NIXIE
Sve objavljeno od NIXIE
  1. Bila je jednostana štampa u originalu i kratkospojnici. JLC je sa gornje strane uradio umesto toga vodove i stavio vie gde su bile lemne tačke.
  2. Jumperi su već urađeni u JLCPCB jer je dvostruka štampa, znači ništa ne treba lemiti.
  3. Imam i nove i polovne. Uparene naravno. Zovi me.
  4. Ni ja ne volim daske, lepše mi nekako u kutiji.
  5. Kako ide kilavo ova nabavka delova, odvadiću verovatno Pavouk AD1865 i napraviti MIro AD1865. Treba mi još jedan trafo 2x12V i nešto sitnih delova, a imam dovoljno onih PRC regulatora LT1963/LT3015. Upravo sam u procesu nabavke odgovarajuće plastične kutije.
  6. Nam je dobar svaki koji stigne pre nove godine.
  7. Ako ti ne treba K samo mi javi.
  8. Taj ti valja.
  9. Jesi li ih proverio? Ono da se meri 1k5 između ne znam koje dve nožice beše.
  10. Zamolio bih nekog stručnijeg za prevod, kako to radi i šta radi?
  11. Zanimljiva šema, poručio dve PCB možda probam nekad. NE5532 Class AA OP Amp Preamplifier Bare PCB Headphone Amplifier Circuit Board WWW.EBAY.COM Note: item is Bare PCB , not contain other parts . The circuit board is used between the CD player and the amplifier stage, for headphone amplifier also has a very good sound effect. After the circuit board connected to the passive tone attenuation line has the ideal matching effect, performance is better than the ordinary amplification circuit. Class AA OP Amp Preamp Headphone Amplifier Board Bare PCB for OPA2134 NE5532 WWW.EBAY.COM 1x Class AA OP Amp Preamp / Headphone Amplifier Bare PCB. Note: This item is a Bare PCB, not contain other parts. If you need assembled board. AA class amplifier wide range, High Definition force, rich in detail, driving strong, sound balance. Evo šta kažu: Panasonic AA class line is a voltage controlled amplifier and current drive amplifier constitute a bridge (see below), the voltage controlled amplifier in the equivalent to no-load status (ie the output current is zero), even if connected to a heavy load,even if it is not the same as the voltage and current waveforms of complex dynamic impedance, the voltage controlled amplifier can still work in Class A state, because of itsexcellent performance and near-perfect sound performance and loved by the people.
  12. Taj čiča me mnogo nervira al moram da trpim jer nema izbora drugog. Platili smo, pošalji nam odmah.
  13. Naši nisu ni krenuli.
  14. Imao sam sličan kablić, 2mm spoljašnji presek, nema čelika sve je posrebreni bakar i teflonska izolacija. Nije se pokazao ni za SPDIF ni za interkonekt, davno sam to probao. Nemam podatke za njega, ali je verovatno 75oma karakteristične impedanse. Isto od nekog mernog uređaja.
  15. Probaj ga, jedino tako ćeš znati da li valja.
  16. Ma da, život ide dalje. I onako se audijom zanimaju sad uglavnom samo starci. Omladina je u fast lane, želim im sve najbolje.
  17. Taman dok napravim još dva daka, biće i ovo.
  18. Kad ćeš da uradiš za PCM63?
  19. Nakon tolikih decenija, ima li vajde od starih master traka, to je pitanje? U principu te istorijske vrednosti su baš i sačuvane zahvaljujući digitalnoj tehnologiji za buduće generacije. Mada malo njih će to stvarno zanimati, mislim na te buduće generacije. Ipak je to neka naša mladost, a ne njihova.
  20. To je krenulo jako skromno, da se napravi nešto malo i jednostavno. Pošto je ispalo malo bolje od očekivanja, apetiti samo rastu.
  21. Vidi jel 50oma ili 75oma kabl. Piše verovatno neka oznaka. J asam takav sličan koristio za SPDIF i radi baš dobro, centralni provodnik je čelični pa presvučen bakrom i srebrom. Nije za interkonekte po meni, samo za digitaliju. Ili probaj ako je džabe.
  22. Sve stavi isto na 1963 i 3015, sve otpornike i blok kondenzatore. Jedne vrednosti su za +-12V, druge za +-5V. Ali na plus i minus regulatorima može biti sve isto, ne mora različito. Probao već na onim Kineskim.
  23. Već samo tamo razjasnili sa Mirom.
  24. Za obe grane možeš imati iste delove, trimere, otpornike i male kondenzatore 100nF za podešavanje napona kao za pozitivnu granu sa 1963.
  • Trenutno na sajtu   3 članova, 1 Skrivenih, 184 Gosta (Pogledaj celu listu)
    453.7k
