Mikorist
Sve objavljeno od Mikorist
  1. Provereno doibro. Bez da su pozlaceni
  2. Imao ja posla. Bas to konfekcija. Krepa najcesce posle garantnog roka...Ahhh kinezi......
  3. Oprilike to.... Ove moderne pljuge imaju katrana i nokitina na meru. Cede iz njih do 0.1% preciznosti sadržaj. Imaš utisak da pušiš papir u koju je upakovana veštačka aroma duvana.
  4. Ispravljanje krive Drine krivom Drinom (Filter bandwidth adjusment. Filter Shape adjustmen), što se više multiplikuje, tolko se i komplikuje, što svakako se svodi na Gordijev čvor i na kraju by a comb filter - uklanjanje artefakata digitalno.... Ovde nema ništa što već nisu ismislili Japanci http://www.easyaudiokit.com/bekkan/manual/RenewDiscreteIV.pdf http://www.easyaudiokit.com/bekkan/manual/DAC9038DManual.pdf Two dual power supplies, two dual ES9038PRO DAC, two dual discrete I/V stages. Filter bandwidth adjusment. Filter Shape adjustment (Fast Roll-Off Linear or Minimum Phase or Hybrid) . THD compensation adjustment. Digital volume, Noise Dither ON-OFF, De-emphasis selector, Jitter Elimation ON-OFF. Master Trim setting, SW check and update, Frequency Calculator, DSD Bandwith set….
  5. FEEL THE PULSE Along with other very progressive audio brands – Chord and dCS in particular – Mola-Mola has its own, custom DAC solution executed in DSP. There are no off-the-shelf DAC chips inside the Tambaqui... Mola-Mola’s software upsamples all incoming data to 3.125MHz, truncating the wordlength to 5-bits while using a 7th-order noise-shaper to retain full dynamic range right up to 80kHz. Each 5-bit digital ‘word’ is sufficient to describe one of 32 possible pulse widths that, in turn, describe the amplitude of the audio signal on an (over)sample-by-sample basis. The pulses vary in steps of 10nsec (the system clock is 100MHz) right up to a full width of 320nsec (0.32μsec). This Pulse Width Modulated (PWM) signal is fed into a 32-stage shift register, clocked at 100MHz, so a composite of 32 pulses ends up reproducing the full PWM signal every 10nsec. The 32 outputs of the register are summed together so that the final DAC output is the moving average of the PWM signal over consecutive blocks of 32 clock cycles (ie, one PWM cycle), updating every 10nsec. The PWM signal is ‘conditioned’ by a comb filter whose teeth coincide exactly with the 3.125MHz repetition rate. Mola-Mola could have used the signal from any of the 32 outputs alone and simply low-pass filtered it. Instead, the moving average technique not only overcomes any slight mis-match in the summing resistors but it also removes the PWM carrier that could potentially demodulate clock jitter down into the audio band. This is innovative stuff ------ Ima DAC koji ima 7 order noise-sharper - podesavanje apsemplova do 10Mhz - ali mora rucno da podesavas na dugmice.... Ovde sofver radi automatski sve to....
  6. Pa pazi mislim da bi me kostalo iz delova da sastavim ovo oko 1500E a mozda i vise....Samo delovi.... Ima kod Japanaca da se kupe ove DAC skalamerije koje rade risejp i konverziju digitalnu po harmonicima. Kacio sam i ja I Shone DAC koji moze ovo da radi.... Tambaqui https://www.mola-mola.nl/readmore/HFN-Nov-Mola-Mola-Tambaqui-Reprint.pdf
  7. Sledeće godine u ovo vreme bit ćemo milijunaši . A možda i milijarderi zbog infalcije globalne.
  8. Mola Mola https://www.mola-mola.nl/tambaqui.php Cim pokupim kripto kajmak p.s. Ovo je inace Bruno Putzeys DAC
  9. Mikorist
    slusalice
    Pa ono jes pre cu da kupim Lambo nego da ga napravim
  10. Mikorist
    slusalice
    Ama slusalice isto treba samograditi. Nije raketna tehnologija. Mogu da se kupe drajveri i tih od $4K za 100 evra u kini. Samo naci odgovarajuci kabinet - ili ga napraviti sam. Sad imaju 3D printeri moze sta oces...A nista ne fali ni drvetu.
  11. Mikorist
    slusalice
    Ima jos dosadniji lik od njih - sampion p.s. verovatno je i on clan tamo na forumu
  12. Mikorist
    slusalice
    Vreme je da predjes na kripto
  13. Mikorist
    slusalice
    Ne znam. Meni su dosadni kao proliv ovi sa audioscience. Koja god da je tema . Mrzi me da kacim primere i skrinshotove - ne zelim ni da se bavim njima. Sto dalje od mene sa njima
  14. Mikorist
    slusalice
    Nešto ne verujem da su bolje od RAAL...da ne pominjem druge slušalice. Amir jbg živi od merenja i prezentacija. Ako neko ima 7000 merenja ne znači da je eminentan i da je naučan. Nego ima najviše pogodaka na Guglu zbog količine istih. I jehovini svedoci prvi izleću na Guglu a ne predstavljaju istinsko učenje. Samo su mnoogo uporni i dosadni pa je njihova priča na vrhu kolotečine. A audiosciencereview ništa bolji nije od sekte. Skoro je @vladd postavio pitanje na drugoj temi - a odakle ovome ovoliki izvor smetnji na izmerenom DAC ? Možda mu monitor pravi smetnje, bezazleni miš ili ima zakačen telefon na PC na koji se upravo meri DAC. Ne može se rođaci meriti tako . Sva ona merenja su praktično ništavna. No nije bitno kakva su nego je bitna količina. Samo ih izbacivati
  15. Mahokrilac (Ornithopter) iz novih Dina Još ako stvarno leti kao vilin konjic kao po knjizi I'm going to lose my shit
  16. Jel ovaj recept primenjliv na sve slicne zvucnike ? Dal moze drska za otpusavanje na Fane ?
  17. Bokte mazooo ovo izgleda bolje od Star Wars
