]
libio-socket-ssl-perl/xenial,xenial,now 2.024-1 all [installed]...
Hvala!
Sve odradio i u terminalu dobijam ovo:
snake@snake:~/IO-Socket-SSL-2.083$
Ništa se dalje ne dešava, a u LMS info statusu mi i dalje stoji stara verzija.
Probao sam i restart sistema i ponovio celu proceduru ali ništa.
Evo kako je ceo proces prošao:
snake@snake:~$ wget https://cpan.metacpan.org/authors/id/S/SU/SULLR/IO-Socket-SSL-2.083.tar.gz
--2023-06-09 16:16:38-- https://cpan.metacpan.org/authors/id/S/SU/SULLR/IO-Socket-SSL-2.083.tar.gz
Resolving cpan.metacpan.org (cpan.metacpan.org)... 199.232.18.217, 2a04:4e42:41::729
Connecting to cpan.metacpan.org (cpan.metacpan.org)|199.232.18.217|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 259940 (254K) [application/x-gzip]
Saving to: 'IO-Socket-SSL-2.083.tar.gz.1'IO-Socket-SSL-2.083 100%[===================>] 253.85K --.-KB/s in 0.04s
2023-06-09 16:16:38 (6.55 MB/s) - 'IO-Socket-SSL-2.083.tar.gz.1' saved [259940/259940]
snake@snake:~$ tar -xf IO-Socket-SSL-2.083.tar.gz
snake@snake:~$ cd IO-Socket-SSL-2.083
snake@snake:~/IO-Socket-SSL-2.083$ perl Makefile.PL
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = "en_US:",
LC_ALL = (unset),
LC_PAPER = "sr_RS",
LC_ADDRESS = "sr_RS",
LC_MONETARY = "sr_RS",
LC_NUMERIC = "sr_RS",
LC_TELEPHONE = "sr_RS",
LC_IDENTIFICATION = "sr_RS",
LC_MEASUREMENT = "sr_RS",
LC_CTYPE = "UTF-8",
LC_TIME = "sr_RS",
LC_NAME = "sr_RS",
LANG = "en_US"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_US").
Should I do external tests?
These test will detect if there are network problems and fail soft,
so please disable them only if you definitely don't want to have any
network traffic to external sites. [Y/n] y
Generating a Unix-style Makefile
Writing Makefile for IO::Socket::SSL
Writing MYMETA.yml and MYMETA.json
snake@snake:~/IO-Socket-SSL-2.083$ -
1 minute ago, Mikorist said:
Šta će ti uopšte zadnja verzija ?
Hoću da instaliram update nekih plaginova u LMS, ali ne uspevam.
U logu piše:
[23-06-09 02:55:59.7633] Slim::Utils::PluginDownloader::_downloadError (266) unable to download Qobuz from https://www.herger.net/_data/Qobuz-2.13.0.zip - Connect timed out:
[23-06-09 02:55:59.7637] Slim::Utils::PluginDownloader::_downloadError (266) unable to download MusicArtistInfo from https://www.herger.net/_data/MusicArtistInfo-1.9.0.zip - Connect timed out:
[23-06-09 02:56:14.7034] Slim::Utils::PluginDownloader::_downloadError (266) unable to download MusicArtistInfo from https://www.herger.net/_data/MusicArtistInfo-1.9.0.zip - Connect timed out: Bad file descriptor
[23-06-09 02:56:14.7041] Slim::Utils::PluginDownloader::_downloadError (266) unable to download Qobuz from https://www.herger.net/_data/Qobuz-2.13.0.zip - Connect timed out: Bad file descriptor
Autor plaginova mi na LMS forumu kaže da je verovatno problem u zastareloj IO Socket SSL verziji.
Hvala, ali ja lepo rek'o korak po korak!
Šta tačno da kucam u terminalu?
Jedno pitanje za Linux magove!
Pokušavam da apgredujem IO Socket SSL na noviju verziju, ali dobijam poruku da je već imam (što nije tačno):
snake@snake:~$ sudo apt-get -f install --only-upgrade libio-socket-ssl-perl
[sudo] password for snake:
Reading package lists... Done
Building dependency tree
Reading state information... Done
libio-socket-ssl-perl is already the newest version (2.024-1).
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
snake@snake:~$Na linku https://metacpan.org/dist/IO-Socket-SSL vidim da je aktuelna verzija 2.083
Kako da sistem nateram na apgrejd?
