John Coltrane
Sve objavljeno od John Coltrane
  1. mamura OPT čučnuli na generator bruma samo tako, zvuk odličan ali mrzelo me da pravim petljancije da može da se prevezuje sekundar na 8oma, urađen je samo na 4oma, pa je malo slabiji izlaz na ovin sansui kutijama
  2. Kod trećeg odozdole na tabeli je greška ne može da bude D toliko veće od 1/2 C ili je neki specijal. Nego dal ima kod nas negde da se kupe novi limovi?
  3. Creative Sound Blaster Audigy2 SB 0240 za udaju. Odlična kartica lep zvuk, ne znam kakva je sa drajverima za win7 na xp provereno radi a ja sam je slušao na linuxu, radi bez problema. Cena 10e, za te pare nema bolje The Sound Blaster Audigy 2 (SB0240) (September 2002) featured an updated EMU10K2 processor called CA0102 to gain access to CA0151 which is a separate chip. Collectively CA0102 and CA0151 was sometimes referred to as EMU10K2.5 (The CA0102 chip alone is just a version of Emu10k2). To address the biggest shortcoming of the original Audigy, a revised DMA engine allowed end-to-end high-resolution (24-bit) audio playback: 96 kHz 6.1 channel recording, and 192 kHz stereo. However, the high-resolution audio was achieved by bypassing the DSP, being decoded directly by CA0151 chip also known as "p16v" to take advantage of which Creative substituted CA0102 for the old CA0100 used in Audigy 1. Using the DSP with high-resolution audiostreams resulted in the Audigy's characteristic downsampling (to the DSP's native-rate of 48 kHz), for mixing with other audio sources. The Audigy 2 supported up to 6.1 speakers and had improved signal-to-noise ratio (SNR) over the Audigy (106 vs. 100 decibels (A)). Audio output was supplied by the AC'97 codec on the front outputs and I²S on the rear. It also featured built-in Dolby Digital 5.1 EX decoding for improved DVD play-back. An IEEE-1394 (FireWire) connector was present in all modifications except Value. Audigy 2's 3D audio capabilities received a boost when compared to its predecessors. Creative created the EAX 4.0 ADVANCED HD standard to coincide with Audigy 2's release. The chip again can process up to 64 DirectSound3D audio channels in hardware. It also has native support for the free and open source OpenAL audio API.
  4. Ja sam oma provalio kolki su EI95?
  5. Pa to je divno Mogli bi i do mene, ako budete u mogućnosti...
  6. Sax, de ovo izvuče iz mog posta, de nađe Boga kod komunjare Boga ti, ja rekoh samo da ću možda da probam, to je pola sata posla, pre neki dan sam video taj blog, znači čova poznat zajebant. Što se mene tiče najbolja na ulazu ECC85 pre sam uvek pravio sa njom, ali je sad nemam a nemam ni neko teorisko znanje da se mačujem meni je bitno da svira i da ne divlja.
  7. Šta će da se pravi? Koja shema? Gledao sam baš sad RH šeme na Kitićevom blogu sviđa mi se koncept, ja ću možda moj GB84 da prekrstim u RH84 ako nagazim na neku ECC81. Kaže da se dobija manje izobličenje itd sa tim njegovim konceptom ovde su verovatno ljudi već upoznati sa tim, da ne izlupetam nešto po običaju.
  8. lepo lepo ne smeš sad da se obrukaš sa pojačatorima moraju da budu ful fulova što bi rekli klinci. Nadam se da će da se ugodi nekad da i ja odem do tog tvog majstora da ukradem neki fazon. Danas bi trebalo da završim i drugi tafojčić, stalno me prekidaju i onda kad nastavim žica neće kako ja hoću pa batalim
  9. Ma što bi rekli pravi vintage zvuk, istina da nema toliko basa u odnosu koliki je zvučnik ali uravnoteženo svira i taman prati 20cm srednjak i ove silne vristavce.
  10. Travojčić namotan ovako ko na slici, svira lepo malo je slabiji u odzivu u visokim od jednog a u basu od drugog trafoa koje već imam tako da sam zadovoljan, nisam lakirao to mi krivo sad, cenim da bi još bolje radio ali nisam smeo. Taman kad legnu dva ista na generator bruma biće i zvučna slika bolja.
