Mikorist
Sve objavljeno od Mikorist
  1. Vi mislite da se tu ne koristi Melodin https://amphion.fi/userstories/paul-wolff-console-and-amphion-studio-monitors-surround-sound-setup-at-schweiger-studios-berlin/ Gregor Schweiger had just enrolled at a university in “some kind of engineering” – just to please his parents – when he also started touring as a guitarist with a hardcore band. A few years on, he realized that being behind the console in a studio made him happier than performing. Things became more serious when he commenced a sound-engineering major at the college and captured an internship with the Berlin Philharmonic. In early 2017, Gregor made his dreams come true by opening Schweiger Studios. He built it almost from scratch and had the chance to design it exactly the way he wanted – a recording and mixing facility with a 55 sq. m. live room, two isolation booths and a 28 sq. m. control room. What really gives it punch is the Steinway D grand piano and the first-of-its-kind fully analog, surround sound Fix Audio Designs console – designed by Paul Wolff. The console is based on 500-series modules, offering two 500 series slots per channel. Currently, Gregor takes advantage of a mix of modules by CAPI, Electrodyne/Pete’s Place Audio, Great River, Tonelux, IGS Audio, WesAudio, Lipinski and Retro Instruments. The side-rack carries all his preamps by Pueblo Audio, BAE, Electrodyne, Gyraf, Tonelux, CAPI, Chandler, with the effects by Bricasti and Eventide. His mastering chain consists of Gyraf EQ & Compressor, and a Foote Control Mastering Compressor. The digital control of his Nuendo 7 and the variety of plugins like Brainworx, Slate, Flux, McDSP, Universal Audio, Melodyne is dedicated to a Slate Digital Raven MTi2 touch controller. The AD/DA is handled by two Merging Technologies Horus Interfaces.
  2. Mikorist
    Boenicke W5 SE
    Aha . Ko onaj sto spava na 20cm od sudopere - klozet solja mu pored frizidera - ali ima JBL
  3. Kvalitet cincha - terminala ne vidi se bas odmah. Moze da se desi da otpadne pozlata posle 6 meseci. Zavisi i od toga koliko se greje pojacalo. Koliko para toliko dugo traje pozlata. Loshi veoma brzo promene boju. Imam Music boy cinceve-kablove - posle 20 godina nije otpala pozlata na njima. Niti su se razglavili. A imam AudioQuest kome je otpao srednji kontakt muski
  4. Problem je što je 90% moderne džez muzike prošlo kroz Melodin. Gotovo sve pevaljka zvuče nerealno. Pogotovu one koje se najviše vrte na hifi sajmovima i salonima hajend opreme. Na čemu god da pustiš Dijanu Kral, Elijanu Elijas i Particiju Barber - zvuče ispeglano jer jesu ispeglane kroz Melodin. Zato vas i iritira - evo i razlog zašto. Kad pustiš Nat King Cole, Ella Fitzgerald , Bili Holidej, Ninu Simon - čuješ da nema ič od toga
  5. A da sredimo zvuk gitare ?
  6. Recimo sa Melodinom mogu da ispeglam bilo sta da zvuci kako god hoces
  7. Pa nisam ja prvi poceo. Da snimis zvucno miniranje mosta je jako slicno snimanju poletanja rakete. Zato se u filmovima koriste specijalni efekti. A i u novim izdanjima muzika raznih vrsta takodje. Slusao sam sinteticki orkestar - jedva da mozes da prepopznas razliku.
  8. Nekome ne trebaa izvorna narodna kao zvucni zapis. Nekome tehno ne treba uopste. Trecima klasika ne vredi memorisanja. Cetvrti ne podnose hevi metal. Peti su operisani od panka. Sestima je turbofolk ekstremni dogadjaj. itd...
  9. Samo ti donesi što vernije snimke na USB - pa ćemo da meditiramo uz nargilu koliko je energije otišlo u toplotu
  10. Ja imam prvu opciju sad. Negde na 90% - imam još uvek potenciometar u Iron. Sa Iron Pumpkin SE 92% Kad narihtam DAC biću na 95% Signal Energy Preservation. Ovo bolje svira od Surround sistema i Loudnesa - a nema ič tonskih kontrola ili EQ. A imao i slušao pre aktivne zvučnike , ekvilajzere, miksete.... Ništa ne svira ovako
  11. Nemoguće je preneti recimo zvuk bustera - energiju koju stvara raketa koja poleće. Imas utisak da ces da umres od broja decibela (i jeste na ivici bezbednog). Nijedan uređaj to ne može da prenese zbog klipovanja. Niti jer mogućno snimiti, niti je mogućno reprodukovati ovakav događaj u originalu. . .
  12. ja bi to na istom mestu drugačije čuo - jer imam drugačije dimenzije glave - dimenzije ušiju - svako će drugačije da čuje živu svirku. Jer je zvuk lične prirode. Duševne. Ako hoćemo da idemo dalje - samo je Bog zvuk kakav jeste. Svi ostali zvukovi nisu.