Imajte u vidu da mi je poznavanje Linux-a skoro nikakvo (dobar sam samo u Guglovanju rešenja i copy paste komandi u terminal), tako da se ništa u mom slučaju ne podrazumeva već morate da me vodite korak po korak!Evo i detaljnih informacija o instaliranoj verziji:
snake@snake:~$ apt show libio-socket-ssl-perl
Package: libio-socket-ssl-perl
Version: 2.024-1
Priority: optional
Section: perl
Origin: Ubuntu
Maintainer: Ubuntu Developers <[email protected]>
Original-Maintainer: Debian Perl Group <[email protected]>
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Installed-Size: 478 kB
Depends: libnet-ssleay-perl (>= 1.59), netbase, perl
Recommends: libnet-libidn-perl | libnet-idn-encode-perl | liburi-perl, perl (>= 5.15.6) | libsocket-perl | libsocket6-perl, perl (>= 5.19.8) | libio-socket-ip-perl (>= 0.20) | libio-socket-inet6-perl
Suggests: ca-certificates
Homepage: https://metacpan.org/release/IO-Socket-SSL
Task: ubuntu-desktop, ubuntu-usb, kubuntu-desktop, kubuntu-full, edubuntu-desktop, edubuntu-usb, xubuntu-core, xubuntu-desktop, mythbuntu-frontend, mythbuntu-desktop, mythbuntu-backend-slave, mythbuntu-backend-master, lubuntu-core, ubuntustudio-desktop-core, ubuntustudio-desktop, ubuntustudio-fonts, ubuntu-gnome-desktop, ubuntu-sdk-libs-tools, ubuntu-sdk, ubuntukylin-desktop, ubuntu-mate-core, ubuntu-mate-desktop, ubuntu-mate-cloudtop
Supported: 5y
Download-Size: 159 kB
APT-Manual-Installed: yes
APT-Sources: http://rs.archive.ubuntu.com/ubuntu xenial/main amd64 Packages
Description: Perl module implementing object oriented interface to SSL sockets
This module is a true drop-in replacement for IO::Socket::INET that
uses SSL to encrypt data before it is transferred to a remote server
or client. IO::Socket::SSL supports all the extra features that one
needs to write a full-featured SSL client or server application:
multiple SSL contexts, cipher selection, certificate verification, and
SSL version selection. As an extra bonus, it works perfectly with
mod_perl.
IO::Socket::SSL uses IPv6 if libio-socket-ip-perl (>= 0.20) or
libio-socket-inet6-perl is installed. -
On 5/31/2023 at 6:40 PM, Penzioner said:
Zelim usb port za usb stick sa jedne strane, a sa druge analogni izlaz ili digitalni, zelim da cita standardne formate i da tu kutijicu spojim sa pojacalom.
On 5/31/2023 at 9:39 PM, zerowaf said:To znači da bi taj gadget u sebi morao imati USB utor, iza njega nekakav stroj koji će raditi kao player i istovremeno napraviti D/A konverziju, pa sve to zajedno izbaciti na RCA izlaze.
Nisam čuo da postoji takav gadget.Postoji.
Ima DAC-ova koji primaju USB stick-ove, kao na primer ovaj moj:
Dugmići za izbor digitalnih ulaza po umetanju USB stick-a postaju komande za plejbek (klik za veću sliku):
- gluv_i_udaren, LightMatic and zerowaf je reagovao/la na ovo
- 2
- 1
Ako iz nekog razloga ne bude radilo sve kako treba, sa obzirom da je u pitanju Arm procesor, ima na SnakeOil sajtu/forumu verzija SO baš za rPi.
- Green and LightMatic je reagovao/la na ovo
- 2
Posle mnogo godina provedenih sa raznim VdH, Kimber, Siltech i drugim kablovima, ja sam se skrasio sa Mogami 2497.
Najviše mi se sviđa od svega što je kod mene sviralo. Ostaje do kraja.
Zanimljiv je unutrašnji vod koji je cevast i kabl ima nisku kapacitativnost (67 pF/m).
Impedansa mu je 75 oma, tako da može da se koristi i za digitalnu vezu.