  11. Za hantor je tražio čini mi se 250e mislim da ga nije prodao to je malo mnogo ne znam koliko to uopšte vedi, meni izgleda drek.
  12. Ne, ovo je od danas, tj sad već juče, četvrtak i petak su regularis dani. Ekipa sa KP je hordašila 15-og a nije bilo ništa lepo za nas, ja kupio samo neke nos roe elektrolite. Dovuko je čovek i hantor ls 1500 veličine su ko JBL Ti
  13. Druže grofe imaš poziv na slušanje. Zadovoljan sam naravno, nije ovo neki hajend, ali je dobro, ne umem rečima da opisujem zvuk ali ajd da kažem da svira uravnoteženo po spektru i ima taj surovi monitorski šmek kad je snimak dobar dobro se čuje kad je dreš tako se čuje, detalja kolko oćeš i što je najvažnije može tiho da se sluša bez da nešto posebno fali...
  14. 16 cola basić, mini monitor što bi rekli. Neće diramo kutiju za sad, jeste kutija plitka ali ne sumnjam u sansuieve inženjere, ko zna zašto je tako. Možda padne neki facelift u stilu kenrick sound-a. Zanima me samo za vešanja, kako da se osveže na basu, u pitanju je papirno impregnirano m harmonika vešanje, nije da zvučnik ne radi kako treba nego cenim da se najverovatnije malo stvrdnulo, mislim da su kutije oko četres banki stare pa zbog toga.
  15. Znači dupli C iliti 00 me gusta!! A i baš sam razmišljao kako da napravim držače za moje mamura, ako ikad budu prosvirali ovo je odlično rešenje i relativno lako za sklepati.
  16. Sansui SP-7500X natrčali morao sam da ih uzmem Legli na generator bruma ko alkosu kilara od sabajle Drajveri su mint ali će spolja morati refresh, jel imao nekad neko vaki kawasaki, kolko vrede, neznam šta da kažem skvo, šta da lažem kolko sam dobar, moram da kažem da su za prodaju, saraniće me u njima . I treba me zadržati da ne utučem dammara u njih papiiiiirrrr je to .
  17. Ako čika Sax kaze da su drek, ondak Problem kod malečkih trafoa su gubici, da bi se dobio odziv u niskim treba da se navrlji puno navojaka, što više navojaka veći gubici ići na deset kvadrata jezgro da bi moglo da stane dovljno navojaka deblje zice to je već preterivanje za 1.5W izlazne snage, opet i pitanje gubitaka u gvojzu. Posle svih čitanija i pisanija mislim da treba račun praviti sa ciljem da se umanje gubici, šta će mi trafo kojme je -3dB na 13Hz ako pojede 20% od wat wat ipo. Sax: lepi trafojčići samo ih uhvatiš za žičke, buć u crnu farbu i MaMuRa samo taki od čega su limovi, mislim jel su reciklirani ili ima odnekud novi da se nabave.
  18. Nisam rekao da cena nije ok znam koliki je posao da se urade, već da mi se ne daju pare za trafoe. A za bahati čok imam lepe ei limčiće.
  19. tatatita titati titatati / tititi ti ta
  20. Ma dočiče na red i nene druge lampike a možda i baš 6V6, al ček onda treba i pobuda u oktal, 6sn7 ili šta već ide za 6V6 pa posle slabo grejanje treba drugi trafko Zvao sam ja čoveka Peca PiKaudio i na pitanje da li mota na donešenim telima rekao je da ne i da je to cirkus da se rasturi i da posle to nije to?? Rekao sam ok hvala, Mož se desi da se nismo razumeli a i ne daje mi se 35+35e - jeftinija varijanta za njegove trafoe.
  21. Ih da je vikler motao bi još kako! Čovek je radioamater ali nije od naših nego tititi-tata-ti i bavi se opravkom rf uređaja, dao mi motalicu da se (m)učim, jedino ako ga namolim da mi napravi matematiku.
  22. Joooo što nemamo ovaku makinu
  23. Nisu subjektivni slušni testovi ja teram drugara koji se bavi audio produkcijom da sluša on mi služi kao osciloskop Pojačalo naravski nema NFB i stvarno treba u praksi isprobati tj motati trafoa da bi se došlo do nekakvih valjanih zaključaka a treba i neka merna oprema a ne moj osciloskop kosijaner.