  13. Šta je zvuk onakav kakav jeste? Nemoguće je snimiti zvuk onakvim kakav jeste. Sem da imaš snimač koji bi preko elektroda u mozgu reprodukovao snimak.
  14. Očuvanje energije signala (Signal Energy Preservation) Očuvanje tranzijentne prirode signala bez eksplicitne detekcije tranzijenata. Ovo je nemoguće postići 100% pošto su parametri nepredvidivi. Sve što je na liniji signala je promenljiva - koja remeti originalnu energiju signala. Recimo imaš DAC - i na izlazu posle čipa - imaš - I/V stage - koji realno remeti energiju signala. Nešto dodaje svoje zvuku ma koliko bio neutralan I/V stage. Ezoterični DAC uređaji nemaju uopšte I/V stage. Ili imaš high speed zero feedback super sounding buffer . Ili ulazni transformator + neki bafer . Ili samo transformator. Recimo imaš preamp - sam potenciometar na njemu za pojačavanje - remeti originalnu energiju signala. Svaki kondezator na putu signala u preampu remeti originalnu energiju signala. Najbolje je da preamp nema nikakav potenciometar i kondezator na putu signala. Zen je rešio ovaj problem - ali je mnogo komplikovano da se izvede . Isto to važi i za pojačalo. Za skretnicu koja je na putu signala. A onda je i sama kutija (BOX) zvučnika - prepreka samom signalu koji zvučnik emituje. Pa onda vazduh u sobi. I na kraju mozak između ušiju.
  15. Mikorist
    Boenicke W5 SE
    Brate koliko truda ljudi ulazu da iz prcvoljaka drajvera izvuku cedjeni bass. Te smanjuju fabrike efikasnost da dobiju preko snage loudnes -te povecavaju X-max na 10 mm, stavlaju magnete iste velicine kao povrsine membrane. Bassevi sa strane - na podu - u kutiji a spolja pasivne membrane... Te EQ raznih vrsta . Stalci na stereoidima. Mislim da treba i iz velikih membrana da se cedi bass. Isto toliko paznje da se posvecuje na skretnicama i kabinetima. I da mora da bude veci izbor velikih membrana - pogotovo FR
  16. Mikorist
    Boenicke W5 SE
    Mislim da svaki zvucnik treba da ima siljke - ili stalak - dodatne tegove *- bez obzira na velicinu i vrstu kabineta. I da imam kabinet od 2 metra stavio bih siljke. I na JBL onaj sifonjer
  17. Mikorist
    Boenicke W5 SE
    Mogu raznorazni trikovi da se koriste. Sve je dozvoljeno. Od mazanja bitumenom iznutra - do lepljenja raznoraznih materijala iznutra da se izbegnu refleksije. Fakat je da svi elementi zvucnika podlezu fizici - fizickim zakonima. Ne moze nista nadprirodno da svira - ali da mogu da se postignu poboljsanja - mogu. 15 inca svira kao 15 - 12 kao 12 - 10 kao 10. Ako 10 svira bass kao 15 nesto opasno ne stima u tom kabinetu gde je 15. Niti Tannoy 15 moze da svira srednje kao 10 i 12. Zbog efikasnosti u odredjenom frekfentnom opsegu. Brzine kretanja membrane u srednjetonskom podrucju. Siljci i stalci poboljsavaju - manji Doplerov efekat - usled većeg kretanja membrane- strahovito uticu na pravac oscilacija cestica. Dodatna tezina -tegovi na kutijama - povecavaju inercionu masu u sistemu.
  18. frontovi su iz uradi sam, gazišta za stepenice? Ovo slicno ko Fane. Samo trebaju veca gazista
  19. Mikorist
    Koji Linux
    Za majmuna find . -name "*.cue" -exec sh -c 'exec shnsplit -f "$1" -o flac -t "%n_%p-%t" "${1%.cue}.ape"' _ {} \; ali mora da je instaliran majmunski codec (ape) MacOS brew tap fernandotcl/homebrew-fernandotcl brew install monkeys-audio Ubuntu sudo add-apt-repository -y ppa:flacon sudo apt-get update sudo apt-get install -y flacon .
  20. Mikorist
    Koji Linux
    Mozda nekom zatreba komanda kako da razbije jedan flac i cue na komade u nekom folderu find . -name "*.cue" -exec sh -c 'exec shnsplit -f "$1" -o flac -t "%n_%p-%t" "${1%.cue}.flac"' _ {} \; treba da se ima shnsplit Na MacOS se instalira preko brew brew install cuetools flac ffmpeg shntool na debian isto samo apt-get install ispred ovako izgleda na primeru
  21. Odlično je to. KO voli limenu glazbu . Sent from my SM-N9005 using Tapatalk
  • Trenutno na sajtu   1 član, 1 Skrivenih, 464 Gosta (Pogledaj celu listu)
    452.1k
    Sanjalica
    Sanjalica