MOGAMI 2497 Hi-Fi Audio Cable - High Definition - by the meter
WWW.DESIGNACABLE.COM
The Mogami 2497 is a Hi-Fi Interconnection Audio Cable constructed with a patented 'Double Cylindrical' structure. Like the smaller 2803, the 2497 is a high resolution cable with rich detail for the most demanding hi-fi applications. The 2497 has a larger cable structure that makes it easier to use than 2803 and so is preferred in some...Mogami 2497 HiFi cable, Ø 8,0mm
WWW.CMA.AUDIO
Professionall HiFi cable Mogami, bulk ware Serie: HiFi-Reference Cable: Mogami 2497, black Bulk ware "Mogami by Lake…Technical Details:
The NIII-2497 is very flexible, with a diameter of 8,0 mm. It features a patented dual cylindrical structure.
The dual-coax design is made of highly conductive Neglex III PCOCC copper.
This achieves an extremely low capacitance of only 67 pF/m, these values guarantee an absolutely clear and undistorted signal transmission that is second to none.- LightMatic and zerowaf je reagovao/la na ovo
- 1
- 1
2 hours ago, Zen Mod said:
za 100-150E racunara ko boMbone na KP i kojekude
NUC samo mali, nista drugo korisno
Što se izbora računara tiče, od raznih faktora vezanih za hardversku implementaciju USB-a može zavisiti i kvalitet zvuka.
Za 18 godina koliko slušam muziku sa kompjutera, probao sam dosta toga - što laptopova (Toshiba, IBM, HP, Dell) što desktopova uključući i mini client-e.
Od svega probanog, jedino što mi je sviralo stvarno dobro su Mac Mini i NUC, koji su tačno razlozi ne znam.
Naravno, siguran sam da to nije jedini izbor i da ima još računara koji će odlično svirati.
Poenta je da računar može da izgleda kao bombona i da ima zvučno ime, a da iz nekog razloga svira loše.
- LightMatic and Srecko je reagovao/la na ovo
- 1
- 1
22 minutes ago, Lemić said:
Vrlo prosto sam pitao kako se ponaša sklop memorije i PCija sa navedenim varijacijama. Jel problem da kažeš, ti ili neko, ako znate, umesto što popujute?
Evo ja prvi nisam znao tačan odgovor na to pitanje, ali mi nije bilo teško da pitam Google.
Jedan od rezultata pretrage:
---=== Timings at Standard Speeds ===---
AA-RCD-RP-RAS (cycles) as DDR4-2666 19-19-19-43 AA-RCD-RP-RAS (cycles) as DDR4-2400 17-17-17-39 AA-RCD-RP-RAS (cycles) as DDR4-2133 15-15-15-35 AA-RCD-RP-RAS (cycles) as DDR4-1866 13-13-13-30 AA-RCD-RP-RAS (cycles) as DDR4-1600 11-11-11-26
Ako sam dobro razumeo ovo gore, spuštanje brzine memorije poboljšava latenciju.
Znači, umesto da se nerviramo i ljutimo na Miku, lepo u Google ukucamo nešto tipa: "does latency change if I use faster RAM in a slower motherboard".
Ma sve super, nije sporno, neka se time bavi onaj ko na taj način sluša muziku.
Ovo nema mnogo veze sa slušanjem muzike onako kako mi to radimo.
Ima veze kada u DAW-u (Digital Audio Workstation, znači u pitanju je audio produkcija a ne reprodukcija) imaš aktivnih više desetina kanala sa gomilama učitanih semplova.
Why do sample libraries need so much memory? And how do you know what sort of RAM to buy? Read on for everything you always wanted to know about RAM but were afraid to ask. . .
RAM is one of the biggest bottlenecks when it comes to smooth playback of digital audio, especially when large sample libraries are involved. We’ve all been there: splurging on some juicy Black Friday deal only to find that the monster 50 GB library we’ve just installed now causes our whole template to grind to a halt. At some point, an upgrade is inevitable.
Ja to nisam pominjao.
U mom slučaju, igra sa RAM-om nije imala veze sa kvalitetom zvuka, već sam hteo da klincu pojačam memoriju u laptopu, pa sam gledao da mu se gađaju moduli po pitanju specifikacija.
Izvršio sam rokadu RAM-a između NUC-a i laptopa i to je bilo to.
Kao što već rekoh, imam pametnija posla od testiranja maksimalnih dometa kompjutera.
Recimo da ga koristim za ono za što je namenjen - slušanje muzike.
- Lemić and LightMatic je reagovao/la na ovo
- 2
30 minutes ago, VukJov said:
То ти је минут посла, крајње едукативно јер видиш који су лимити рачунара односно оперативног система..
Има и неких који су се навадили да искључиво користе DSD, без обзира да ли је материјал оригиналан или препакован.. теоретски то је много природнији начин рада, продукти конверзије много су даље у односу на чујни спектар па је и филтрација много мање насилна..
To bi jedino imalo smisla kada bih imao native/full DSD DAC.
Ovako, poptpuno je besmisleno da u letu PCM konvertujem u DSD, da bi moj DAC (koristi PCM1704 čipove, ali može da primi DSD na ulazu) taj DSD ponovo konvertovao u PCM.
Nemam pametnija posla!
- 1
- 1
18 minutes ago, Lemić said:
Očigledno je prevladavajuće tupljenje i bez koga se na žalost ne može, čak i kad se radi o vrlo prostim i egzaktnim stvarima, takođe i nadgornjavanje bez pokrića i naravno, neizbežno soljenje. Meni je ovo postalo i previše smorno i velika danguba, uz dužno poštovanje svima, bolje da slušam mini tranzistor.
Ja sam zbog neke kombinatorike nevezane za audio, vrteo nekoliko RAM modula između NUC-a i laptopa mog klinca.
U pitanju su bili moduli različitih "megahercaža" i latencija.
Nikakvu razliku u zvuku na NUC-u nisam čuo.
Na kraju je, čisto zbog uparivanja modula istih latencija u laptopu, u NUC-u završio brži RAM sa većom latencijom, umesto sporijeg sa nižom koji je bio originalno instaliran.
Kao što rekoh, nije bilo nikakve razlike u zvuku.
Zato Lemiću, kupi slobodno jeftiniji RAM i ostatak potroši na ćevape!
Super!
Ne znam ni koji je problem!
Ja ga nemam.
18 minutes ago, Mikorist said:
Ama instalacioni fajl Snake Oil sa njihovog sajta ne namešta kod mene smb i Samba da radi. Tačka
Ama ja više puta ovde napisao da ti i ja ne koristimo istu verziju/instalaciju SnakeOila-a.
Tačka.
Dajte ljudi upišite neki osnovni kurs linuxa...Ili me zaobiđite molim Vas....Ovaj priča da nema SSH a sve instalirano kroz SSH - drugi pričao o brzini a pola protokola nema u instalacion fajlu SO...Samo se sranotite bzvz...I ja ne pričam o fotografiji nisam fotograf.
Čekaj malo, ti mene ubeđuješ da mi nešto ne radi, i ako sve radi bez problema.
Smb file sharing radi u svim pravcima - i NUC vidi diskove u mreži svih komjutera u kući, i svi uređaji u kući vide disk na NUC-u,
...i muziku puštam u svim pravcima - NUC kao deo LMS ekosistema kontroliše druge uređaje i drugi uređaji kontrolišu njega,
...i brzina protoka je dobra...
..i meni ništa više od toga ne treba!
Ne treba mi kurs Linux-a, kada mi sve radi bez problema i tačno onoliko koliko mi treba za šta mi treba.
12 minutes ago, Mikorist said:Ili me zaobiđite molim Vas....
Pa ne zaobilaziš ti nas!
Uzeo si SnakeOil i NUC na zub ni krive ni dužne!
Ja sve vreme lepo govorim nek cveta hiljadu cvetova!
Ti hoćeš da imaš supergiga mašinu za Viber, filmove i Steam igre, odlično!
Brža je i jača u svakom pogledu od NUC-a, odlično!
Napravio si sistem baš kakav tebi odgovara, odlično!
Nama takav kompjuter i sistem ne trebaju, isto tako odlično!
Pusti mene i Srećka da na miru uživamo na način koji nas zadovoljava i čini srećnim, i hajde da idemo dalje!
Na kraju svega nije bitno čiji je Kernel veći , podelili smo različita iskustva i nadamo se da će nešto od toga biti i od koristi zainteresovanima za ovu temu.
- 1
Trenutno na sajtu 5 članova, 3 Skrivenih, 27 Gosta (Pogledaj celu listu)
Ukupan broj tema435.1k
Jedno pitanje za Linux magove! :)
in IT
